Does anyone here have a MSD ignition system on a legacy?
Legacy777 replied to Nug's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXcool
leaking fuel lines 92 legacy
Legacy777 replied to anaphe's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXjust buy a length of fuel hose and replace that section. Rubber hoses do get brittle over time.
Legacy777 replied to Nug's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXguess they haven't updated their website.
H6 duel cab ?
Legacy777 replied to Neil's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXthink you're talking about the baja. Don't think it has the H6 though.
new to this board
Legacy777 replied to sevenkenny's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXmight get some more replies on http://www.nasioc.com what year impreza does your friend have, and what year engine you looking to get?
need "check engine" light help
Legacy777 replied to johnd911's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXyeah check out my site.....let us know what you find. there is no egr valve on the 1990-1994 legacies.
Just incase no one has seen this awesome site.
Legacy777 replied to torxxx's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXpretty sure we won't get the xenon head lamps....
Valve Timing
Legacy777 replied to automan1223's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYou didn't mention whether you're looking at using an ej25, ej22, etc. You may want to contact cobb tuning http://www.cobbtuning.com as they make cams for the 2.5 May also want to contact Paeco http://www.paeco.com/
Driveshaft length
Legacy777 replied to ShawnW's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI'll take a look when I get home. Was busy all weekend....and now i'm back at work.....yeah
Legacy777 replied to Nug's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYes you must use a DIS ignition one.... I think you meant to say the programable DIS ignition, pn. 6212 It's a nice unit, however it is more expensive then the normal DIS 2 which you can get around 300 bucks. But with the programable one you do get to set boost/timing curves and other goodies.
head gasket warrenty
Legacy777 replied to brompy's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXplease keep all replies in your other thread.
Legacy777 replied to Nug's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXyeah I got the dis2 unit. Good ignition, good options, and pretty easy to wire up. I've got some pics on my site.
Driveshaft length
Legacy777 replied to ShawnW's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI can give you specs from my legacy fsm if you want....not sure if it'll be the exact length you're looking with.
ej 22 thermostat
Legacy777 replied to myossfeece's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXyeah....thermostat is on the bottom. There is also a bleed screw on the top passenger side of the radiator (for US models) It is necessary to remove this to help bleed air from the system. Also turn the heat on full blast when bleeding air out.
Legacy cigarette lighter
Legacy777 replied to JHH0511's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXcheck the fuses. If you remove the panel below the steering column that should give you a little more room to test things.
No AWD – help!
Legacy777 replied to dashton's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThis is the part # 31711AA911 I have a complete parts book for the 1990-1994 legacies. It has application guides and other very helpful and useful stuff. That TCU is definitely used in the AWD legacies 1990-1991 to be exact. Definitely check the grounds.
Autobahn Driving
Legacy777 replied to EuroB-rad's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXyou won't get the new filter completely full with oil.....but fill it with as much as you can......and yeah....there's no need for an anti-drain back valve on the EJ series motors since the oil just drains back in the filter.
No AWD – help!
Legacy777 replied to dashton's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXDave, post the part # on the TCU, and I'll check to see whether it's a FWD TCU or not.
EG 33 HP / Torque Curve?
Legacy777 replied to SVX JET's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXyeah, I'd say you'll do a lot better with an aftermarket ECU, since you can tune it for performance & to run right, rather then for emissions.
Question about electric radiator fans...
Legacy777 replied to Atomic Robot's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXfans kick on around 190-200 deg F I believe, or so they do on my car. Turn on your A/C or defrost. That will kick the fans on regardless of temp. But yeah if it's super cold, I wouldn't expect the fans to be on much, if at all. Subaru cooling systems are very robust.
Legacy777 replied to SVX JET's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYou loose a fair amount through the AWD.....however that dyno does seem a little low. It can depend on the type of dyno that was used as well.
Legacy777 replied to SVX JET's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXmay want to ask over here http://www.subaru-svx.net
P/S shudders, why????? (94 impreza)
Legacy777 replied to Ratty2Austin's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXhmmmm never thought of the fluid.....I'm using a synthetic ps fluid......wonder if I should go back to just a dextron III fluid.......
95 Legacy blows hot then cold....
Do you know if they used an OEM thermostat when replacing water pump & t-stat? That can also cause you some probs if they used an aftermarket kind.
Rear subframe compatibility
Legacy777 replied to Marnix's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXhmmm......not sure.....it's a good question though. may want to ask on http://www.bbs.legacycentral.org
