8
I bought a 92 Legacy sport
Legacy777 replied to wplocal's topic in Meet n' Greet. Your USMB Welcome Center
Welcome to the USMB. I'd also suggest checking out http://www.bbs.legacycentral.org if you haven't run across it yet. -
I would suggest starting by checking the ECU for codes. Even if the CEL hasn't come on, it's a good idea to check. From your description the only consistant thing is the problem occurs after filling up. Do you always take the fuel down to around where the tank is empty or do you fill it when half full, or is it a mix? That may help determine if there's any consistancy related to fill up level. What kind of maintenance has been performed on the car in recent months/years? Any additional information you can provide would be helpful.
3.6?
Legacy777 replied to Suba9792's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
I've actually heard some reasonably good comments about the new 6's Subaru is making. No real issues that I've heard of. -
I'd take a turkey baster and suck as much of the old fluid out and put some fresh fluid back in. If the fluid has consistantly been aerated, you may not be able to get the air out of it. So if the noise gets better with new fluid, but is still there, I'd drive the car a little, and then remove the fluid again and replace a second time to flush as much of the old stuff out. Also, do make sure to use plain old Dextron III (you'll most likely only find Dextron IV or V, which is fine)
