1 Lucky Texan
  1. yeah, ecu could have had the car in limp mode. That feels like dead turbo. But I'd expect the CEL would be on. otherwise - what ^^^ they all said.
  2. probably need to pick up a new axle nut. Hope that's all there is wrong, but you probably need to have a back-up plan, The axle probably has some type of warranty. personally, I've had zero problems with the EMPI axle I put on the wife's car. $10-$15 more than a rebuilt - but new. supposedly, dealerships have rebuilds that are QCed/cherry picked to a higher standard. MWE has soob rebuilds and is highly respected. If it becomes really confusing what the source of the vibration is - try swapping axles left-to-right.
  3. one other thing, did you torque the axle nut with the weight of the car on the tire? It's recommended to torque the axle with the hub in the air. back-up the rotor with a big screwdriver in the 'vanes' and against the caliper. but many people have complained about vibration from rebuilt axles as GG mentioned.
  4. did the d'stick's tube get bent during the swap? this seems very odd.
  5. I think there are no Lexus in Japan, that line was created for US marketing reasons. Maybe Infiniti too? I've often thought Subaru should do something similar - break out the 'Legacy' plate as a separate, 'upscale' line(Tribeca, Outbacks - and maybe a 'luxury' Forester and BRZ?) as a sorta Lexus-type maneuver. Run the name 'Subaru' for the Crosstrek, WRX/STI, maybe a downscale Forester and the other Imprezas. Then, bring over the R1s or design some FWD/Electric/maybe hybrid subcompacts and name them 'Fuji' (to compete with the Scion - type line of vehicles). the reason, so I've read, that the Lexus line was created, was so folks didn't feel 'cheated' paying 35K for "a little Toyota". Japanese cars had the reputation of being small and cheap. Nobody wants to feel they paid Rolex money for a Timex watch. There could have been a vehicle brought over from Japan or Europe with Toyota badges, or someone might have re-badged their Scion.
  6. I just saw that commercial. It doesn't mention Toyota, and 'maybe' it's saying it's the first boxer with that special injection/ D4S and direct injection tech. w'ever. I'm not sure though - there's a LONG pause between the different statements.
  7. pretty sure the timing mark will put the pistons at about half travel. Maybe someone else will chime it but, by ensuring no piston is at TDC, if a cam slips - there should be no interference.
  8. cool, what's ideAL and what's 'trouble' when you do this?
  9. I'm also wondering about things like a sticking valve or even carbon buildup. just odd thoughts though. so many things can go wrong - or 'drift' in a bad direction on older cars. I'm glad there are folks like Ivan and other mechanics around and I give them plenty of respect. I don't think I'd like to repair other people's cars on a regular basis - I can hardly understand what I'm doing on my own cars.
  10. exhaust leaks? retarded timing from bad knock sensor? engine temp sensor? I bet it's maddening trying to track down all the possible causes.
  11. just reporting what I saw at the KYB website - wish it did list RX for ya - but it doesn't. maybe email them?
  12. turns out that a Forester part 'may' work but, the STi or Legacy or other non-'lifted' soobs won't be compatible. It's like the Forry and the OB cone from the factory with a slight body lift and the housing for that bushing is shaped differently to keep the steering geometry correct. So, buying a replacement for $80-$85 or rebuilding for about half that seem to be the best options. Pricey little unit. If a 2 piece, 70 durometer polyurethane bushing could be found, and if you can cut out the sleeve for the old bushing insert, rebuilding might be a decent option.
  13. I've bought brushes before - many years ago - at the car parts place. Wonder if they could match-up some new ones for ya. good detective work.
  14. I'll just set my wrench on 60lbs and torque it 3 times. anyone have insight on the fitment issue?
  15. and that crosses to 341216 at KYB And usage for that number is listed as ; 85-89 DL, GL, GL-10 and 90-93 Loyale.
  16. that's weird - might be fun to dig into them but, they're 10 years old - unless you got lucky and there was a very clear, obvious problem that could easily and reliably be repaired, I think you'd be better off with replacements. has this car ever been wrecked? maybe those aren't the original fans.
  17. just thinking about harley/big v-twin chains and belts. don't some experimental aircraft use chain reduction for the props? sounds like a wild project!
  18. yeah, even in the middle of winter, you can still do outdoor 'stuff'. hope it works out for ya!
  19. ah - so the instructions in the Whiteline document to leave the connections loose, drop the car onto it's wheels - bounce it a coupla times - then torque things down, would likely replace the alignment marking routine?
  20. link in edited previous post indicates 4.25 . It still may depend on which transmission - one with the 'remote' filter vs filter on the side, maybe ambient temps, condition of old fluid, etc.
  21. edit - see; http://www.subaruoutback.org/forums/99-do-yourself-illustrated-guides/5843-changing-automatic-transmission-fluid-easy.html
