somthing different
supercharger !?!?!? tell us more
OBDII question
laws. rules, training. They're going 'by the book' and sticking with year model, instead of looking on an emissions sticker to test it. Basically, the law probably says " 1996 and up " - instead of - " all OBDII ". unless you're saying the truck was also a '95 then, I have no idea - maybe call the DOT or w'ever agency runs the testing?
Rear differential operation 4eat
Well, some folks say that after about 60-80k miles or so, the rear VLSD is worn out. Likely it depends on other factors like how often the car is on low-traction surfaces etc. Basically, the rear lsd wears out. Dunno why it would behave in an asymmetric manner though.
2003 EJ25 Subaru Outback AWD Wagon
tell him to search for either a CAI (cold air intake) or 'short ram' intake. boxer4racing probably has some legacy/outback specific stuff. He won't see any difference except in noise under the hood.
hmmm, I can tell you on my wife's 03 H6 with weather package, the right rear will spin the left in the same direction (LSD). however, I'm not sure I've tried it the other way. I will try it in April when I plan to do some maintenance. But, I'm not really sure I understand your question. Also, can you be more specific about the vehicle and what direction you expect the wheels to turn? Someone else here may already know how to answer your question.
OBDII question
I didn't see Subaru listed as an exception at the scangauge compatibilty page. Does your car's emission sticker have OBDII printed on it? Did your car perhaps originate in Canada? Maybe re-post your question with a thread title like 'Scangauge Users' and see if anyone has help for you. Or email Scangauge. http://www.scangauge.com/category/support/faqs/compatibility-faq/ http://www.scangauge.com/support/compatibility/after-1996/
OBDII question
If it's OBDII, should be good to go. There were some very cheap code readers from ebay or Harbor Freight that folks had trouble with. They wouldn't read the ISO protocol used by Subaru. But that was a long time ago I read about that. If it doesn't read, you might be able to read the OBD I system with a blink code and the black (or green?) connectors. http://www.ultimatesubaru.org/forum/showpost.php?p=428662&postcount=9 http://www.ultimatesubaru.org/forum/showthread.php?t=81497&highlight=black+connectors
OBDII question
I'm pretty sure OBDII allows for 'some' manufacturer specific codes, but most will be 'universal'. And, there are 4 (IIRC) 'protocols' for communication. The emissions sticker - usually on the underside of the hood?, should have OBDII printed on it if that's the system installed. might look similar to; what codes are you getting or are you having problems reading the codes?
Any reason to get OEM timing belt stuff?
I think, instead of driving to the dealership tomorrow, he'd drive to NAPA instead.
gotcha - you could price the same part numbers from on-line dealers (like subarugenuineparts) and ask if your dealership will match prices. I got a couple of items from my dealership that way. they matched one price and 'almost' matched another. good luck!
good post - pretty much how I feel. I'm saving money with my own labor, so I upgrade where possible, but never downgrade.
first, is that quote from your local dealership? Some online sources would probably be cheaper - like subarugenuineparts, maybe fredbeans, etc. generaldisorder and some other experts here seem to have a good source on ebay. maybe they will chime in.
Unusual 4x140 Wheel?
LOL! now I think of it, I've been to Moscow Texas!
Removing battery terminals
1 Lucky Texan replied to 1-3-2-4's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXno experience with that but, any questionable connections might create a problem for the car audio - or an alternator going bad. Even cut traces on the hatch window defroster has been reported as making radio static.
your english is excellent.
1 Lucky Texan replied to 1-3-2-4's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXAs I do different things on my cars, I always retighten grounds when I see them. I dunno if I'd take the time to hunt them all down unless I was having problems related to them. If I lived in wetter/salted roads parts of the country, I'd probably retighten them and then smear dielectric grease on them.
1 Lucky Texan replied to 1-3-2-4's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXlook on the sheet metal right beside the battery.
1 Lucky Texan replied to 1-3-2-4's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIf there's enough slack (unlikely) you can cut the old term. off, strip back some insulation, and put the new term. on. Otherwise, you may need to buy the entire cable from a dealer. If it is old (4-7-10 years?) it likely has corrosion creeping down the strands inside the insulation anyway so, a new cable is better that what you have now.
cough cough after engine turned off
maybe pull plugs to see if one is wet?
A/C clutch? I dunno
around here, batteries last an average of about 3 years. I don't have an Optima, but for about the same money as Autozone's top of the line, I got O'Reilly's supreme/super start w'ever battery (I think it's made by DEKA ?) which is some kinda advanced technology (AGM with silver ?) and a true zero maintenance. There is no way to add or check the electrolyte. (And less corrosion on top so far) Very long replacement and pro-rate warranty too. So far, it's been fine. Other folks that are into motorsports want lightweight batteries. And, as mentioned some folks might have high-demand accessories. So, there could be good reasons to 'upgrade' for some folks.
Monroe vs KYB shocks
1 Lucky Texan replied to blinkytoo's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIf yours are worn out, expect ANY new struts to feel tight/stiff. I just put KYB on my wife's outback last fall, no regrets. You might consider new strut mounts too. Inspect the boots, I just moved mine over, but if they are torn you may need to order some.
03 H6 engine free wheels/no compression
1 Lucky Texan replied to notnowles's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYou could try the old test for stuck exhaust valve, hold a strip of paper at the tailpipe while cranking. If it 'sucks in' then there may be some bad valve timing. Another thought, (carefully) take the hose loose at the fuel filter and see if there's pressure. There is an odd failure to some fuel pumps on this model. maybe just no fuel is being sent to the injectors.
2005 outback rack and pinion question
1 Lucky Texan replied to gritle's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXthere are posts on this and other subaru forums too. But an 05 is unfamiliar to me, but any PS system sucking in air will have a problem. Again, monitor the PS fluid tank. I had to remove the intake runner - 2 bolts, to get a good eye on mine. It was bubbling and foaming. After I fixed it with an o-ring from Ace Hardware, it just showed a little flow, no more bubbles. I also, used a small hose attached to a acheap turkey baster to replace much of the fluid with the owner's manual recommended fluid as the old fluid was quite dark and I assumed contaminated with moisture from the suction leak. Quite and working fine now. Of course, you could have a completely different problem.
'95 legacy runs hot, heater doesn't work
1 Lucky Texan replied to JohnK's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXany t'stat other than from the dealer is suspect. Stant Xacstat might be OK but I don't think there's been a lot of feedback on those yet. There's another brand out there too that seems like a direct replacement. Certainly, typical small aftermarket t'stats are known problems. Also, the system is prone to holding air pockets. Some people even recommend parking with the nose up on a curb to help move air out of (burp) the system. There are several ways to proceed. Are you losing fluid or is the overflow bottle filling up? Are there bubbles in the coolant? Seems like your radiator fans are working OK, but doublecheck them. Is the coolant clean and clear? has the system been well maintained?
