Everything posted by xoomer
Brat topper...
I am Picking up a Brat topper this week and wondering how you attach them to the bed? I don't want to drill anything... how do you do it?
83 Brat Heat questions.
Ok, So I have been doing this round about with my Brat on heat first it was this then it was that now its this.. I have heat now! on the passenger side:-\ And warm to body temp air on the passenger side. have checked the Flapper for the outside air and that gave me heat finally. I had to pull the Heater control valve because it was leaking. But I have another one, my friend says put it in and it will slow the flow of the coolant in the heater core so that I have good heat.. I'm a bit hesitant to put it back in. I was thinking I should replace core. then put it in. I'm slowly putting this together. But I would like to be able to check off the Electrical, and start working on the interior, like new carpet and getting the seats cleaned up.. as well as working on rust so I can put my new doors on. Anyone Got suggestions?
'83 Brat - same PN for both front bearing seals?
O'Reilly's Part number is 207 for the branded box, 207br For the master pro.
Brat Stuff I need to do... ??
Picked up front and rear Brakes today.. As I have a grinding noise, I'm hoping that rotors/drums are not to bad. although I do have a wheel bearing issue I have to figure out... only during turns do I hear the grind of the bearing... so I'll figure it out tomorrow when I do brakes.
Ok, A list of things that I need to do. And Parts that I'm going to need.. I need brakes on all four corners Axles in the front. New exhaust. Heater core Carpet pulled and new carpet. Rust Removal Lots of other things. Any Ideas?
Brat Rebuild. Now with Photo's
More work done.. Still no heat but I think I figured it out.... I'm pulling the dash back out.. I think the heat actuator cable is loose...
Ok Enough Hijack... Anyone got a Tilt wheel ignition Switch? Let me know how 1.0 is...
Evangelion rules my world too... Amazon had them..
soon as I'm confident the brat is a good rig... she is going up for sale... Got to try to get some money back out of her... some of my toys have to sacrifice new ownership... As for the dash rip out... I needed to pull out the PO ************ wiring. also to install shiney no crack dashboard...
Pictures.. Well, So far Me and a friend have put a new (rebuilt EA81) a fresh radiator, and and a shiney mismatched dash... Here is some pictures...
88 Wagon, title, Wa state... totaled question...
Actually it Can... They fought me on it at the licensing agency, so I went to the Actual DOL, and they said it was fine as long as you can prove that no money was exchanged. I.E. Written Notarized statements, Or both persons present. There should be no Reason that you could give a friend a car, And then that person gives it back to you. no tax either way... and if they say you must, Argue. (long story But goes to my very argumentative and anti Government days. Oh Wait I'm still in that faze.)
Ok, So as some of you know I traded a XT6 to Sti-wolf for a lifted wagon that was in Less than stellar condition, I then had a friend who knew someone who needed a runner and a driver, he had a brat with a blown head gasket. We made the trade. I towed the brat home. I found an engine, got it swapped in. thanks to a fellow board member. have not really tested it out yet as I also needed a radiator, and several other things. but a friend of mine who cruises Aarons auto wrecking, found a Perfect Dash, with all the switches and everything I need plus a radiator.... So with a now empty savings account I have a brat that will hopefully be great after a day or two more work. Engine $200 Trip to get engine $100 Engine mounts and exhaust manifold gaskets I didn't need $68 dollars. Long story, We went searching when the old ones were broken-- didn't bother to look on the new engine. DAMN!! $150 at Aarons for a perfect dashpad lots of other misc parts. (thanks Sean and Tom) I will get awesome pictures and stuff this coming week...
Look What Followed Me home!!
It might... but Compression numbers and leak down show ok numbers.
- Look What Followed Me home!!
huh??- Look What Followed Me home!!
Thing is its not milk shaked. Oil is a nice Brown color, Smells like oil. And seems to be ok. the only Milkshake is in the Air Cleaner... that's it, Thats why I'm confused,- Look What Followed Me home!!
So what are the chances that this is a Intake Gasket issue? or should I not even waste my time?- Look What Followed Me home!!
(unfortunately) The tree run has been postponed for me this year.. But, This is definitely a clean rig. Compared to the Wagon, she has some rust... but nothing too bad... and at least she has the Jump Seats...- Look What Followed Me home!!
and all it cost me was a lifted wagon... Previous owner said Blown Head gasket, But she starts right up, and no Milkshake.... Except in the Air Cleaner. and then the passenger side Intake Manifold gasket looks blown... so I'm thinking that might be the problem... (I don't want to do Head Gaskets but will if I have too.)- Online parts soiurce? '84 brake parts
GD, I had a 1980 with vented rotors.... it confused me cause the cat said and the shelf said non vented... I think a few might have made it in prior to that cutoff.- A question for the EA81 guys out there
ok.. Im gonna make sure that the coolant leaks are gone.. and try to figure out what is making the battery drain down... then I'll talk to the guy..- A question for the EA81 guys out there
The dilemma I have currently is the guy just wants something that could last him a couple of months, Currently I have put a fresh oil pump and tightened up a few things, gonna go through the coolant leaks next... and then off to the races... it seems to be running good specially after oil change and plugs today... still lacking power though... retimed it again today so hopefully that will get something done... I just don't want to trade him and then something major goes wrong with the wagon... it seems solid but slightly scared...- A question for the EA81 guys out there
Some one has offered in trade to me for my lifted wagon.... an 83 Brat with a blown head gasket, I'm not much into doing head gaskets and wondering how hard/Easy it is to rebuild, I tore into an EA81 a few years ago and it seems easy enough... the only thing that scares me is the pushrods I know trading my wagon for a brat in any condition should be a no brainer but to go from a decent running car to a potential new engine car is not something I really want to do... Suggestions advice or any other ideas?- Kia Sephia Sporty
Kia's are excellent cars. You take care of them and the will take care of you... No Im not saying that because I worked for a kia dealership.- The tally thus far..... '96 Legacy FROM HELL
xoomer replied to GeneralDisorder's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXnot even gonna get started. - Look What Followed Me home!!
