October 1, 201213 yr I have a 95 Legacy Outback Wagon 2.2L AWD. The stock tire size is 195x60x15. I put on 205x70x15. They rub in the rear. when I go around corners. Would a small lift or some coil overs do the trick? I'm taking it back to the tire place to get the right size tires on, but only if they will do it for free. Otherwise I'm going to upgrade the suspension if that is possible.
October 1, 201213 yr If YOU picked that tire size they aren't gonna change them for free. Best bet is just get some outback struts to put on it and get the clearance you need for the outback tire size.
October 1, 201213 yr if they told you there'd be no issues, you MIGHT get them swapped for free. where do they rub? It might be possible to run a few millimeters wheel spacer - but that could lead to fender rubbing (roll them?) and more stress on the wheel bearings.
October 1, 201213 yr Author They rub on the bottom of the spring. No where else. I was talking to a guy who would sell me these for 350$ http://passwordjdm.com/KSport-Kontrol-Pro-Damper-System-02-07-Subaru-Impreza-WRX--P4950C1901.aspx?UserID=65458421&SessionID=fLDIZ9Rv7Tm73O6DvZSn I have no idea if they will bolt to my car though. The thing is that coil overs are a lot thinner than my stock strut and spring, So i feel like that might solve the problem? It rubs a little on the inside of the rears too. Against the strut/spring.
October 1, 201213 yr Author Anywhere I can find 96-99 struts in good condition that are cheaper than those coil overs for 350?
October 1, 201213 yr Those coilovers wont directly bolt to your car. The rear strut tops have a slightly larger bolt pattern to them. You can slot the holes to make them fit. Otherwise I recommend going with a set of KYB GR-2/Excel-G struts. http://www.ebay.com/itm/KYB-GR-2-STRUTS-SUBARU-LEGACY-OUTBACK-1995-may-1998-/390384445113?pt=Motors_Car_Truck_Parts_Accessories&fits=Year%3A1997%7CMake%3ASubaru%7CModel%3ALegacy%7CSubmodel%3AOutback+Limited%7CEngine+-+Liter_Display%3A2.5L&hash=item5ae4b9e6b9&vxp=mtr Reuse your strut tops if they are still good.
October 3, 201213 yr Those coilovers wont directly bolt to your car. The rear strut tops have a slightly larger bolt pattern to them. No, they will fit exactly. It's the 90-94 Legos that have the smaller bolt pattern. At any rate, that's probably overkill. I would simply go to the junkyard and get a whole set off an Outback used.
October 10, 201213 yr No, they will fit exactly. It's the 90-94 Legos that have the smaller bolt pattern. At any rate, that's probably overkill. I would simply go to the junkyard and get a whole set off an Outback used. In the OP he stated his car IS an Outback, Jus' Sayin'
October 10, 201213 yr '95 is the the legacy w/the 'trim'; '96 got the body lift, suspension and 205/70R-15's. '95 PICS HERE. Edited October 10, 201213 yr by wtdash
October 10, 201213 yr '95 is the the legacy w/the 'trim'; '96 got the body lift, suspension and 205/70R-15's. '95 PICS HERE. Ohhhhhh. Learn something new every day. Must have been where the tire shop slipped also.
October 10, 201213 yr Must have been where the tire shop slipped also. Good point....I was wondering that too.....if the tire dealer 'sold the stock tire size' they didn't look up the year.... Td
October 13, 201213 yr Alright. Today I successfully put outback rims and 205/70-15 tires on many legacy l and I was wondering, since my stock tires were 185/60-14, how badly will my speedometer be affected and how hard will it be to correct???
October 13, 201213 yr According to one calculator site I use, your actual speed will be 15.7% faster than your speedometer reading. When speedo shows 60mph you'll be doing 69.4!!!
October 13, 201213 yr So I should get better fuel mileage too xD. The engine will be turning less rpm's while the speed is upped.
October 13, 201213 yr Theoretically, yes, but the engine also has to work harder to move the car now. So will use more fuel to do the same work as before. Also you have to figure the difference in the odometer reading, which will now show fewer miles than you actually traveled.
October 13, 201213 yr So I should get better fuel mileage too xD. The engine will be turning less rpm's while the speed is upped. That's the theory. But then the engine could be working outside it's "power vs efficiency" zone. You might be lucky and the engine will handle the required power fine and return you some good economy. But if you're cruising with the throttle open further than what you used to do with the stock sized tyres then you're using more fuel over all, even if your revs have dropped by 500rpm (big difference!) Cheers Bennie
October 13, 201213 yr Actually I did notice something interesting. You would think it shouldn't work this way, but I noticed my car moves along better and steers better with these tires. :/ Oh yeah. And what will I have to do to fix the speedometer difference issue??? Edited October 13, 201213 yr by soobie_newbie67
October 13, 201213 yr Actually I did notice something interesting. You would think it shouldn't work this way, but I noticed my car moves along better and steers better with these tires. :/ Oh yeah. And what will I have to do to fix the speedometer difference issue??? New tires always feel better. You could paint new numbers on the bezel.
October 13, 201213 yr Can't I just use a speedometer sending unit from an outback that uses 205/70-15 tires? Or do I have to go to the dealer and have it calibrated?
October 13, 201213 yr What you'll find is that Mr Fuji swapped the speedo drive gear in the gearbox and that the outback instrument cluster is calibrated the same. What you could look into is a pulse modulator that modifies the signal from the reed switch at the gearbox. I'm 99% sure your subi doesn't have a speedo cable, which means it's all electronic and easier to play with Unfortunately I don't know of a kit that does the job as I've not had the need to ever do this so far - I've only heard about it on the forums. Hope this helps Cheers Bennie
October 14, 201213 yr Well. On Monday I'm gonna call the dealer and see if they can calibrate it. I downloaded a speedometer app on my phone and found out I'm doing 65 @ 60 on the dash. Around town no problems through. Doing 36 @ 35 on the dash.
October 15, 201213 yr What you'll find is that Mr Fuji swapped the speedo drive gear in the gearbox and that the outback instrument cluster is calibrated the same. What you could look into is a pulse modulator that modifies the signal from the reed switch at the gearbox. I'm 99% sure your subi doesn't have a speedo cable, which means it's all electronic and easier to play with Unfortunately I don't know of a kit that does the job as I've not had the need to ever do this so far - I've only heard about it on the forums. Hope this helps Cheers Bennie Well I hope your right. I called the dealer and the service guy told me it has a speedometer cable. I don't believe him. I couldn't find a cable anywhere.
