Retro GL-10 TURBO build
these are my new fuel and oil pressure sensors KAsensors and from just installing the oil pressure wow highly accurate
like to thank Franz @ Dieboldautosport for hooking me up with these bad boys !
  • Replies 479
  • Views 154.3k
  • Created
  • Last Reply
Top Posters In This Topic
Most Popular Posts
  • a company in the usa makes them out of fiber yours looks to be the same        so
  • well the manual rack wont fit... I lowered my motor so the sti 6mt would fit and am using the longer u joint any ways when the manual rack is there i would need even a longer u joint... i have a leone
  • my guys are so busy they made mine and told me its going to be a while.. but i have another way of doing this with out costing so much which you will see in the wagon build i have going on... got new
Posted Images
Well I guess I answered my own question, this is my spare one, with OE bushes in it, she's bent to buggery!
From an XT so its not like its hooked a boulder or something - definitely needs strengthening!
The 'added after MY series 'Stiffeners'' are a mere cosmetic joke!
Gonna have to put some flat bar top and bottom or something, make an I beam out of this thing...
And yes, according to part numbers, the XT6 one is different:
I wonder whats different? Gauge of the plate?
Notice that they all seem to be bent the same way, probably has something to do with the way diff is mounted & the amount of torque that is applied through it ... ;)
You might be chasing your tail a bit here though as you strength one bit, may have to compensate / strengthen in other areas as the load is transferred to things like the mounting points on chassis / floor ... :blink:
You can get 'open seam' round tube / pipe, roll / bend it to the required shape and then stitch weld it to top & bottom flanges ... :)
Not sure what size or how thick to get it though ... :(
Try here : http://catalog.johnsonrollforming.com/Asset/openseam_tubing.pdf
Add : Thinking about how the forces act on the bar, you'd want to increase the torsional stiffness at right angle to bar with an extension of your 'T' shaped beam, into a stronger overall triangulation shape - so something like this ( in Plan / Section ) :
                  | |        o ,
o------------[__]------------o                                                         |    o
  ````~~~~~~~~~~~~````                                                          o '
Bit rough, but you get the idea ... B)
P.S. : Other option is to just butt weld two together ... :ph34r:
Cheers, Bantum ...
Edited by Bantum
  • 1 month later...
  • 5 months later...
I guess I should update this build thread since new parts are being piled up for my Subaru Leone RX TURBO STi, as of now its in storage for winter but was building the Subaru Leone TURBO WRX NB-R Wagon version which can be found here --> http://forums.nasioc.com/forums/showthread.php?t=2687011
so I just ordered these EJ22T oil jets brand new from the dealership which if I remember right they couldn't be sold at the dealership which is a myth !.. also got the JDM STi quick steering sticker for my Leone.
out of japan I finally found one of these rare STi 6mt Short shifters which was a task and has the serial number right on it from STi factory.
Edited by Nico
Do you have the part number for those squirters? I've looked before, and I didn't see them listed in the catalog. But with a part number, they certainly might be available.
ill get it for you
another cool part from japan R180 STi finned rear diff cover, helps cool the rear diff fluid.
  • 4 weeks later...
  • 3 weeks later...
is that hood scoop from an old ford truck?? like a '55?
like this one?
so new season and new SUPER Rare rims for that 90s style square look, these a hard to find even pictures of them !
JDM 16x8 5x100 ET35 Tecnomagnesio ..MAGNESIUM..
aluminium caps with snap rings wow !
Made In Italy
off to the walnut blasting and ready for the gold paint job !
  • 2 months later...
Love the wheels.  I have similar looking wheels on my Legacy, but in a six spoke.  Speedline magnesium
  • 10 months later...
LOL
well i sold my legacy turbo as is so im just going to buy new stuff like a STi ver 8 for its heads, wires, 6MT, then swap the built ej22t block i built.
so parts list is
VER 8 Sti complete
Vi-PEC V88
EXEDY ?? dont know yet maybe multi plate to hold the power
SPARCO seats: maybe, kind of want it stock but need support lol
Rims: gc8 and volk jdm if i can find them
Tire's : RACE SLICK lol for evey day haha !!
new rotor pads that wont stop this much power to weight lol
my rear control arms, that me and my dad had to make a tool becuase no one on the plant has one lol
little thermal coat so then i can wrap them
got some tubes to make my wastegate pipes longer away from everything
How did you make the control arms? I am trying to do a 4 lug to 5 lug swap and I can't get any XT6 parts
or insta gram https://www.instagram.com/big_bad_wolf_xo/
Where did you order your body kit? Could you assist me with the rear end conversion from 4x140 to 5x100?
so been really slacking on updates but lets try and catch up
I add a new turbo the old version died from Anti lag fun lol, new borg warner s300sx-e has better oiling and updated cover
Edited by Nico
  • 1 month later...
  • 3 weeks later...
I also swapped out the turbo blanket for the PTP Turbo Blanket, so much better design and construction then the DEI ones that fall apart
I also swapped the Sparco Grid seat for a MOMO racing seat with higher bolsters to keep me snug while I'm on the track, the sparco grid is in my wagon version.
Edited by Nico
Edited by Nico
new tires, refreshed the paint on the Enkei ES tarmac 16x8j 5x100 et45
Edited by Nico
i add DBA 2 piece rotors for better stopping on the track, the stoptec ones cracked
I also add Forged Billet shifter forks, i was sick of the plastic tab suabru used for the stock STi 6MT transmission.
Edited by Nico
this is a short clip with all the new toys add.
https://www.instagram.com/p/BNVOHVkBY3a/
also add a FIA Rain light so people stay off my rump roast i hope lol.
https://www.instagram.com/p/BVvJYRPjDK7/
also got a super rare Nardi Torino Gara Sport 350mm flat bottom steering wheel from japan.
today i just got back my was silver Tecnomagnesio rims that have been properly striped and painted to the original Subaru 80's single stage paint my car came with
Edited by Nico
so one of two boxes from Europe just came in and wow i'm super pumped !! rare euro spec OEM Subaru parts !.. still going through the stuff but just put on these Ver1 Euro spec corner lights that pop out more then the JDM Ver
Edited by Nico
So awesome. I am glad you found our group on Facebook as well.
Edited by iluvdrt
  • 2 weeks later...
yeah i made a car page i didnt know there was that much activity on FB
more rare parts from japan ! my new PIAA Nakajima Racing wheels 16x8 5x100 ET38 made by RAYS or ENKEI 17lbs..
they have that T37 volk look but five star style to them which should make them pop on my square body once i sand blast and have them painted Subaru gold !
Edited by Nico
  • 1 year later...
1988 Subaru Leone GLX Turbo wagon all original  (120,000kms 74564 miles)
My 1992 Subaru Loyale has seen better days the Canadian winters has eaten the body away so ill be stripping it down and using what I need to build my 1988
NVAUTO wiring harness built from the JDM wiring for my car.. AVSC JDM NBR WRX open source OBD2 ECU... stock on stock on stock !!
NVauto JDM WRX NB-R V7 V8 V9 STi wiring harness all complete ready to be added in the mighty LEONE SUPER Wagon !
so here is my new ECU in place and super clean job from my buddy Nam at NVauto
