Everything posted by Skip
"You could rule out electreical by just unplugging the harne for the trans and going for a drive. The trans should function by hydraulic pressure alone at that point." I would be interested in seeing if this is a fact or a guess. How do solenoids open and close with no electrical input? Is there an over ride function (pilot pressure or line pressure??) that forces them open/closed? Maybe G knows it better, I know I don't.
Nice of you to offer Jon but I don't want to broadcast my address. I'm sure you will get many replys. Happy Holly Daze to you and thanks for doing what you do for us Suby nutz. Great having vendors like you aboard!!
Since this is an electronic tranny, I say it would be a waste to right it off for a TCU or it's inputs problem. Guess you will find out when you swap the tranny. Why not wire just one LED to the second gear shift solenoid, if it lights and does not shift.. well nuff said. I am absolutly sure you and Nipper will hash it out.
brand new REBUILT starter. Sometimes when you try to start the car, you hear the click of the starter solinoid engaging, but the starter doens't spin. I've cleaned all the connections and was still having a problem. last time I had a nuetral safety switch problem there was no clicking as Keith says some rebuilds are not as good as others but.. the test outlined in the post will show if the ignition switch contacts are to blame. If so the relay is a much easier fix than changing the ignition switch. Congrats on the hitchin' enjoy your Vayca.
Trouble shooting help sought
Skip replied to GeezerTrainee's topic in Old Gen.: 80's GL/DL/XT/Loyales...
this sounds like a fuel starvation issue I believe this car has two fuel filters, the one under the hood is called a vapor separator. The other one is under the car by the fuel pump. This one is the first line of defense (some call second due to the fuel pick up sock in the tank) I'd try changing those as a first step. -
"..i'm sure it's complicated....???" I built the tranny shift solenoid monitor used cuurently in one of my 4EATs Seen here in detail 4EAT monitor Yes the shift algorithm is complicated it could be your line pressure is falling and thus no shift from first. You might try wiring a similar device to watch the output from the TCU. This would narrow down the problem to the tranny or the TCU. One guess is the line pressure is not making the trip when warm. The TPS may also have the idle switch stuck on this may prevent the TCU from letting it shift. As it could be either the tranny not shifting or the TCU not telling it to shift, I would try and narrow it down to which is at fault. Doesn't the XT6 have some switch on the console to keep it in the lower gears?
Well used alt are not that expensive nor are rebuilts. The "needing water" could have been caused by the alternators internal voltage regulator going haywire. This can cause an over charging situation which boils the H20. After time the overcharging causes the diodes to go bad. Best to get the alt checked before throwing parts at it. You could have warped plates in the battery now also. This condition shorts out cells and well ...battery time.
Shifter lock out
Skip replied to Gloyale's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
under the shifter console (part that has the PRND21 on it) kind of a pain as the entire center console needs lifted, you will have to push the unlock pin to get this part out. -
"I guess I'm asking if anyone agrees that its the battery and not the alternator, or something worse." I for one do not agree. The battery may be toast now but your description leads me to think that half the output diodes in the alt are toast. Thus with the headlights and no doubt heater fan on, the alt can not make enough juice to support the load and recharge the bat. Have the alt output tested and make sure the cables other ends connections are clean. Whats a 2KOBW ??
Welcome aboard the good ship USMB. You say "Hmmm. any advice?" Yes, before throwing parts at it. Break out the multimeter and test the resistance of the EGR solenoid coils. Should be ~ 35 ohms, if the meter shows infinity, then put into the search box "parts supplier" 1stsubaru.com is one of the more mentioned places Sure hope this helps.
This entire post is getting nowhere. Silver, please post a new thread linking to the web site for your car. I am sure many people will want to see it. If you would be so kind as to include the appraised value it would be most appreciated.
I was wondering which system he meant also? The pressure type - tank with gauge - pressurizes the master cyl. Open an bleeder -> out comes the fluid. I like the vacuum type (Mity Vac or my home made system) Sucks the fluid through the system. If you use the brake pedal to bleed them, listen to the Roosters method. Do not push the brake pedal to the floor. The bottom part of the MC may have crud that gets dragged up onto the seals. My EZ bleed -vacuum pump and vacuum flask.
no tranny type mentioned but if it is an auto the vacuum modulator (pass side low) will do this when the diaphram ruptures. Pull the line to it off -> ATF is seen thats the problem. (sugg you start a new post if this isn't the answer)
Thanks for the reference AZ but THE Dude does not tell us what car/engine/fuel system he has. The picture I posted is for an EA82T A.K.A. MPFI fuel system. If Ben means his DL-- it will have SPFI. The temp sensor in the SPFI will be the pig tailed sensor in the goose neck, they arely have contact problems as the contacts are enclosed/sealed in the connector. People corn-fuse (sic) the connector problem. The MPFI unit sits back and burried in the heat / jungle, the connector cap heat cracks and water gets in. This is what leads to the problem.
