Everything posted by Petersubaru
How to Install a new wire to the fuel pump
I will let you know, maybe in the next couple of days, hopefully it will not be to cold outside
Any of you guys run H6 oil filters on your H4's?
Petersubaru replied to Towel Rail's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXGenuine Nippon from rockauto.com $2.45ea..outside looks identical to the mobile 1, including the metal stop ring for proper tightening(for those that need that)
That is exactly what I thought...but the pump will only run and the car starts up when directly hooked to the battery which has more voltage
Loyale wandering front end
I have a bit of wandering in my 86 with original ball joints and 265K miles ... the aligment guy said that all the ball joints are in good condition and do not need to be replaced...although there is some "side to side" movement of the shaft that comes out of the rack...the constant in and out movement has caused the bushing around the shaft to be worn out...I will have to replace the rack before ordering new tires..or stay with scrapeyard specials
..I know it is not the "plug" because I went inside the car under the carpet to test the wire leading to the pump...had the same low voltage
my '86 loyale Carb fuel pump has only 12 volts going to it (not enough to run it) while the battery has about 13volts or more...the pump works OK when hot wired,but my haynes manual does not provide enough info ...does the pump run directly off the coil or starter switch or ???
Was the Headgasket problem taken care of for the 2004 Outback
Petersubaru replied to Petersubaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXSorry, I forgot to mention that the original question was for a 2.5L motor
my son-law is looking at a '04 Outback with 40k mi on it and was wondering if the headgasket issues were somewhat resolved...being familiar only with the '01, I was unable to answer him ...I think the problem was corrected for the '05 or '06
Question concerning about Hooking the battery up the wrong way
Petersubaru replied to Petersubaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThanks guys..
I am asking on behalf of someone else who is to embarressed of what he did...but what will happen to the car when the battery (with some forceing) is hooked up the opposite way ... now after correctly hooking up the battery, the the car will not start, but only will turn over,over...will it damage the ecu
2001 H6 3.0 OBW LL Bean Ed. purchase recomendations
Petersubaru replied to DubMutant's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXyour description above for the subarus(6cyl) also applies for many chrysler cars having the same oil lubricated timing belt tensioners..strict and often oil changes are needed to maintain those pulleys
Rear CV axle removal??
I was just going to start with this method..I need to have just a little more, an inch or two will do it
my Haynes manual just says to remove the pins for the rear axles to drop down on my '86 4wd loyale wagen..I am having a problem with this method in trying to remove them and I was wondering if something further in the suspension needs to be unbolted to make this work
Rear differential Bearing Removal??
just wondering if someone has already replaced the rear differential bearing on an '86 loyale and what may be involved...for ex: if I pull the side cover off, will the bearing come with it ??
Rear end Gear noise...what is the cause
I hear or at least I think the noise is coming from within the rear end gear housing ...in gear or in neutral when coasting the noise is the same...a flopping sound..I have heard this sound before in more extremly driven cars... the '86 loyale has only 250K miles mostly highway driven, with the rear end oil changed regularly,... it seems a bit early for problems in this area....when slightly turning the drive shaft in either direction, I notice that the CV axles on both sides of the "pumpkin" seem to go more up or down first before beginning to rotate...would this be normal because of the short splined stubs coming out of the "pumpkin" with a sloppy fit for the cv axle to fit on...or just maybe, is it the bearings within that are showing signs of excessive wear??
Ea82t
the 1986 turbo (canadian) automatic with original manual says 89, but for my driving style I use 87...timed to 25 deg btdc..no pinging unless I "floor it"
Very basic Question concerning checking the Dip Stick
Petersubaru replied to Petersubaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI was made aware of this on my first oil change...the exact same amount of oil was added too what was drained out and it showed "low" on the stick, while before the oil change it registered "full".. I guess the best way to handle this situation is to add the amount of oil that subaru requires and just leave it be until the next oil change and when checking the dip stick and seeing oil between the marks, also leave it alone..just trying to make it easier for the wife without her worrying to much
Petersubaru replied to Petersubaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXthe oil is always checked cold,
Petersubaru replied to Petersubaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXthat is exactly what I am doing
on my '01 outback I thought it would be simple for my wife to check the oil level when looking at the dip stick, but even I am confused...The oil is checked Cold with the car parked in the Same spot on the driveway..at times the dip stick shows that 1/2 qt could be Added and other times when checking the oil, it is completely full...I have tried like this morning to add 1/2 qt..drove the car around the block and when re-checking the dip stick, it showed that I have added Well beyond 1qt of oil...the oil level orginally was between the 2 dots and now it sits well above the the notch on the stick
Anyone done a turbo to non turbo swap?
wouldn't you also have to change out the turbo fuel injectors to non/turbo F/injectors..much like the difference between the N/A MPFI and turbo MPFI
Air Bags and possible Dangers Question
Is there a danger of injury or worse from sitting too close to the steering wheel when the bag goes off...I have asked a lot of people, some with long arms and others with very short arms and nobody seems to have a clear answer on what is a safe distance ...some people drive around around looking like they are ready to kiss the wheel
What's the biggest tire i can put on the Stock 13" steely?
I am running 185/80/13 on my stock 4wdr loyale, even when loaded down there is plenty of room...10-15 tire companies that provide these tires thru ... http://www.tires-easy.com and cheap
brake pads sticking
Petersubaru replied to popeye2's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXwould useing ceramic pads cause this same problem
Opinions on window tint
Petersubaru replied to danz75's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI thought 3M along with a good installer plus lifetime warranty was the only way to go
