105
Evidently, these pulleys have bearings that fail prematurely. My wife has heard squealing a few times and this weekend, I plan to change the bearings in the idler and tensioner pulleys when I change the serpentine belt. I just haven't found any torque values for re-installing the pulleys. thanx for any help.
The wife has complained of a squealing noise on startup - intermittently - in her 03 OBW 3.0 . Naturally, it hasn't made a peep when I drive it. On another forum, I discovered her car is supposedly prone to having bad serpentine belt idler and tensioner pulley bearings. I bought new bearings from NAPA and a new belt and will probably swap those out soon. anyone here done that? is there a link to pics or a video? Mostly, just wondering if tapping the new bearings in will be adequate. I plan to put the bearings in the freezer, maybe warm the pulleys up. I may look for some Locktite threadlocker or similar to put on the outer race of the new bearings before assembly. thoughts?
yeah, stupid comment from me. but, that episode is kinda fun - basically about a bunch of trading back and forth and a guy gets stuck with these bolts his nephew bought just because they were cheap or something...until the very end and someone needs them badly and it works out OK. maybe it was in the next episode or... I really don't recall the specifics....just never forgot the 'self-sealing stem bolt' phrase. Sounds like they might actually work! lol! http://www.youtube.com/watch?v=jfqeUq7sZPI
I like the seats in my wife's 03 OBW. I REALLY like the seats in my 06 WRX wgn. Some folks may not as getting in/out over the thigh bolsters is odd. Plus, non-removable headrest. But they are comfy and 'sporty'. (careful if you get some at the junkyard - there's an airbag built in the side I think.)
wife's 03 H6 OBW had a leaking rear strut. It also has had a split inner boot up front so, I decided to install all 4 sttruts and half-axle. It went OK though, I was quite slow - doing it over 4 days with 3-4 interruptions. Also, after doing the rear struts with handtools, I bought an electric impact before doing the front so, NEW TOOL! WOOT! used info from here (also, added some pics and comments); http://www.subaruoutback.org/forums/81-wheels-tires-brakes-suspension/36263-2003-w-h6-baja-springs-kyb-struts-done.html
wonder what's wrong with the present engine? Anyway - same generation so, maybe not too many differences. DO check/change the bearing on the tensioner and idler pulleys for the serpentine belt. If the engine that's out has ANY hint of needing plugs or valve cover gaskets - do that before installation. And don't cheap out - platinum or iridium plugs.
I recently installed Redline Lightweight Shockproof (synth.) in all the differentials and 5MT in my 03 Outback (4eat) and my 06 WRX wagon. The front diff in my wife's Outback seems noticeably quieter. It was always a little noisy - noticeable mostly at highway speeds. At first, I didn't notice any difference in my WRX manual, but now I think it is not working too well. probably TOO slippery for good synchro operation. I may try to find an additive or swap it out at my next service interval in April. I'd like to run a synthetic, but I don't want to sacrifice synchro operation!
ea81 burns through alternators
1 Lucky Texan replied to brumby420's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Sometimes, a poor ground can cause alt./charging problems. Mkae certain there a good physical grounds from the alt, engine, frame/fender, etc. to the battery and everywhere really. -
08 STI wiper blades on my 06 WRX wagon
1 Lucky Texan replied to 1 Lucky Texan's topic in Subaru Retrofitting
DOH! Hmmm....I'll work on it. a few pics located in this discussion; http://www.subaruforester.org/vbulletin/f94/09-forester-aero-wipers-35097/ -
Despite being different lengths, they fit and work without interference. They have a very nice 'aero' look to them. small thing I know - just FYI Carl
I'm not sure you're missing anything - be interesting to see if one side has slipped valve timing. You could try holding a small stip of paper to the tail pipe. If it tries to 'suck in' that could mean a valve is open when it shouldn't be. I dunno if that trick works if timing is off by just 1 or 2 teeth though. Maybe there is a fuel pressure/delivery problem?
Diesel!
1 Lucky Texan replied to Olnick's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
http://jalopnik.com/5058493/subaru-boxer-diesel-unveiled-for-forester-impreza-and-legacy-in-paris
