Coolant Conditioner ... to goop or not to goop?
Legacy777 replied to hohieu's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXbump
Polymer Vinyl Sticker
Legacy777 replied to likecivic2006's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXbump
'91 EJ 22 - Not smooth
Legacy777 replied to mtnwater's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXPlease elaborate on the "growl" Is it coming from the intake, the motor....? Does it feel like it has similar power to other converted vans? Any other details will help in diagnosing.
98 Legacy GT replacement exhaust
Legacy777 replied to rlsimpso's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXHow much are you wanting to spend? Do you want a bolt up type application, or do you want to get just a muffler and have a shop fab up the piping? You may want to ask your question in the legacy forums on nasioc http://forums.nasioc.com/forums
A/C ?? about my '92 Wagon
Legacy777 replied to jimkup's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThe subaru specific haynes or chiltons manuals don't tell you squat about the AC system. I would suspect you overcharged the system. On converted r12 to r134a systems, you should run about 75% of the original R12 refrigerant capacity. Did you do the conversion, or did someone else do it? Can you give details on what exactly was done? What pressures are you seeing? A book I would recommend is the Haynes Air Conditioning book. It's very good, and has a lot of info.
DIY head refresh
Legacy777 replied to 970subaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXPersonally....something like what you're talking about is not an item I would recommend a DIYer with limited experience to perform. I didn't even bother when I did my motor. Even if I would've done the heads myself, I probably would have still taken them to a machine shop to perform a valve job.
air condition, temperture selector knob?
Legacy777 replied to mackryan's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXPlease post the year and model vehicle you are having the issue with.
'95 L Wagon - Vulnerabilities?
Legacy777 replied to subiedoobiedoo's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI don't really know of any one particular thing that could be a deal breaker. Anyone else with the 95-99 MY's have any other comments?
Name this part
Legacy777 replied to nipper's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI'm sure it may exist on some of the newer subarus, however on the first gen legacies 90-94....I believe it only came on the 91 turbo model.
Which ATF filter gasket to get???
Legacy777 replied to Mjez's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXTo be quite honest, the older transmissions just had a screen, and no filter. The screen is in the pickup piping. Usually they stay pretty clean unless your tranny is eating itself up....in which case replacing the screen is the least of your worries. I'd really just recommend draining the fluid without removing the pan. If you want to remove the pan, I'd recommend calling your local subaru dealer and see if they can decipher which one you're supposed to have. Typically they should be able to determine which one you need by the production date of the vehicle.
AC not engaging on 1999 Forester
Legacy777 replied to phatline's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXDoes the compressor clutch engage when the ac button is depressed? If not, I think you're on the right track with the issue being electrical. BTW, the search engine requires a minimum of 4 letters to search. You can search for 3 letter things by using an astericks a/c* or 2 letter word by using two astericks *ac* However you're going to get A LOT of other stuff if you just use the search term *ac*. For that search to be effective, you should add another term.
Stupid window won't roll-up all the way.
Legacy777 replied to Jutboy's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXAny chance of better pictures or larger pictures. I can't see squat in those pictures, so I really have no idea what the metal piece you're talking about is
Name this part
Legacy777 replied to nipper's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI believe they were only on the 91 turbos, if my memory serves me correct.
Zexel compressors: Drain Plug?
Legacy777 replied to anastij's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIf it's not on the body of the compressor, you'll have to drain/fill the oil out of the inlet/outlet ports.
Name this part
Legacy777 replied to nipper's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThat part is a clutch damper. There should be a line running from the clutch master cylinder to the damper, and then to the clutch slave cylinder. As to what exactly it does..other then "damp" something....I'm really not sure. I did not install the damper when I did my AWD & 5MT swap, and I don't really see an issue to not having it on there.
95 legacy stalls... what vacuum lines (sets) are recommended?
Legacy777 replied to yarikoptic's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXGlad I could help
Engine H4SO U5
Legacy777 replied to dpoppeli's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYup....they have some good vacation pics
'93 Legecy, won't start
Legacy777 replied to buddyepa's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThe air control valve is the idle air control valve. To me, both of the codes retrieved wouldn't indicate/cause the problems you are having. I don't recall if this has been asked but are you aware that there is a bleed screw on the passenger side of the radiator that must be open to properly bleed the cooling system of air? If this has not been open, open it, and see how things go. However I'd probably suspect a headgasket or similar issue with the symptoms you described.
Three cylinder boogey...again!
Legacy777 replied to Greg55_99's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXBINGO! And that's why I said you need to do the italian tune up every-so-often and run some fuel system cleaner. As for frequency of the italian tune up......depends on how much you drive.....every other week...once a week.
95 legacy body work documentary
Legacy777 replied to dj3stripes's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXNice before pictures. Keep us posted as things progress.
low fuel light went kaputz
The R22 connector is under the rear seat on the passenger side. That scan is for the 90-94 legacies. As I mentioned, the low fuel light is triggered by a separate device on the older cars. It doesn't sound like that's the case for the newer cars....so the test procedure I posted probably won't work. Here's a pic of the fuel pump assembly http://www.main.experiencetherave.com:8080/subaru/images/ej22t/28/DCP_5290.JPG The thermister is the round silver looking thing attached to the bracket where the sender is located. Some additional pics http://www.main.experiencetherave.com:8080/subaru/images/ej22t/28/
Going to 'pretty up' The Pretty One's '00 Legaback*
Legacy777 replied to mtsmiths's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThe covers should either pop out, or there will be some screws or something to remove. Your best bet is to remove the fender liner so you can see behind the bumper. That'll tell you real quick what you need to do.
92' Legacy 2.2- Q's about Valve Replacement
Legacy777 replied to LostinSubaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXFor your code retrieval process. It sounds right. The only thing that is a little odd is that the CEL did not blink a steady all clear when you connected the black diagnostic connectors only. Being that your ej22 is not turbo'd, that shouldn't change much....if anything it'll be easier.
Legacy777 replied to LostinSubaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYou can do the head without pulling the motor, however it's a little more cramped. You're probably right about it being a valve type issue. The bottom ends tend to be pretty stout, but without removing the head, you really don't know. The CEL isn't going to be displayed because OBD1 ECU's are a little limited, and if the issues is mechanical, the ECU isn't going to really know that anything is wrong. Newer OBD2 ECU's that detect misfires on particular cylinders would probably have thrown a code. Just curious....how were you pulling the codes from the ECU? I've got instructions on my site www.surrealmirage.com/subaru/engine.html Also, here's some pics from my engine rebuild, which may give you some idea of how things are put together and confidence of doing the work yourself. http://www.main.experiencetherave.com:8080/subaru/images/ej22t/
Legacy777 replied to Greg55_99's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYeah, that exhaust valve is toast. These engines tend to build up carbon if they don't get run hard every now and then. It's also a good idea to run fuel system cleaner every now and then.
