105
directional tyres running wrong direction
1 Lucky Texan replied to Steptoe's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Oh, if it isn't a viscous unit then I retract what I said. I admit to being ignorant about the construction of the older soobs. sry -
I like Discount Tire, if you have one nearby, you could discuss your needs with them, ask what seems to be popular on Subarus in your area, discuss your budget, expectations, whether you switch to snow tires or not, etc. always had good customer service from DT. Everyone in a DT store started by slinging tires in the bay - they strictly promote from within.
AWD (viscous center diff or, in the auto, wet clutch-pack) really needs the tires to have the same 'rolling radius' (Subaru says, 1/4" in circumference) so, even though the size may be listed as the same, more than 2 or 3/32" or so in radius can introduce driveline stress if one 'end' of the car is rolling fatser than the other. if you have open diffs at each end, you can run the pairs on opposite corners, or run the pairs on the same side as their mates and the open diffs will save the center diff. some folks have taken the car to a large empty road/parking lot, marked the tires at 6 o'clock with chalk, roll straight forward for 10/20 revolutions of one tire, then compare each corner's offset from the other tires. do some calculations and you can determine if the tires are in spec. but offroad or on wet roads, wouldn't matter as you said. a true lock or unlock F or 4 wd center diff wouldn't care in FWD mode. -
I wasn't sure so, thanx -
It's OK to mix tire models like that on your car? No torque bind? -
What the f#&k is in my cylinder?
1 Lucky Texan replied to Gramr's topic in Old Gen.: 80's GL/DL/XT/Loyales...
weird -
if you were to rev in N, is there a point at which it would start missing? some older soobs would have crank pos. sensors that would get intermittent at temp....I've also seen at least one post where cleaning debris from a cps helped it! any association with rain/dew/moisture? how old are the plug wires?
not a code monkey, just a long-time tech. Used to work from masters but now almost everything is file-picked off the server(some Customer stuff is on cflash masters). We mostly just build hardware, but we customize bioses and have some code for customers they want loaded so their equip can just be pulled from the shelf so, we keep a lot of their stuff to burn. Plus generic stuff like romdos, dr dos, windows CE, linux....etc. I work at "a long-time embedded computer manufacturer located 'near' Arlington TX" so, the fob's pass code will reside in that part and the other chip will enabled when there's a match from the latest signal? seems odd that it seems 'erased'. I may have spotted a post that said it was possible, but I would have thought old codes would just be overwritten with the newest???
ah, that's why the number seems weird to me, never messed with serial mem stuff. 4001 and similar, yeah. Mostly now, I help out the girls downstairs since the Data I/O 2300 promaster's DIP head doesn't work. Just PALs though, ep320, PEEL18cv8, ATV750s , etc. Using a BP Mico 1610. maybe it isn't used for code, just temporary data?
the 2 items I got from subaruonlineparts were priced well BEFORE the discount code i got from here; https://www.subaruoutback.org/forums/121-subaruonlineparts-com/501795-new-lower-pricing-subaru-gear-codes-vip-s.html I've also used fredbeansparts and subarugenuineparts in the past - along with amazon and ebay
on a 95 - the rubber could crack 'at any moment' just get new mounts for both sides - the other side's bearing is likely dry and crunchy too. many folks get KYB mounts. don't over torque those 3 little nuts, theire spec is very low - 4-5 ftlbs or something (check with a better source than my memory!) Be sure the top spacer (conical washer) has its narrow side up. It is supposed to only touch the inner race. Sometimes when folks assemble the strut assemblies it gets flipped. That will cause dragging. squeaking and maybe pulling too.
I assumed you must have tried this many times which is why I wondered if this could be an issue just with the chirp feedback part of the circuit. There must be a parallel trigger to the horn relay or parallel relay. I could def. see a less-than-smooth lock cylinder being tricky - maybe even needing to hold some pressure on the steering wheel so that 'steering' lock doesn't interfere? I have only needed to program remotes twice on my 03. I was lucky and don't recall much drama. If I keep the car, the next remote may not be so easy.....
I should have said remote locking system - evidently, customers felt the horns were too loud and they added another horn on beginning with some later model. Joe has probably successfully programmed many remotes. so, if the horn chirped on the 11th or 12th cycle, or the 9th, what would you do? maybe you could get some contact cleaner on the ignition switch? I'm not arguing the design, as you say, there could be excessive contact bounce or a ratty signal that's rejected by some input filtering..... you seem quite frustrated and it seems I haven't been very helpful so, your bench approach will likely be the best approach for you.
If you have never heard this system work, it occurs to me, suppose the horn chirp is silent due to a problem? maybe you HAVE been in program mode but never heard the chirp? On my 03, there's a separate horn for the remote lock system (not sure on a 99 - at some point they switched from the car's horn to a dedicated sec. horn) but, if the actual sec. horn is bad, or, some relay from the sec. system to the car's horn is bad - you wouldn't hear the chirp. maybe try to test the security horn if so equipped. Or, find a schematic for how the sec. system chirps the car's horn and find a way to check that circuitry. Could just be a bad ground wire or relay somewhere.
Air bubbles in radiator
1 Lucky Texan replied to scorpiankill's topic in Old Gen.: 80's GL/DL/XT/Loyales...
you could try a chemical 'block test' or send a coolant sample to a lab for analysis. sure seems like a HG internal leak though.
