Everything posted by calebz
Gary is right. Check here on the board. I sold 2 a while back for between $25-30. Although, if you are not having any functional difficulties associated with the code, I would start with by clearing the codes and checking the wiring. I have had 2 EA82 optical dizzies crap out on me. THey make themselves real obvious when they don't work anymore;)
Tips for taking off EA82 rear struts???
calebz replied to Ryanb's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Air Tools -
Turbo GL Question... need help!
calebz replied to tjZ06's topic in Old Gen.: 80's GL/DL/XT/Loyales...
If you are looking for something to lift, perhaps an 88-89 SPFI wagon would work better for you. The turbos are sorta lacking in bottom end. I spent about $400 on my longblock.. a large chunk of that was for some specialized taps and such that I had to buy to install the carbon steel head bolt inserts that I wanted. I did as much of the work as I could. I paid a local NASIOC guy to weld a small piece for me, and a local muffler shop for a piece of intercooler piping. All other assembly and mods were done by me. Where I started to get into more money was when I bought a bigger turbo, Intercooler, RX body kit.. things like that Oh, and BTW, no boost gauge that I know of in any of the EA82T cars. Granted, mine have all been digidash, but I don't think the analogs had it either. CRX A pillar pod and some guages takes care of that though. Also, there is usually a bit of debate about fuel grades. I always use premium. 90% of the cars I have had over the past 10+ years have been turbo. Most of them asked for 91 and above in the owners manual. -
Could be any or all of the above. Either way, if it is a decent price, EA82s are cheap to build. -
Thats is for the hill holder. You only need to replace the MC and lines if you intend to keep the Hill Holder. Personally, when I did mine, I stayed with the stock MC, and just put a nice strong return spring on the clutch fork.
Thats a big question with no real direction. Search through the forums (this one specifically), gather some info on your own, then post up if you have any specific questions. Caleb
MUST SEE RARE JUSTY CLUTCH lol
calebz replied to JustyPimp's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I noticed the pic being used is just a stock pick. Not application specific. Am curious what makes these 'stage 3', since they didn't really see fit to post any specs in the listing. -
Emission question for state of washington
calebz replied to starkiller's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Yeah. King and Pierce pretty much follow the same standards, but boondock places like Thurston have no emissions. Though I hear that will probably change in a few years:( For now I keep teh wagon registered in Thurston County.. Easier that way. -
RS that looks like an RX?
Only ones I have ever seen have been maroon/SPFI/AT -
Gentlemen, I am at your mercy.
calebz replied to eponodyne's topic in Old Gen.: 80's GL/DL/XT/Loyales...
www.ozified.com thats a good place to start;) -
Nissan 280ZX Turbo Injector Swap *DONE PROOF*
calebz replied to Steveman09's topic in Subaru Retrofitting
Thats actually good info. IIRC, the FSM puts our stock fuel pressure at 36psi above manifold pressure. That should actually yield more fuel than the Nissan factory 259cc/min Looking better all the time -
I have to wonder though.. the Z - injectors are 259cc/min, but at what PSI? Seems the stockers came up into the 230s or 240s in a 43psi test. Nice mod. Going to have to keep my eye on this. -
Turbo motor with NA pistons
calebz replied to Subarian's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Hard to tell what the improvement was. I did the shortblock, Intercooler, TD04 and 2.5 inch TBE all at the same time. As a whole, it kicks rump roast:D -
I used the whole NA shortblock with mine. It goes pretty well.. Has aabout6k miles on it like that.. Premium gas? I have driven mostly turbo cars for the past 10 or so years.. they alllll get premium -
Additional note: The starter is not always the say between EA82 manuals and autos. it bolts up the same, but some of the autos used a long bodied starter that, when used on a manual, tends to get in the way.
What wheels will fit my 89 DL
calebz replied to Suzrub's topic in Old Gen.: 80's GL/DL/XT/Loyales...
5x100 for the win! -
Looks that way to me too. Moving to old gen. More justy owners there.
ea82 dizy advance curve turbo vs NA
calebz replied to fredsub's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Sorry man, Iam going to have to let someone else answer that for you. I tend to stay away from the pre-87 stuff;) -
yes, That is correct 85-86 - 25DBTDC 87+ 20DBTDC -
If they are both dizzies from a hotwire MAF /optical dizzy setup (87+), then the connectors don't matter as much. Sounds like what you got was an 88+ dizzy.. there are a few wiring differences between 87 and 88+. No worries though.. most of the diffferences can be easily adapted to fit either year. There is a phillips head screw on the underside of the casing. take it out and you can swap connector pigtails.
The front swaybar on mine was a serious pain as well. Eventually just wrestled it into submission. My car is too low to do it with both wheels on the ground, so I put the car on ramps. Much easier. Still haven't gotten the rear one in yet. That was being a serious pain and I haven't had enough time to bully it in there.
EA82T headstuds once again!
calebz replied to Caboobaroo's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Timeserts do the trick quite nicely
