Everything posted by xoomer
xt6 reseal
Ok, So I took A break from my legacy Project this weekend... I went to work on my XT6 cause its my daily driver and I was loosing about a quart a day.... it was leaking like a sieve And I think I took care of it I drove from Burien to bellevue and it didn't loose any oil and I didn't see any drops on the ground after I pressure washed it... you know the usual Cam Crank and Mickey... thanks to Auburn Subaru for $22 bucks out the door... Now I found I need to do a new axle on one side Darn
Journey of a T-leg picture show 56k warning June 3rd
xoomer replied to xoomer's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXLittle more work done on this thing.... but first A random Sword picture... (its one of my dads trophies, He's letting me smuggle them one at a time down from CA) and I finally got it hung up. My Heads Drivers Side Assembly Head bolts, The assembly process really I don't like which was torque to 27 foot pounds. then too 55 foot pounds then back it off 180 Degrees, then to like 38 foot pounds... Then turn it 90 degrees more... Valve Cover. Bottom End Reassembly. Water pump and Oil pump, I like the o.E. Water pump gasket... Its METAL!! I used grey RTV a reallly fine bead all the way around the Oil pump.. Top of The Driver Side... Rear Plate.. (watch the videos at the end..) I may be needing a new FlyWheel... My Patented Flywheel Locking tool.. (i'll Sell it to you for $10 bucks) Videos Of me working....
xoomer replied to xoomer's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXAs long as she starts when I'm done, then it is full of win... if she doesnt than this thread is full of Fail
xoomer replied to xoomer's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThey came with the car, So I'm assuming there stock...
xoomer replied to xoomer's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYes it is... Otherwise I would not be rebuilding it...
xoomer replied to xoomer's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXGot a lot of work done on her today and found more work to do... Engine Cleaning Heads off Block cleaned up. Found in oil pan... As for this I figured out what piston it belongs to, can I just yank the piston? and put it back in?? Short Block
xoomer replied to xoomer's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXGot some work done today!!.. Engine tear down and clean up a little bit. Close up oil pan carnage! Left Engine Mount Right Engine Mount Whole Exhaust off... (I'm thinking to take the Metal protectors off and get some heat rap for the exhaust, Cause I would think that would keep it cooler? Dirt and Crap Now that is a neglected cooling system!! Ok, now my next step is to pull the CAM SPROCKETS off, do I need a special tool?
xoomer replied to xoomer's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXRight now there are no plans for power cause I'm struggling for cash to fix it. My goal is to get it running and driving, Make her my daily driver till I can get some work done to my sixes... and go from there... But yes, maybe bigger turbo, intercooler, blowoff valve, turbo timer... and such Eventually I'm slated for two raises this year... one for sure, the other one is my new boss is so impressed that he wants to give me a raise
xoomer replied to xoomer's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI'm getting new ones..... I'm also getting a new oil pan, along with alot of hoses, I'm gonna try my best to make this a new car!
xoomer replied to xoomer's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWhen I pulled the starter, I had access to the pressure plate bolts.:lol:
xoomer replied to xoomer's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXGot some work done on it today, Got the harmonic balancer off and the intake and the turbo.. lots of hoses are gonna need to be replaced... lots of cleaning to do... next time I'm over its gonna be pull the exhaust and oil pan, as well as the timing covers, to get it down to engine. then the heads are off to the shop to be machined magnafluxed and a valve job, I didn't take any pictures but my friend said he would email me some cause he came over to help a little bit...
xoomer replied to xoomer's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXGot to work on her some more today.... Engine coming out... Back of the Engine stand Front of the engine stand.. Whoops looks like I left something behind!! Whoops Forgot to unhook a couple of wires Found the cause of the overheating!! :shock: :shock: :shock: New Parts!! New Radiator
I thought I would chronicle the Journey of my 91 T-leg here and let you guys know what I'm up to... I'll start with some pictures from when I first got her... and to now... Any suggestions, comments, or offers of help more than welcome!! I purchased this thing for $100 dollars... Low Miles!! Drivers Side Passenger side Front Rear Engine This is After her First pressure wash bath.... She was sitting in a storage and was ugly as hell and because she was sitting at my moms house I had to clean her up... Interior Shots, Teardown and rebuild. (had to get the mold out and put in a new carpet.... New Carpet (junk yard Carpet cleaned up and put in) Interior mostly put back together, I haven't finished yet because I need to get the door lock fixed, and I want to get the shifter slop out of it. Back seat Now to the Engine... She is getting pulled... engine prep SHE WONT COME OUT!! We broke some stuff trying to get her out... need to get some new bits and pieces... Freaking engine mounts...
What should I NOT be doing with a subaru trans?
I want!
side and rear lights stay on
shhhh.... this is how we get these gen car's for cheap because of "electrical Problems"
just lit up my subaru
Kinda Reminds me of.. I miss her loud engine, no power and little heat..... She was a death trap on wheels I need to get a new one.
Duralast clutch
Chatter, is most likely gonna be oil on the clutch plate, sometimes from the rear main... possibly from the grease packed release bearing.
heater not hot enough :(
Yep actually I do. did that in my old xt6, last year... and that stuff is comming with me to my new xt6.... and I'm doing the same thing to my legacy as we speak
Duralast clutch
Well, I just sell Auto Parts, And have been doing so for many years. I'm not trying to start a flame war but every time I sell a ba clutch it comes back in a couple of weeks, And I'm not talking just about DIY'ers I'm talking my installers also... **Side note; When I sold parts for Dealerships. I also worked in the service department. 99% of the time when they replaced the clutch it was just the disk and throw out bearing unless the flywheel/pressure plate was bad. Any Crack less than an inch in the flywheel is fine, as that is normal wear. If you see a crack that is longer than an inch that is when it was machined. (I Worked for the Largest Honda Dealership this side of the Mississippi and unfortunately KIA also) and from my own experience, Over the last 15 years of back yard wrenching... I have only ever replaced one entire clutch kit. it was a Autozone clutch. it was slipping within a week. I pulled it apart, took some brake clean and a dremel, and cleaned up the flywheel put the old SOA pressure plate. And just put a new disk in... and 20k later not a single bit of chatter, noise, or problems. My total lesson learned.... Subaru's have it easy. I can have a new clutch in the car and back on the road with in 4 hours. so if you have a little bit of time and very little money this is the simplest way to go....
Just get a 54mm 220 Degree thermostat... that should raise the temp of your heat inside the car.... as well as the temp of your engine Just enough that it might blow a head gasket. What I'm saying is that you may have a problem such as a bad water pump, a clogged radiator/heater core. and/or a partially functioning Thermostat. Don't ************ around. Get it fixed Flushing it just runs the risk of pushing the clog into the engine and clogging it... the coolant passages get pretty small.... Or do What I do... Everytime I get a questionable car... I replace the entire cooling system.
throdle is sticking
Also the Cable could be bad, As well your pedal could be frozen... don't ask me... I replace the cable in my car still did it... finally realized that it took a while for the spring on the pedal to bring it back to the top... so I soaked that in a Silicone lubricant and have not had a problem since.
Duralast clutch
Duralast=Crap ValueCraft=Crap, When I worked for Autozone There were probably over 100 warranty's a day. Beck Arnley = $$$ Same thing as ValueCraft (same Manufacturer) Fenco Decent. out of all of them I would go to the Dealership and see if replacement parts are available... and replace only what you need. Most likely only the throw out bearing and the disk. and just clean up the Pressure plate and the flywheel as long as they are not Massively cracked. My .02
Got Turbo Sedan?
88 Chev Cheyanne 1500 with a 305 It's an old Fleet truck thats for sure.... 640k on the ticker, it was a les schwab truck then it was some other company and now its mine.. it was kinda funny cause the head light switch died that night..... Just as it was getting dark..... I had to pull the switch and jumper it.
Got Turbo Sedan?
My next question is will an ER27 engine fit?
Got Turbo Sedan?
Blue Devil is a snake oil type product for Fixing and repairing headgaskets. (its guaranteed or your money back) and you can get it at your local Checker/Schucks/Kragen you take your t-stat out, drain the antifreeze, put water in and then you put the blue devil in, and idle for 50 minutes. -- When I started the car was spitting coolant out the reservoir after running for only a few minutes. I ran it for 50 minutes and i noticed the idle getting smoother, the heat getting hotter, and it never got over 195 at idle sitting and when I shut it off there was no bubbling in the reservoir, Tomorrow I'm gonna Flush it again, and run the blue devil again.... then I will put a t-stat in it along with new plugs and find all the vacuum leaks, hey it was a free car and if nothing else Its looking like I have a parts XT6, Hmmm, can anyone say XT6GL105lugSedanliftkit?
