September 22, 201312 yr 87 gl wagon 2 inch jaw lift on 27/8.50-14s mount on steel pugs! Edited September 22, 201312 yr by zte87
September 22, 201312 yr Got a set of 33/1400 tsl boger paddle tires for buggy step up from the 31 10.50s at least 2 inch more height and a lot wider
October 11, 201312 yr 1998 Impreza wagon Brighton. 2.2 4eat- 1998 Forester struts and springs (rears swapped with the original Impreza tophats)- 215/70/15 Goodyear snow tires - rear doglegs "adjusted" forward instead of swapping the trailing arm brackets - 10.5" clearance to the oilpan, 11" to the rear diff. - rear swaybar currently disconnected, front stock one in use
November 11, 201312 yr I'm thinking about buying some 15" pug alloys for my unlifted ea82 4wd, what size of tires will fit with no mod (if any)?
November 13, 201312 yr I'm thinking about buying some 15" pug alloys for my unlifted ea82 4wd, what size of tires will fit with no mod (if any)? Probably something like a 195/55/15 or 185/60/15. Even then those are around and inch taller assuming your stock tire is a 175/70/13
November 13, 201312 yr 1985 GL Wagon 4WD 6" JAW Lift (6" Suspension, 4" Body) 235/75/15 Maxxis Bighorn Tires 29x9.5x15" (Roughly) 15x7" Allied Daytona Wheels With 4.5" Backspacing 6 Lug Conversion
February 1, 201412 yr 1996 impreza outback chopped off muffler no sway bars no front or back bumpers abs delete no name off road lights outback trailing arm brackets 04 forester kyb struts and some off brand 185/65/14 snow tires This is my new baby I have big plans for her if i can find someone to dig up drawings and specs for a four or two inch lift pretty please lol
February 25, 201412 yr 2" SJR lift with 27x8.5R14 (General Grabber AT2) tires, 14" Pug steelies. No rubbing unless you're at the extremes of the suspension, but I've also hammered my front fenders quite a bit.
May 31, 201411 yr Sorry for not really adding anything to the thread but I got a offset/back spacing question for y'all. I just took my SJR lift kit off and am just on forester struts and I still have my 235s on. They stick out way to far for my liking. Wondering if anyone knows what a good backspacing would be for a little bit of poke. Right now over half the tire is past the fender. My wheel specs are 15 x7 3.75 backspace with 1" adapters. I want at most 1 inch of poke. There are some options on summit racing I just don't what what backspace to get
July 3, 201411 yr I am doing a 2" lift on my loyale and am looking at new tires but I can't figure out what will fit. Lots of people say they have 27" with no rub on a 2" and others say they have rub from 27" on a 3" lift. Why the difference? Offset? What would the ideal offset be? Or is it from saggy suspension?
August 13, 201411 yr No lift, yet :/ but i stuck some 195/75/14s on there with 14" pugs ! thanks turbone ! What kind of tires were these Skylar? I have the same pugs trying to run about the same size tires on my 88 GL.
January 5, 201511 yr 215/60/16 nitto snow on xt turbo wheels. boss 2 in in rear and imreza struts in front 1-1.25''?
April 15, 201511 yr 4" with 27/9.50r15 swamper radials 4 1/2" with new 215/75r15 hankook's I know I'm incredibly late, but I wanna say that brat is absolutely beautiful
May 12, 201510 yr Sorry for not really adding anything to the thread but I got a offset/back spacing question for y'all. I just took my SJR lift kit off and am just on forester struts and I still have my 235s on. They stick out way to far for my liking. Wondering if anyone knows what a good backspacing would be for a little bit of poke. Right now over half the tire is past the fender. My wheel specs are 15 x7 3.75 backspace with 1" adapters. I want at most 1 inch of poke. There are some options on summit racing I just don't what what backspace to get How high was your lift? And is it for sale?
November 9, 201510 yr Last pick no lift with factory adjustable coilovers Honda Accord coil springs in the rear 195/70R14 Middle pick same coilovers and tire wheels 2" SJR lift First pick 205/70R15 with a lot of rubing on mudflaps and plastic trim on corner of backdoors
November 9, 201510 yr 2" Boss lift, RX front springs, 2wd rear struts/springs, 14" pugeots steelies, 175×80×14. Is this RX still on the road if so please pm me I have ????'s I'd like to ask u about my 86 RX
November 10, 201510 yr I'm looking at lifting my 87 DL wagon but I dont know which one I want to do. I've looked up the lifting spacers and have been thinking of getting them, but also I've heard of using forester springs to give the car a lift too. which one do y'all think would be the best and cheapest to do. Another subject would be bigger wheels to get cheaper mud terrain tires. what wheel would i get? i know its a six lug but which ones work the best?
November 10, 201510 yr I'm looking at lifting my 87 DL wagon but I dont know which one I want to do. I've looked up the lifting spacers and have been thinking of getting them, but also I've heard of using forester springs to give the car a lift too. which one do y'all think would be the best and cheapest to do. Another subject would be bigger wheels to get cheaper mud terrain tires. what wheel would i get? i know its a six lug but which ones work the best? Forester springs or any ej style suspension won't work on your car. You're only option is lift blocks.
November 17, 201510 yr 235 70 16 Hankook dynapro all terrains on my 98 Forester with an Anderson Design and Fabrication Mammoth lift
November 24, 201510 yr I have got a 97 legacy outback and would love a 3'' lift. Does anyone know what years that Forester or Outback Struts and springs will comply with my ride
November 24, 201510 yr I have got a 97 legacy outback and would love a 3'' lift. Does anyone know what years that Forester or Outback Struts and springs will comply with my ride 98-08 Forester struts and 96-99 Outback struts will be a direct bolt in.
June 3, 20169 yr Just got a 96 legacy. Looking to do lift and tires but don't know the best direction to go in. I want to go big but not ridiculous. I saw someone say something about forester or outback struts and springs, how effective/easy is that swap to do? I've also seen lift spacers and king springs. Again just looking for advice.
