Dr. RX
Everything posted by Dr. RX
  1. Looks like some bad little boy couldn't wait until Christmas morning.
  2. Since I taught the other Corky everything he knows (and then he goes and writes a book and gets money for my ideas), I can't believe what I'm reading here. Skip and Tex are on the right track. The wategate regulates the amount of boost being created by the turbo, if you are set at 11 psi and the wastegates starts to open at 2200 rpm (which I doubt), then that is where the turbo is creating more then 11 psi boost. If you choose to close of the wastegate, be prepared to detenate your engine. When the wastegate opens, it is just releasing the extra exhaust, not needed to create the desired boost, you will still be producing 11 psi, if not, then there is something else wrong. If you are wastegating at 2200 rpm, then that is where you have acheived maximum boost, most people I know would be happy acheiving max boost that early. In my WRX, max boost doesn't occur until somehwere around 6000 rpm, the turbo starts boosting at around 4000 rpm (and you'd better be hanging on when it does).
  3. Oh if only that were true. When I did the EJ20G conversion into an 87 RX, we discovered that the EA82T fuel pump just wasn't up to the task of getting the engine running properly. Now granted, the EJ20G is a different engine then the EJ22, with higher fuel demands, but you can't go wrong with getting a high performance fuel injected type pump to begin with, you certainly are not going to flood the floats.
  4. I believe that is a setting on your computer for opening pictures. On my computer, if I put the cursor over the picture, a tool will show up in the lower right hand corner that will allow me to expand it.
  5. It must be the area, I had a motorcycle stolen in Las Vegas, it was chained to the trailer. They cut the chain and stole the bike in broad daylight. The bike was never recovered.
  6. The decoder is great, but here is a link to the data that it was created from. http://www.corkysrocks.net/images/VIN.bmp . By the way, the link on the decoder is wrong, it should be a .net instead of a .com, I had some trouble with my web host a last year and had to change it.
  7. Well by this time next week I should be in Sisters, visiting my sister (and no I don't have a brother in Brothers, Oregon). I'm only planning to be there Sunday, Monday and heading back on Tuesday. Maybe some of the Central Oregon people can meet me for lunch on Monday like last year. Let me know, either PM or e-mail me. I'll be driving the Impreza down.
  8. The first picture is the way it was delivered from Subaru, the second picture is how it was prepped for the movie. The lighting is terrible, the photos were taken with a cheap camera, but it are the same car. The color of the car is dark brown, not black or grey. The film used was daylight film, and those shot were indoors under florescent lights, ask any photographer, they will tell you that combination will not give you true colors. Quattro San is the car the Jackie Chan drove in the movie 'Cannonball II'. If I remember correctly (and Freak can check the dataplate) Quattro San is a 1980 Hatchback. The photos are about two weeks apart.
  9. Note sure they were an option on the 93, if they were they would have been on the LSi, I believe the bumper was similar up to 96, and I know the 96 LSi had them.
  10. OK, here are the pictures, http://www.corkysrocks.net/quatrosan1.jpg http://www.corkysrocks.net/quatrosan2.jpg http://www.corkysrocks.net/quatrosan3.jpg http://www.corkysrocks.net/quatrosan4.jpg http://www.corkysrocks.net/quatrosan5.jpg http://www.corkysrocks.net/quatrosan6.jpg The first two are of the early days just before the movie, the rest are from two years ago. The pictures from Freaks post are newer.
  11. The car is owned by Western Washington University, since it was not officially imported into the USA, it can not legally be purchased or licensed. The car is in fair condition having been store outside for many years. I have some pictures that I'll put on my web site then post links here later. You can see for yourself what the car looks like (but the pictures were taken two years ago).
  12. That very same car is now parked in a holding area at Western Washington University in Bellingham. I have a verbal agreement that after I get my garage built that I can store it at my place.
  13. The Legacy was introduced to the world in 89, but not offically to the US until 90, I'm wondering if this might have been a Canadian import. PS: Ed I never get tired of your updates.
  14. I could have sworn that the 84 Turbos were EA81Ts, and being such would not have HLAs (hydraulic lash adjusters), but they would have hydraulic lifters. The HLAs are on OHC, not OHV engines.
  15. I know the feeling, when I finished my WRX (260hp), I drove it a few times before I took it to get inspected, getting back into abd driving my 86 GL-10 4WD Turbo Sedan after driving that car just wasn't the same.
  16. Just a hint, in the USA, we don't use kilometers.
  17. OK, I'll convert that into USA specs ( ), timing belt every 60,000 miles or 4 years. I change oil and filter every 3,000 mile, but you can change the filter every other oil change. The tranny and diff fluid changes are probably about right, but most people that I know of, have never changed either. The coolant is also about right, if you change it every other year you should be alright.
  18. I believe it has something to do with the venturi effect. The intake manifold will always product a vacuum as long as air is passing through it, all the turbo does is back more air into the same space, there is still a vacuum created. Try this, place a tube into a bucket of water, now blow air across the opening at a 90 degree angle, if done right, you will suck water out of the pucket, that will happen because of the vacuum you are creating by the air passing over the opening.
  19. The answer to your question is, yes Subaru has a factory manual for you car, the problem is that from 93 to 99 they created a series of binders, with volumn 1 & 2 being the 93 model year, each volumn after that was updates and changes between model years, so to get a 96 FSM (Factory Service Manaul), you would need volumns 1, 2, 3, and 4 (there wasn't a volumn for 94) to have a 96 model year set. I have a complete set, volumn 1 thru 13, but do not wish to break up the set, the complete set, all 13 volumns is $325 plus shipping. Because of the size and weight of these books, I would expect the shipping to be somewhere around $50 (just a guess).
  20. If the reason that you are doing head work is because of a blown gasket, and overheating, my recommendation is to use new bolts.
  21. You might check, but that last time I did, CenterForce did not make a clutch for a cable pull type clutch on an Impreza. I have one in my WRX, but that is a hydraulic type clutch. For me, CenterForce makes the best clutches around.
  22. Your are fortunate to live in Florida, www.CVAxles.com is in Florida and those are the people that I recommend for axles.
