Everything posted by forester2002s
2009 Outback starter motor problems: Maybe a bad relay?
forester2002s replied to Ravenwoods's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYes, that temporary wire should work to crank the engine. Just a note of caution: If doing this on a Manual Transmission (MT), make 100% certain that the gear-shift is in Neutral (otherwise the car might leap forward)
forester2002s replied to Ravenwoods's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXAll these 3 must be satisfied, to energize the starter solenoid: - Ignition switch to 'Start'; - Starter-relay energized; - If MT: clutch-pedal depressed to close clutch safety-switch; or if AT: in park (or neutral) to close start-inhibitor safety-switch. These 3 are all in a 'series' circuit/logic; this requires that all 3 work, before the starter is energized. On my 2002, these devices are all in challenging locations to reach. May be easier on your 2009.
Stumped on my highschool daughters first car - 2008 Legacy can't go up hills and has no power
forester2002s replied to idosubaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXCould be a partially-clogged fuel filter. Put in a new one, and see if it makes any difference.
06 baja drinking oil
That sure is unusual! How does that work? I don't see a physical connection between the vacuum lines on the booster, and the brake-fluid system. EDIT (2 weeks later): I now see how this must have happened: the brake master-cylinder is mounted on the front of the vacuum-booster, with the operating rod of the cylinder extending into the booster. Hydraulic-oil must have leaked past the rod-seal, and into the brake-booster; and from there, a vacuum hose would have sucked the hydraulic-oil into the intake-manifold of the engine. Bingo, oil burning-off in the exhaust!
Head Gasket blow-by?
1996 Subaru Legacy with bad rear wheel wobble
If it's a vibration (rather than a visual wobble) coming from 'somewhere' in the rear of the car, then it could be the main drive-shaft vibrating under load. The centre bearing of the drive-shaft (located forward of the rear-diff) could be loose, or beginning to get loose.
Vibration at 25-35mph and light load and at highway speeds - getting worse!
I think that you are right to suspect the drive-shaft. The drive-shaft shouldn't be able to be moved by hand. It should be rigid, not soft - especially in the radial direction. A passenger in the back seat might be able to tell where the vibration originates.
Anyone ever run a 2005+ EJ without a timing belt cover - I have a question for you
forester2002s replied to idosubaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWhat about the belt-tensioner? Is it behaving itself? And another possible suspect: the belt guide-shoe, above one of the pulleys? (only installed on manuals, I think)
H1 LED Headlight Bulbs?
forester2002s replied to lmdew's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXFound this in a 2011 NASIOC forum: So it looks like the following Subarus use H1 low beam bulbs: 2004-2005 Impreza 2003-2004 Baja 2000 - 2003 Legacy
forester2002s replied to lmdew's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXSingle H4 bulb, with 2 filaments.
forester2002s replied to lmdew's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXH1 bulb are single-beam. H4 bulbs are twin-beam High/Low.
resurrecting 1996 Legacy 2.2L - what's this vacuum hose
forester2002s replied to kite's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXOne other, often overlooked, maintenance item: Change oil in rear-differential. First, check for oil leaking from the differential, especially from around the input-shaft, and from around the left and right output shafts. Ideally, the differential case should appear dry and not oily. If there is evidence of oil leakage, then the oil-level should be checked, and it's not much extra work to drain and replace the oil. However, if the diff-case is dry, with no apparent oil-leakage, you might be tempted to leave well-alone; but it's really not difficult to drain and change the oil. There should be 2 plugs on the the rear face of the diff. Use a 1/2"-square male driver to release the plugs. Always remove the top (filler) plug first, in case the plug is seized. On most Subarus, the rear diff takes about 1L of 75W-90 gear oil. The trick to filling the fresh oil, is to buy a cheap 'turkey baster' (squeezy-bulb type), and use that to get the fresh oil in through the upper fill-plug; fill until the oil reaches the bottom of the fill-plug. And you're done.
forester2002s replied to kite's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWhile you're at it, it would be a good idea to replace the fuel-filter (the black canister that one of the fuel-lines is connected to).
Clutch replacement
https://www.ultimatesubaru.org/forum/topic/145506-ej251-engine-weighs-119-kg-262-lbs/?do=findComment&comment=1222275
Strange Electrical Issue
forester2002s replied to Daskuppler's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXAgree on both points. Electric gremlins are difficult to corner and deal with. And there are multiple ground-points to worry about. My philosophy on grounds is that you can never have too many grounds (I'm not totally convinced that this is always true). So rather than chasing bad grounds, it might be quicker to just add grounds (in strategic places).
2012 Outback Manual Transmission - clutch pedal to the floor, won't come back up
forester2002s replied to idosubaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIs anything interfering with the clutch pedal? Carpet or mat for example?
After brake job, electronic parking brake set, idiot lights ALL lit up, car immobile
forester2002s replied to craigmcd's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI've replaced the brake-pads (front & rear) on my 2017 Forester. And with no problems. But my Forester has the old-style hand-brake lever - no electronic brake gizmos.
Torque converter seems to be slipping?
Oil change/flush might help?
2014 Impreza start up noise
forester2002s replied to Bilegeyser's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI would be tempted to to try a thicker grade of oil (but still within the recommended range).
2006 Forester - wobble at 19-20 mph with FWD fuse in
forester2002s replied to subaru86's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXMy first thought is the rear drive-shaft (prop-shaft) bearings. But these usually cause vibrations when transmitting torque, for instance when accelerating in AWD. Same goes for the wheel bearings and half-shaft bearings. So it is unlikely that you'd feel any vibrations in FWD, with no torque to the rear end. So that leaves the rear-diff. I wonder if the rubber mounting-bushings on the rear-diff are failing. With no torque on the rear-end (when in FWD), perhaps the rear-diff can move around a bit, and this may be felt as a 'vibration'. I dunno, this is just my best guess.
Tach and speedometer stopped working (intermittently) yesterday
forester2002s replied to mickytrus's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXFlakey ignition-switch?
2003 Legacy Outback vibration between 32 and 40MPH
forester2002s replied to biggman100's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXSounds to me like the rear drive-shaft, even though you've said that you have checked it. They are difficult to check by hand, but can you get a crowbar on it to see if it's loose?
EJ22 30 PSI on all four cylinders HELP
Low compression reading? And same reading on all four cylinders? I would suspect a problem with the compression gage itself.
no start weirdness a month after front end impact
forester2002s replied to 89Ru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXCould be lack of fuel? Either low tank level, or something else related to fuel?
Project 1990 Legacy Wagon No Crank
You shouldn't need a heavy-gauge wire to energize the solenoid. 16ga would work. And we're only talking about a few seconds anyway.
