Everything posted by Skip
My last attempt, I dug out section 6 of the 1986 FSM the wiring diagram shows (like the one above) For the driver's (left side) headlight Red/blue ---- hot (+12v) from the left side headlight fuse --------------This will show +12v anytime the ig switch is on --------------and the headlights are on (high or low beam) Red/white ---- high beam (shows a ground via the hi/low switch when --------------- in the "high" beam position) Red/black ---- (shows a ground via the hi/low switch when --------------- in the "low" beam position) If you wire terminal # 85 on your relay to the Red/blue wire and wire terminal # 86 on your relay to the Red/black wire then the relay will close (connecting relay terminals # 30 to # 87) when the low beam lights are on. [relay #30 gets a fused hot wire from the battery and # 87 goes to the light's positive side. The other wire from the lights goes to ground.] For the supplied switch (note: the light on it will not work do not connect the terminal that shows a ground symbol) Instead of wiring the red/black wire directly to the relay. Run a wire to the switch and from the switch to # 86 on the relay. You are most welcome, Good luck Skip -out
Opus, I run Hella 500's on five of my vehicles and am very framilar with "what comes in the box" (includ. a standard Bosch lighting relay) and how to wire them as you want. (Willy the above wagon has Hella 500s) The above diagram is from an 87 GL maybe your year is different. I will look through my FSMs and see if I can find one from an 86. You say "You have a ground, you have a battery connection, you have a switch and 1 wire that you need to tie into the low beam side of the lights." This method works for domestic cars that use a positive feed to the lamp that is lit, you do not have this system in a Subaru. I guess I'm not getting through to you. Wired the way you have will not hurt anything but will leave the Hellas on anytime the headlighs are on (high or low beam) and you have the switch in the on position. BUT You say this is not the case so your year must have different wiring. I will research this. Maybe Cougar will step in and help.
your plugs may be gas fouled try some other plugs and charge the battery
Opus, No worries, mate. I'm not attempting to be a wise arse but I have been through this a dozen times with guys on the board. Your test light is looking for +12 V. (assuming the clip lead is grounded) If you want to try a test. Turn the ignition on. Unplug both head lamps and try your test lamp. (As I said, I will assume one side of your test light is grounded) High/low will make no difference, you will see +12 v (light lites) on both the red/blue driver's side and on the red (pass side). Switch the stalk to the other beam and you will still see the same. As I explained obviously poorly, wire the coil wires of the relay across the red/blue and red / black wires. The relay will only close (aux lights on) when the low beams are selected. It will go open (aux lights off) when you have the high beams on. For the dash mounted control, I would run a pair of wires from the red/black side of the coil control. That way if it shorts to ground, it will not blow a fuse. I will draw up a wiring diagram and upload it if you request. But since you say "The way I have it now with the red/blue works for me" I'll just bow out and say congrats on a fine wiring job. Glad you figured it out. All 4 aux lights come on only with the high beams on this car.
Sorry please do not take this wrong but... Your car is either wired differently than the FSM drawing above, or You are not measuring for the correct signal. My guess is you were measuring for a hot feed (+12 V) and not the ground control wire as I tried to explain above. The wire that controls the lighting of the low beam filament is the red/black. It goes to ground when stalk is switched to the low beam. The red with blue is the hot feed for the driver's side lamp. It powers both the high and low beam on that side and comes from the fuse box. If you try to control your relay coil with that wire and a ground on the other side of the coil. Your aux lights will be on (relay closed) anytime the headlamps are on. NOT just when your low beams are on. (This would also be the case if you used a parking lite) As I said the ground is what controls which filament lights. I have wired many sets of lights to be controlled by the hi/lo beam stalk (normally I wire a set driving lights to come on with the high beams) IMHO the best way to do this (but I feel you will have your own) is to wire the relay control coil to the two wires that work the filament you want to use for control. One wire from the relay coil to the Red/black and the other wire to the red/blue. The main contact for the relay that will power the aux lights, gets a fused hot feed from the battery + For ingress into the interior there is a rubber plug located below the power brake booster that is seldom used. Hard to reach but is there. I doubt this will help - sorry I tried. I could email you a wiring diagram if you want.
Glen my sincere apologies my friend. I dug out another coil bracket and this one HAS screws holding the power transistor on just like you said it would. Once removed (see picture below) it is a conventional power transistor case, just as you said. Sorry, I thought I had seen some rivoted
from this diagram it looks like you want the Red with a black tracer wire. You do know these are NOT controled like lights in a domestic car ? Meaning on these cars, the beam you want lit gets a ground from the switch and the center or common is powered from the fuse via a relay. Each side having it's own relay. Hope this helps.
Glen, the ig amp case is rivoted to the bracket, not held there by screws. The wiring comes from the car to the ig amp from the amp to the coil. as seen here I'll dig one out and get a better shot
You do not mention what you plan on using them on. I hope you cheked that they are all Gen II wheels. Hard to tell from the picts but Gen I's will not fit on the front of a Gen II car. Hope you got center caps and the plastic fit rings?
my pleasure folks (glad to read that JoAnne, my Willy kinda went into retirement) hope it helps Wildhair and he gets back to us no matter what the outcome.
Whose got the Wickedest Ea82
Skip replied to The Dude Abides's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Here is Willy, since been retired and is still for sale. -
loyale likes to throw CEL codes
Skip replied to saetern's topic in Old Gen.: 80's GL/DL/XT/Loyales...
For values and location of the sensor, Please take a look at this post http://www.ultimatesubaru.org/forum/showthread.php?t=83667&highlight=resistance+chart -
As Heartless correctly called it the unit under the coil on the bracket is the ignition amplifier Some people incorrectly refer to this as an ignitor (I have even seen this in print) but in reality an ignitor is found inside some (not this model) distributors. It sends a pulse to ignition related components. On the other hand, the ignition amplifier receives a signal from the ECU - amplifies it and sends it to the coil. It is nothing more than a power transistor. Thus Hearthless's warning about the bracket grounding, as the ground is one of the "legs" of the transistor. They do go bad and or have wiring issues on rare occasions. As Cougar says the best test is a replacement. The distributor in this model is called a Crank Angle Sensor (CAS). The "guts" are pictured below. Hope this helps.
As Cougar says The CTS or it's wiring is bad. I'd vote for a bad CTS. No fuel system spec'd so I'll guess SPFI On the gooseneck (upper rad hose to engine connection) there is a sensor with two wires leading to a plug. This is the CTS, it tells the ECU the engine temp and the ECU adjusts the mixture accordingly. The backfire you feel is a lean mixture from the ECU not knowing the engine temp. You can measure it's resistance vs temp if you are friendly with a multimeter. Hope this helps -
pull the plastic cover down that is above you knees when driving find the black connectors (two single wire -one male one female) by the ECU Plug them together, turn the key to run (do not start the engine) watch the small round hole on the end of the ECU facing you and read the codes. Note this hole and it's LED is what is called the O2 monitor see this site - do not be fooled by the opening line about OBD II The site is for OBD I like you have. http://www.troublecodes.net/Subaru/ hope this helps
This part of the original post is disturbing "can hear the starter sproket spring out under the hood but it doesnt turn over." You may have a stripped gear on the flywheel/flex plate. The starter engages enough to rotate it slightly, next time it bites the remaining teeth. If this is the case the situation will deteriorate. Remember the engine only stops at four places (when one of the pistons is on comp) I'd pull the starter and have a look see at the teeth on the flex plate/flywheel.
I have a question why are the pictures dated 11/30/2006 If she just bought it? Maybe they are the original "For Sale" pictures?? Keep the height stock and add only factory assc. to it. Should be worth 10 k$ in a few years.
PGH Scoob. First a Legacy or OB gets about the same fuel mileage and are far more comfortable. I will vouch for Davebugs. I live close to him and have seen many of the cars he sells. HE IS ANAL!! "Come on Dave - the buyer is not going to mind two types of lug nuts!!" He will not sell you a car until it is driven and proved worthy. Trust him, he'll set you up. Gary will treat you right also, he has been around Subies for a long time and is a very trusted member here.
You welcome and much thanks for the update. Nice to read guys getting their rides fixed and how they did it.
Here's mine with a short vid of it in action Thanks to Scott of Subarubrat.com fame click link for video http://www.subarubrat.com/PICS/carlisleskip.MPG
As a folow up It occured to me that I had an EA82T distributor laying on a work bench. I took the cover off of the sensor ring and found there appears to be two sets of slots one inner with four large slots and then the outer what look like 360 slots (one per degree) So it is possible that your CAS is having issues with the pulses coming from the four inner slots. I appologize for the mis information. The only test I know of, barring the use of an occiliscope is to try a know working model.
The CAS in a 89 EA82T distributor controls not only the fuel pump via the ECU but it also controls the spark. From your post it does have spark. Therefore I would say the CAS and the ignition amplifier are working. Have you verrified the pump is running when the key is in the crank to start position?
how to adjust EA82t idle...
Skip replied to ()__1337_CRAYOLA__()>'s topic in Old Gen.: 80's GL/DL/XT/Loyales...
my WAG is the line from the IAC is split or cracked at one end causing a vacuum leak. Have a look at it while you check for the coolant leak. Nobody you know messed with the throttle stop scew - eh?
