Everything posted by calebz
Can it be done(N/A block mated to a Turbo)
calebz replied to Petersubaru's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Less zoom too -
Who has replaced pug lugs with aftermarket?
calebz replied to TheSubaruJunkie's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I would like to know as well.. I don't like the way the factory soob nuts fit on my Konig wheels -
Knowing what fuel system each has will go a long way toward being able to advise you. Each fuel system uses a slightly different compression ratio. Oter differences as well.. Overall, $600 probably isn't too bad if theres lots of good extra parts. PS - no Tcase in a soob.
K & N cone air filter installation?
calebz replied to CoreysLoyale's topic in Old Gen.: 80's GL/DL/XT/Loyales...
A lot of us have had way too many subarus -
No -
Mine didn't take any modification to make it fit:-\ Even has the P/N in one of the links I posted -
Piston issues - what would cause this?
calebz replied to mr.radon's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Running Turbo pistons in a nonturbo car would only result in a drop in power due to the subsequent lower compression. -
Not too lazy, still waiting for parts. If I could just have a full day to work on it, I could probably get everything done.
http://www.ultimatesubaru.org/forum/showthread.php?t=28681 http://www.ultimatesubaru.org/forum/showthread.php?t=22170&page=3&pp=15&highlight=maf+adapter Search is your friend. -
if its a cone filter, youre going to have to remove the airbox and get a mass airflow sensor adapter so the cone has something to clamp on to -
That ground has been covered. You end up with a lean condition at high boost.
Can you use wheel adaptors on an '85 Subaru Brat?
calebz replied to Tranzition's topic in Old Gen.: 80's GL/DL/XT/Loyales...
IIRC, center bore is ~54 mm -
Cooling: water is getting warmer
I had the same issues with my wagon..Grounds were the key. Do you have a digidash? -
not sure.. your last post said you had a line on a couple "EA8T" Cars, so I just took a shot in the dar..lol yes, EA82T can be done as well.. more work.. But probably more fun as an end result.
Let's play engine trouble trivia *Answer Posted*
calebz replied to spanky_pete's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Plug wire broken -
Sure.. Install an EA81T in the brat.. it would be cool.. Make sure you have all the stuff you need before you scrap the donor though..Crossmember, ECU, wiring harness.. all that neat stuff
More of a mounting thing. The EA81T is MPFI like the EA82T.. So it would have the proper intake ports on the heads, which you current heads do not.
If you wanted it setup like a factory type system, you would need a lot of EA81T parts.. Heads And such.
What does an EA82 weigh?
calebz replied to belizeanbus's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Yup.. Two guys can lift an EA82 from the bay withot much trouble. I'm not a very big guy either, and a friend and I did it with an EA82T -
engine options list throughout the years
calebz replied to rabbit_39's topic in Old Gen.: 80's GL/DL/XT/Loyales...
The rear in the turbo car will be 3.70. The Non turbo D/R is 3.90 The sawp is pretty easy, especially since you have the whole donor car from which to get all the trim and linkage and such. Yes, you will need to use the D/R axles with the D/R trans (23 spline) they should hold up just fine. -
86 turbo is MPFI. More than likely no dual range. -
Sooo.. Tell me again.. How is fabricating a complete (functional and safe) turbo setup easrier than a bolt-on setup as described above? Vanislru - cool site.
Don't worry, we're not;)
