Everything posted by simple monkey
it looks like you can modify ford escort struts. http://subarujusty.proboards20.com/index.cgi?board=suspensionmod&action=display&thread=1073294331 http://subarujusty.proboards20.com/index.cgi?board=suspensionmod&action=display&thread=1113789693 and apparently the oem struts are very expensive. i think you should go to a yard and size up different struts, many older cars can use suspension from cars with a bigger aftermarket. for example, my brother's corolla uses camaro and mr2 struts. what ever you decide to, be sure to document it. you won't be the last to ask these questions. good luck in your findings.
Blow thru Maf setup??? Anybody
simple monkey replied to 2K4 STI's topic in Old Gen.: 80's GL/DL/XT/Loyales...
what are your plans exactly? as far as running a BOV to the Atmosphere, i have had no issues with mine, doesn't run rich between shifts or long off throttle periods. try the blow thru setup and document whether you needed to tune it. be a pioneer. -
dont a lot of people do this when they have a GT30or GT35? even tho you wouldn't need to make huge adjustments, it would still be wise to re-tune. -
thats probably the best wheel fitment i've ever seen on an older soob. keep up the good work.
so what strut did you end up using in the rear?
fuel injector questions
simple monkey replied to simple monkey's topic in Old Gen.: 80's GL/DL/XT/Loyales...
these volvo ones i'm interested in are high impedence. i'm assuming we have low impedence injectors, correct? when used on the N/A volvos, they require 4 x 10ohm resistors wired into the AFM. has anyone ever tried this before? glcraigGT, thanks for the response. i'm glad you brought up the impedence values early tho, might have forgotten about that........ -
I'm finally looking into upgrading my injectors, but i have a few questions. I've searched and searched, and the 280zx turbo injectors seem to be a good candidate. But, there are none in the local yards, and injectors seem hard to come by. So, as an alternative, i've found that stock volvo injectors come in 2 sizes: 357= the bosch 357 injectors that came stock in the 84-89 b230ft motor 29lb/hr (300cc/min) @ 3bar 804= the bosch 804 injectors that came stock in the 90+ b230ft rated 30lb/hr(310cc/min) @ 3 bar i plan on using an S-AFC or e-manage to tune the bigger injectors, but is there anything else i should have to look out for?
I hate vac lines! help please!
simple monkey replied to Tosh's topic in Old Gen.: 80's GL/DL/XT/Loyales...
the line coming out of the compressor housing is just fine routed into the wastegate. as long as there is no leak in that hose, it will be fine and will allow the regulated amount of boost from the wastegate (8psi i think?) i run the same thing on my stock turbo. for a line running into the BOV, any vac line will work; i run a T from the same line as the fuel pressure regulator which is right on the intake mani. O. on mine points straight at the ground, no ill affects yet. my factory serivce manual says the vac line for B. goes straight from the brake booster to the engine, does not need a T. but i would feel better if someone confirmed that. F. and G. appear to be the same vaccum nipples on the non-spider manifold, but not sure where those go. wire S. could be a ground since it is black? thats all i got, my fsm doesn't cover the spider manifold. hope that helped some. -
heavy, heavier, and too long. RB26DETT is an inline 6 and cross-breeding is not normally cool, especially with a nissan.
you can run the ground control coilovers on the stock shocks or kyb replacements. the spring diameter is 2.5" which is the same as the rear springs anyway, so you just need to find a tophat for the rear. the front is the same way except you can use your stock tophats. i still have the stock shocks with ground contols on my car, they came from a wrx and they were $50 on ebay. i read a couple posts a while back saying the ebay coilovers weren't that bad.
i've never had problems with the BOV and police. i've actually had one case where the cop liked the sound. how is venting it to the atmosphere rice?
i now run the stock wrx bov to the atmosphere. much better throttle response then recirced back into the intake or running compressor surge. it doesn't run rich either and gets about the same gas mileage.
the stock bypass hose out of a wrx goes in the right direction, but it needs to be extended a little bit and have a 90* elbow. mine looks like this, it went from my 02 WRX TMIC into the "duct B" in the intake snorkel (the cup thing). here's a close up: 0. wrx bypass hose 1. 3/4" PCV pipe, not sure on length 2. 3/4" to 1" pcv coupler 3. 1" to 1 1/2" 90* elbow.
bypass valves and blow off valves add no performance what so ever. they simply vent excess air into the atmosphere or back into the intake.
MSD Blaster 2 install ?
simple monkey replied to SmashedGlass's topic in Old Gen.: 80's GL/DL/XT/Loyales...
i would suggest getting the MSD .8 ohm resistor as opposed to any other brand. the MSD one fits perfectly on the MSD coil, where as the other ballast resistor i ended up getting took some custom chaos. -
FRANKENSTEIN EJ motor time... w/Compression ratio calc enclosed.
simple monkey replied to s'ko's topic in Subaru Retrofitting
ej22 heads on the ej25 block would yield 11.5:1, and would be a much better set up. the ej25 block will starve for air with the ej18 heads. ej22 heads have much bigger ports and bigger combustion chambers for better performance. if you plan on keeping the ej18 heads, i would suggest putting an ej22 shortblock in there. there are a couple people on nasioc.com who have tried it and liked the results. also, isn't the bore of the ej25 too large for the ej18 heads to fit? i know some of the coolant passages dont match up as well. good luck on the build. -
My RX has made some speed!
simple monkey replied to WJM's topic in Old Gen.: 80's GL/DL/XT/Loyales...
what water injection kit are you using? or are you DIY-ing one? -
if i remember correctly, the ej18 intake manifold will not bolt up to the ej22 heads. so, you might need the intake and exhaust manifolds for the ej22. also, i've seen a couple cases where the new engine will be sluggish and not rev as high. so, rallitek makes a piggy-back for running the ej25 on the ej22 or ej18 wiring + ECU, it will probably work in your application at well.
you don't exactly need to do the wire mesh thing. a ways down the road, this will keep pine-needles out of your ducts and such, but a rodent can still chew thru the mesh. it would just be wise to close all the flaps, like the one that leads to the heater core (i had a mouse in mine along with a pound of bird seeds). urban legen- rodents don't like the smell of oleander (a plant). i bought some (don't remember where) and put it in the mole holes outside. no more mole problems. not sure if it works for rats/mice tho. hope that helps.
i would go with the soch ej25 heads. they flow better, and if you want that bump in compression, you can do it 2 ways: 1. cometic head gasket. 2. mill the heads.
project supercharged xt-6
simple monkey replied to supercharged-xt6's topic in Old Gen.: 80's GL/DL/XT/Loyales...
that hood-lump looks like it was drawn with a t-square, just like the rest of the car. looks amazing. -
it would only be neutered if you put an inline engine in it. well done, is there a reason why you decided on an NA ej25 though? which tranny are you using? curious as i am looking at an ej swap for myself soon enough......
