1 Lucky Texan
  1. I understand there is risk - just tryoing to get some data points on quantifying it. heading to CoSpgs this weekend - hoses are 13 years old, but only 80K miles. is there a decent little kit to take in the car that might repair a pinhole leak or ? something I could grab at O'Reilly ?
  2. crank position sensor can be intermittent with temp. Many old soobs have run with holes in the filler neck - just throws a p0440 or w'ever code. how hot is it getting though with no radiator hooked up? when it fails to start - will squirting starter fluid or brak cleaner into the intake make it fire? maybe it's a fuel problem. also, try starting with the gas pedal held to the floor - that is the clear flood procedure for flooded engine.
  3. When did you guys experience your radiator/heater hose failures? Will those hoses last 15 years? 20 ? my wife's car is only at about 80K miles, but the hoses are 13 years old!
  4. when you say "reset the belt" - why are you doing that? does it shift off-time?, maybe the tensioner is weak/destroyed. any CEL codes? scan and maybe a pending code will have some information. when it fails to start - does it crank? crank, and 'sputter'/try to fire?, crank and 'nothing'? maybe there is debris on the crank position sensor or the sensor is intermittent?
  5. the ecu compares crank and cam sensor pulses and can definitely cut operation if they are 'too far' out-of-sync. Bet it will work after you get the timing system sorted.
  6. did you 'feel' any jerking/bucking? do some tight circles on flat dry pavement. Car should idle-or just above idle- thru with no binding or jerking. if the car is an automatic, try driving with the FWD fuse in place. try swapping tire front to back. are the axle boots split?
  7. since we seem to be into the odd stuff now - you might scan for pending codes. clear the ECU, try to start, scan again for what code comes back.
  8. hmmm---if you cycle the key from OFF, to ON a few times, the fuel pump should run for a coupla seconds and fully pressurize the rails. Dot that cycle 4-5 times, then got to START. see if there's any difference. If it's better, maybe, for some weird coincidental reason, there is a fuel issue. did all the gross oil-gunk get cleaned off the plug wire boots? maybe losing some high voltage energy with arcing in there. if you think the system is flooded - try starting with your foot holding the gas pedal on the floor while cranking (don't pump) When the pedal is on the floor AND starting are detected by the ECU - it switches to a 'clear flood' mode and shuts-off the injectors. (but, I'd have expected a fuel smell from the tail pipe if it was flooded?)
  9. check that big hose from the IACV - easy to miss connecting it under the intake. possible timing - never use the the arrow/triangle - use the dashed line on the tab at the back of the crank sprocket. If one of those tabs was broken off - car won't start either.
  10. find the tooth count for your engine. Belt marks won't line-up again for 300 revolutions or w'ever - really crazy. even on a new install, I did not solely trust the belt marks, I did a tooth count also.
  11. are you beginning to get cool/damp mornings ? bad plug wires could be an issue - they arc when wet, then dry-out. (but, not sure if the 2.0 has coil-on-plug ?) could be oil in the plug tubes I guess?
  12. I think you said, when it begins, it's repetitive? if so, is it in sync with tire rotation, or faster? Could be some carrier bearing or u-joint problem i guess. you feel no jerking or binding when maneuvering or parking in parking lots? maybe after it happens, you could measure hub temps with an infrared thermometer - if a bearing is failing in an odd way, that hub may be hotter than its mate.
  13. post your city in a new thread asking for a mechanic - maybe someone can suggest a shop that will track down the noise. If you can duplicate the sound for a mechanic on a test drive, that will help. a common source for banging is the sway bar and its link/mounts. They can also be broken and will catch and pop. Plenty of other sources of noise of course, even springs can be broken in odd ways.
  14. I just remebered a trick I used decades ago, call 4-5-6 used car lots, maybe include a subaru trade-in lot. pretend to be an insurance adjuster and you are trying to find-out some values because you need to total-out a wrecked RS. see what numbers come up.
  15. you could keep the struts and replace the mounts if they are cracked or the bearings squeaking - honestly, many cars are driving on worn-out struts all the time. and, if you are short on money to maintain this car, where does the money come from to buy another car and begin repairing it?
  16. brakes are common wear item for all cars. knock sensors are $10 from ebay axles are a common repair for most cars too - not horribly expensive to replace or re-boot O2 sensors can be a little pricey - but, some codes for that are just an exhaust leak - some welding could be all that's needed get a new one, keep this one too! (man, I wish I could get it)
  17. what kind of work does it need? you should get it fixed and keep it.
  18. I'd spray some starter fluid or similar into the intake to see if it fires - that should help with questions about fuel. make certain the crank position sensor is undamaged and plugged in. any CEL codes?
  19. no - I doubt you're an idiot - but I can tell you whoever approved the iconography on our 03's stalk was, it clearly indicates washer-squirting with a pull of the stalk, but all you get is a quick mist-wipe. the ONLY way to get front washing is the button on the end. I THINK I've seen a thread about modifying the swith's little pc board to alter the function. Not worth the trouble to me.
  20. get new KYB - I just don't think junkyard struts would be much better than the ones you have - I suppose if you found some with less than 50-75K miles, maybe..... you can scribe the position of the adjustment bolt and get camber back close enough. do a search - you can find DIY stuff here and over at subaruoutback.org , as well as some youtube videos (users ericthecarguy and briansmobile often have Subaru videos that are good). check parts prices at Amazon, RockAuto, etc.
