Everything posted by Step-a-toe
second generation Brat Shock absorber
- second generation Brat Shock absorber
It was possible to replace the inserts on the 81-83 models once upon a time- second generation Brat Shock absorber
The two part numbers for left and right, superceded to one to do either side. If you had that part number, have you got a Subaru dealers to ask if your can order in? I run EA82 L Series struts in my 2nd Gen Brumby, required the three bolt top mounts, mounting holes to suit. Also made my own jelly bean shaped reinforcement washes to replicate the originals- EA81 Oil Pump
- EA81 HITACHI FUEL INLET
GD ? Makes it easier to retain the rest of original bits such as return hose and fuel filter up front. I pulled one off my single when I fitted up my twins, for fear of screwing things up if I didn't. Pulled another the other day off another single Hitachi in case a Weber conversion needs one. Got the Weber, the return line fitting, just need adaptor plate and a recipient- clutch cable keeps seizing/snapping
Yeah, such a clean break, looks like vandals. Has the clutch and it's declutch bits been inspected, you know, engine and box separated?- Fuel pump control unit '83 GL
I have seen one dodgy HT lead cause tacho grief What sort of job is it to rebush an EA81 dizzy GD? I have a worn bushing with sideways play up top- Anybody run cylinder walls like these on an ea81?
Only one way to find out -try it. There are cars getting around that have been bodged up and put back together and likely give some reliability until it poos itself. A mate used to say " back home in (select your Baltic country) we wouldn't have had a choice but to stick it back together" Depends what and how you use it too- Fuel pump control unit '83 GL
Two functions. One safety, one convenience yeah as GD asks, better refresh your module issue while he is in the room- Weber EA81
I think it has only one function - to only supply power and maybe also earth to the fuel pump once engine is running. And as you know, relies on a signal from the coil to control stuff. I don't know if it has a momentary prime on initial ignition switch on as fuel injection and propane safeguards have. Think I have seen the safety box has six wires. I use propane safety control units that are just four wire, or even just 3 when mounting bracket is the earth connection- Vacuum lines
Get some silicone blanking plugs in the standard size, 3 , 4 mm and blank everything off after next step below Don't try start it on old fuel, pop the sender off the top of the tank and take a peak inside first.- Weber High Idle
I think you may have "main jet" and idle air adjust screw confused. Maybe it is me confusing with certain Holley 4 bbl ?? A few years since I have played but think main jet is inside and needs top section off to access, change. You have primary barrel your choke sits above, then the secondary barrel that opens mechanically- Weber EA81
- Weber EA81
- Weber High Idle
Yep, the air in the crankcase needs to exchange with outside world in a filtered way ( combustion ). Make or buy a catch can to run the 5/8" lines to catch can. I use heater hose. Also need to plumb in the PCV valve. Then use a smaller diameter hose in order to fit the Weber carb air filter fitting. I would fit two into air filter base to start to match the original 5/8" flow. So, catch can could have up to 3 of 5/8" fittings and 2 of 3/8- 4WD transmission compatibility question
That was quick work and one of the better ways to get job done or just shift to driving the donor. I did. Got eight years / 110,000 km on it before it donated it's organs- Weber EA81
- Weber High Idle
It was wrong to describe the two holes into side of engine as such - I have no idea what you describe. Plug the PCV Post some well lit photos?- Weber High Idle
It is surprising just how many revs you can get from such a minimal opening of the throttle. Looking down primary throat can you see if it is closing properly? Is it a tried and tested Weber or out of the box newy? Had issues with new before with idle screw jet only just holding on ( by some foam packing?) Adaptor correctly seated between inlet and Weber? PCV valve stuck open?- Camshaft "jumping" after timing belt replacement
Good to hear positive result. Did you torque the tensioner bolts correctly? They only have a low number like 15 ftlbs. Some do elbow tight and can spoil threads and clamping ability- Camshaft "jumping" after timing belt replacement
Have you successfully done EA82 timing belts before?- 4WD transmission compatibility question
You will find many threads on EA82 5MT DR into EA81 body. I have done a few. It is a conversion, not a direct replacement, yet quite an easy conversion The hi lo 4sp 4wd from EA81 will be more straightforward- 1991 Subaru Loyale wagon 4wd
The auto starter motor is different most often in these. They turn a light flexplate, with a filled torque converter but a manual starter turns heavy fly and clutch and compression of course So yeah get starter motor that matches the flywheel- '80-'84 part numbers
I hate to say it but....book face ....saw a photo recently depicting a jumper installed. A single wire jumping from one terminal to another I looked and looked even harder when stripping out a 9/84 Sportswagon - no control module above the pedals, behind the cluster at all. Maybe some models or some markets had or required the safety circuit, others not? Tricky to get to. Why not 'just' run say an LED in your console powered by the earth and power wires at the pump so you can monitor its power supply?? - second generation Brat Shock absorber
