Everything posted by mtsmiths
info on someone's project
I log in when I come to visit, odderwise no can see da supahmahket, eh? Never know when the perfect Subaru will come along, desperation sale right in the next county ... course, BlueTrain is the onliest other member around, and he's TWO counties away. It just ate my post. I did the preview, corrections, posted, and 'poof'. It told me to log in and the whold page was history, piled in some virtual jy somewhere in cyberland. grrrrr.
... until the board ate it, that is. Had they used the bottom half of the hatch as a bottom hinged tailgate? How was the vertical 'B' pillar married to the slanted 'D' pillar? Will be building one sometime this year. First to sell the Powder Patrol wagon, and after, find a good clean AWD/auto wagon with air, power everything and moonroof. Will ultimately want a mild lift, winch and a few other goodies to make it useful as a light pickup
about making a Rancheroo, or El Subamino, and when I posted the board said I wasn't logged on and ate the whole thing. I'm p!ssed. What do we have to do, write in word and cut and paste?
Ventshade/ Window Deflectors, any of them fit?
mtsmiths replied to a post in a topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI've seen a few up here in Montana. They are long and run in one piece to the rear of the back door (I've seen wagons only). Don't know where they came from tho. I've been hoping to find one I can chase down and ask, but they've always been going the other way. If I recall the post, they came from England, so-oooo maybe these were down from Canada, eh?
2000 outback
mtsmiths replied to nhtutor's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXBought it in Nov '01 with 100,000 miles on it. Now have 146,000. NW Montana, so it sees it's share of snow and nasty cold, and has never faltered (except the two nights it was -27 deg. F, it made some complaining noises when it started in the morning). Much nicer driving and more 'sophisticated' car than our trusty '87s. If you don't know the history, and can't confirm that the timing belt has been done; do it right away. Also, if it's an automatic, don't neglect regular transmission service.
Would you pay $31,000 on a new car...
mtsmiths replied to duane b's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX... but a LOT of others would. The car was just voted the 'Readers's Car of the Year' by Road & Track magazine. The general concensus is 'It's put the SPORT back in 'sports car'.
Head gasket, Has yours been replaced?
mtsmiths replied to murphsubaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXNW Montana, so it sees all outside temp ranges. No HG leaks internal or external. I guess if it hasn't done it by now, it won't.
wierd happening
Classic symptoms, as taught in flight school. Is your Brat missing the heat muff snorkle? It would have actually started off sooner if you had left the hood down. As soon as you stop running cold moist air thru the venturi the heat from the stalled engine will melt the ice block out of the carb. After a couple of rough seconds while the engine digests the accumulated water, and you're off again. If it happens again, note the air temp / dewpoint; the closer together they are the better chance of carb ice. As you lose power put it in neutral and let it coast as it idles, you want as little air moving thru the carb as possible as the engine heat warms the carb throat. If the heat riser is missing replace it. Won't hurt anything but your prode ... unless you're flying over that pass and have to land your new glider on the interstate between the semis!
New 1st gen owner.. knows nothing
Are you expecting large amounts of snow?
OK lissenup, I am ready to pronounce an assessment on the SOA
"Cooling System Conditioner" Testing procedure: Shake thourtoughly, per instructions. Open can, remove seal (which was leaking, BTW?). Decant into clear glass jar. Allow to sit one hour. Observe closely. Characteristics after one hour: a red clear liquid on top of a rich depisit (approx 50% by volume) of tan to light brown sediment interspaced with black flecks. Smells just like paint thinner (turps, not mineral spirits). Judgement: This is a solution of finely ground oatmeal suspended in turpentine, and augumented with ATF (remember the 'lubricant' they promised). That's my story, and I'm sticking to it. This is simply STOP LEAK of some sort, pure and simple; and this is SOA's 'fix' for thousands of leaking head gaskets on low mileage new cars? Subaru should be ashamed, and we should be offended that they think we are SO gullible. Wait, most of America is, isn't it?
need Mechanic, Austin, TX
mtsmiths replied to aisha999's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXrather than a bad car. I don't know what the miss and hard starting is, but the vast majority of CEL lights on later Subarus are bogus O2 sensor faults, and should be ignored. Anyone that gouged you hundreds of dollars to get rid of a CEL was knowingly ripping you off, IMHO. I found an indy when I was working back east for the summer by looking in the phone book for a foriegn parts store that listed Subaru along with the other cars they sell parts for. Then I called them and asked who to go to. I got a guy who knew what he was doing, was cheap, and had me on the road in less time than promised. Good luck.
Head gasket letter from Subaru
mtsmiths replied to cookie's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX... I dropped in, had them pull our records and they handed me my little bottle of SUBARU "Professional Use, Cooling System Conditioner". Along with a warning from the mechanic standing by the service writer (who is basically a pretty good guy, and may even be a board member ... or at least benign lurker), to NOT put the stuff in if I'm not showing symptoms. The packaging is relabeled "Holts Stop Leak", looks like Barz-Leak dyed red (you know with those little-itsy-bitsy beads and stringy thingies). It smells just like paint thinner. These guys can't believe that SOA is pulling this stunt. We seem to be in luck, 146,000 miles with no signs of head problems, so the concensus at the shop is we won't have to face the head gasket demon. I guess I'll just keep it around for the inevetible leak in my '87 heater core.
Map lights installed in TS
mtsmiths replied to outback_97's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXas part of my deBrightonization program. Piece o' Cake. Also picked up a pair of lighted vanity mirror sunvisors from the Subaru site, for really cheap. Just as easy. Use the map lights lots, the vanity mirrors hardly ever, but I sleep much better knowing that they are there.
Cold air on passenger side! BRRRR!
mtsmiths replied to Rooskie's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXNo drafts anywhere, just cold. If we close all vents and put the heat only on, it passable, but never really warm. Only complaint about the whole car, but when it's -20 F outside IT MATTERS!
Marvel Mystery Oil
mtsmiths replied to ejlain's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXAlways has been ... whateverthehell it is.
Replacing Roof Lining - 89 L Series Touring Wagon
Lasted far longer than the OEM liner. Make sure you get good adhesion, and for gawdssake do't let the sprayed surfaces touch each other until you WANT them too! I covered the dried surface with waxed paper and lined each 'strip' up then pulled the paper out as I slightly stretched and smoothed the cloth down. Good Luck, you can do it!
Sears automotive
mtsmiths replied to mattocs's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThe local mechanics were SO bad, and would never make mistakes right. "Yah shuah effing haole, geddouda heah, brah 'for I broke yo' face!" One thing about Sears is that they will always honor their warranty. Just make sure that you can absolutely document condition when you take the car in. If you can prove they screwed something up they WILL fix it. Many (TOO many) years ago I got a new set of Goodyear tires on sale in LA. Since we lived in the country I got my front end aligned at Sears (so I could get warranty response). THey didn't tighten one of the links and by the time I got up to the Gold Rush country mountains where I lived the front tires were already ruined. Sears not only replaced the front tires, but because the local dealer didn't have the same tires, they replaced ALL FOUR with better quality as well as redoing the front end. In Hawaii I had my '84 Mustang HB front-end aligned and bought the 'lifetime' warranty. Poor Sears, because the roads on the Big Isand are SO bad, I had the car realigned at least twice a year ... and I kept that little car 12 years!
Four inches of fresh snow overnight.
And I had some errands out at the Kalispell airport. Of course I just HAD to go across the field from my hangar and borrow some wing cradles. All those nice wide taxiways and not even a deer track on them ... WHEEEEEEeeeeeee!
Coolest Subie Toy ever!
mtsmiths replied to GoldDiggerRoo's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX... terminally weird, but pure genius.
(Yet another) wheel bearing (?) post - FIXED
mtsmiths replied to outback_97's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIt wasn't too bad but we we're heading out for about 8,000 miles of driving so I had it fixed. mid $200's at a local indie. Both of our '87's have had to undergo front wheel bearing replacement. Rotate the tires anyhow, hardly any of us do it enough.
Snow Fun
mtsmiths replied to Hocrest's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThe Powder patrol is back in Montana, and lovin' it!
Snow Fun
mtsmiths replied to Hocrest's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX... eh?
2 problems,1987 Subaru 4x4 GL wagon D/R 5 speed??
... if i was damp out as well as cold (like ice fog conditions) the lack of a heat snorkle on the air cleaner can cause carb ice. Both our carb '87s started dieing on us in the; cold and I finally sussed it by thinking about what the symptoms would have meant if I had been flying ... AHA! Carb ice, it was too, a new flex tube on both cars and neither one ever died again.
what headlight bulbs to buy?
mtsmiths replied to johnd911's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI put in Wagner Ultra-Brites (the pure white ones, not the 'blues'). $14.95 ea, in stock, over the counter at the local NAPA. Much better than stock, and no ' false high beam complaints' from oncoming traffic.
30,000 Mile Checkup {2000 Forester}
mtsmiths replied to howards11's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThem easterners don't git out much do they?
