Everything posted by DerFahrer
Need Help!!!!
Wow, a GenI owner that says his car hauls rump roast. That's encouraging . I'm still a carburetor n00b, but I would think if you stomp on the pedal and the car stumbles, that there isn't enough fuel coming in to meet the new volume of air coming in. I won't say anything definitive though, the veterans can tell you.
leone video
That is now on my Myspace
EJ22 vs. EJ22E vs. EJ22G, Any Difference?
DerFahrer replied to 91LegLS's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXEJ22 = just the first 4-digits EJ22E = all USDM N/A 2.2-liter engines from 90-96 EJ22EZ = all USDM 2.2-liter engines from 97-98 (9.7:1 CR, solid lifters, single-port exhaust, but still Phase I) EJ222/EJ223 = USDM 2.2-liter engines from 99-01 (same stuff as EZ, but Phase II) There's some weirdness in the transition from E to EZ in 96, as some 96 2.2 owners report having solid lifters and single-port exhaust. EJ22T = 91-94 USDM Legacy Turbo engine EJ22G = Impreza 22B engine EJ22T is NOT the same as EJ22G, despite what the Nasioc clowns tell you.
ej18s... how well were they built?
DerFahrer replied to 75subie's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXEJ18's are as well built as the EJ22's they're based off of (as far as the shortblock, EVERYTHING is the same except the bore). Hope to be turboing one here in the next 8-9 months, the one I have has 230k on it and has nothing wrong other than oil leaks. It will have more power than your EA81, but not THAT much. It has 110hp stock.
has any 1 put an 5 spd into an 1400 coupe
What's different between an EA71 bellhousing and an EA63 bellhousing?
JDM EJ22 for EJ25 Swap Questions
DerFahrer replied to sportsfan1026's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI was going to say something about this. Unfortunately, we have a lot of assclowns (especially on eBay) who either are flat-out lying that the engines they have are JDM, or are just stupid and assume every engine they have out of a Japanese car is automatically JDM. Regardless, I've never heard of any EJ22 in Japan except the EJ22G that was in the 22B.
Carburated Turbo?
They were
where can you get subaru shop manuals ?
DerFahrer replied to bmac_1277's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXBelieve it or not, service manuals are still available brand-new from the dealer for both of your cars, yes, even the 91. The 91 manuals are in short supply, but still available. If you want, PM me and I'll give you the part numbers. Of course, I understand if you don't want to spend $300 for a set of brand-new manuals. In that case... keep a close watch on eBay
FF-1 / Ford corsair
Wow, that does look pretty close, at least in the front. But I feel confident saying that the two are entirely unrelated. The body shape is too different. And of course, the engine is different.
OEM key set?
DerFahrer replied to ShakotanBoogie's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIs the key you have an original key? Do you see a number cast into your key, right below the head? If so, that's your keycode. All you'd have to do is take it to a dealer or locksmith and tell them to cut a key for that code. If it's not an original key, any dealer can look up your keycode with a VIN. If I wanted to get in HUGE trouble (and I don't) I could have you PM me your VIN number and I could look up your keycode right now, as we speak
harmonic balancer
On OHC EA engines (so just EA82s), the flywheel is the harmonic balancer, not the crank pulley.
2007 Baja
DerFahrer replied to Bo13mwz's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXAt first, I heard the Baja was gonna be dead for 06, but now I'm 99% sure it's dead for 07. It is based on the last-generation Legacy, after all.
SOA givin' props to the Bi-Drive
Thank you for that actually. Someone tried to tell me that the ST-X had a 3.0L four, called the EJ30. Thanks to that, I can prove them wrong
Gallery : 73 Subaru Splitgate
*scratching head* What is replacing this Bryan? I don't remember you buying any other Soobs. Unless you bought that blue 76, I can't remember.
Unusual starter problem EJ22
DerFahrer replied to 91LegLS's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXHaha, reminds me of the time I was working at a Toyota dealer, and used Toyota starter contacts to rebuild the white 93 Legacy wagon's starter. Too bad it was the solenoid going bad and not the contacts (starter still clicked afterwards). It's a simple explanation: Subaru uses NipponDenso starters, and so does Toyota :-\
Electronic Throttle in 2006 Outback
DerFahrer replied to RonP's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThe drive-by-wire throttle does simpify the car quite a bit, in all honesty. It eliminates the ENTIRE cruise control system. Cruise control is completely computer-controlled and integrated into the drive-by-wire setup. That's a lot of weight savings. It also eliminates the need for the fancy idle control systems of yore. No IAC valves, etc. It's all controlled by the drive-by-wire.
Synthetic Manual Transmission Oil ?? GL4 vs GL5
DerFahrer replied to rweddy's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI've learned a lot about this type of stuff since that posting. It appears I had the diff and gear oils mixed up, as the regular Redline 75W90 belongs in the transmission because it has friction modifiers for the synchros, and the Redline 75W90NS belongs in the diff, because it does not have friction modifiers, and they're not needed since there are no synchros in the diff. That said, I am running the GM Synchromesh and am very happy with the results. I was having a slight resistance engaging 3rd and 4th gear downshifting with the plain cheap dino oil I was using. That went away with the Synchromesh. And before anyone wonders about its compatibility with Subaru transmissions, my dealer keeps it in stock for use in Subaru transmissions to alleviate this very problem. We feel that confident about it.
Great ideas (stuff ive done/doing)
I wouldn't do the fabric personally, but I will definitely be using similar methods to restore my dash. That, and the condition of the front seats, is my main concern about the interior condition.
Need Help!!!!
The reason I said voltage regulator (the external ones anyway) is because they contain the fuel pump relay. If that voltage regulator is b0rk3d, then the fuel pump won't get juice. Shift, hotwire your fuel pump directly to the battery and see if that allows your car to run continuously.
Need Help!!!!
It sounds like you have the same problem I have. What's your system voltage? I'll bet that in all the electrical horror, you screwed your voltage regulator.
Kiwi subbie, have you seen this?
What I would do to have that car...
Specs Needed: WRX Flywheel vs EA82
You all know that EA82's harmonic balancers are their flywheels and not their crank pullies right?
What kind of motor is this?
It could be an EJ18.
I got a pretty nice 77 wagon the other day.
Okay, it makes sense now. Anyway, yes, back on-topic. Great score sucker king!
Latest Subbie
I want to make sweet, sweet love to your RX Have any pics of the twin-carb setup?
