Help ID'ing Plug on Forester- Got it.- Thanks!
EDIT: well, not really, but I got the engine installed and started it up - No CELs, so hoping/guessing it was 'extra'..
Hi,
1998 Forester - 5-speed.
I'm reinstalling the engine and failed to label the plug circled below. I can't find its mate (it might be unused). It's on the 5-speed's bellhousing near where the 3 big, main plugs connect.
Thanks,
TD
Edited by wtdash
First guess due to location and contacts is probably O2 sensor. And the ohter end fell down by the Y-pipe and you don't see it.
Unfortunately, it's not the O2 as that plug is more oval and I'm very familiar w/it (due to changing it multiple times on previous Subies).
But I appreciate the reply.
Edit: It's more a triangle shape. :-)
Edited by wtdash
O2 was my first guess. O2 sensors look different on different subaru's, there are various 1 to 5 wire styles. Sounds like you're sure so I can't think of what it is. I just did a 99 EJ swap and there's nothing in that area electrical that I disconnected.
Sort of looks like the master cylinder plug but that's the wrong side. How many wires does it have?
Did you check everything non-engine related - like cruise control - a/c components, etc back there? Maybe it was a connection that wasn't necessary to unplug for removal?
Or put it all back together and see if it fires up? :lol:
Thanks all....it's 'none of the above'. But I appreciate the replies.
(The one empty plug is the 02, but I ID'd that one.)
There are 2 wires - 1 white and 1 black w/white stripe - going into the plug.
I'm going to just fire it up and see if I get a CEL...hopefully tomorrow.
Thanks,
Td
Edited by wtdash
Thanks,
Td
rear o2?
