March 20, 201511 yr That looks damn good! You may have said, but I couldn't find it, what size tires are you running? They look awesome on there.
March 20, 201511 yr Author Don't think I did post that! 185/60/14 (22.8") So they are pretty much the stock size in Diameter.
March 24, 201511 yr Author Gonna be getting a EA82 FWD 5spd trans for the coupe this weekend. Has 110,000 mi and came out of an '86 GL 3-door. Should be able to get the Flywheel too. Just gotta source a pedal box for an EA81 car and whatever other odds to make this a complete swap. Thank you MilesFox and SlickDizzy!
March 30, 201511 yr Author Trans turned out to be a Push-button 4WD 5spd, so its more or less useless to me. But I have it anyway. I did get a flywheel for the D/R, so thats wicked! Orange Marker lights! Tamiya TS-73 does wonders. I am debating on painting the High-beams amber as well...
April 4, 201511 yr Author Just got NOS Magnum Fog lights, cleaned them up and planning on mounting them under the bumper. Been looking for some large 80s Fog lights for a while. I tested them with 12v, they are rather bright, the bulb is just an 1156. The reflector is very nice chrome and the design of the lens seems to direct the light the right way. $20 steal!
April 5, 201511 yr Author Tamiya TS-73 (Clear Orange) Always works great! Wheels were powder coated white about 5yrs ago lol.
April 8, 201511 yr Author The SPFI EA81 swap thread is a decent read for anyone. http://www.ultimatesubaru.org/forum/topic/14639-ea81-spfi-conversion-and-more-horsepowertorque/page-2
April 8, 201511 yr Author Also going to post this Write-up here. EA81 Performance Mods. http://www.subarubrat.com/engine.htm
April 8, 201511 yr Found lights mounted! Geez mate, there's a lot of orange on the front of that coupe now!! I Australia we use a yellow light for foggy conditions - well, those who actually need fog lights, the new vehicles come out with white "fog lights" that are run at night with the other lights. Not cool but no body does anything about them Cheers Bennie
April 8, 201511 yr Author I still want to get two big round Light Force or IPF lights for in front of the grille, Mounted on some type of bar, I like Light Force because you can change the Lens.
April 8, 201511 yr Author So I finished de-smogging the EA81 today. I even removed the Charcoal canister and everything associated with it. Now the only lines which run to the Carb are the Main fuel supply, the return line, and a vac hose for the Disty advance, every other port on the carb has been capped off along with the intake. I no longer have the EGR hooked up, so its acting as its own block off plate until I make one. Seems to run even better now.
April 8, 201511 yr I want to do that to mine. There's way too many hoses and crap running everywhere.
April 8, 201511 yr Author If you don't have inspections or emissions over there, just start removing it all! It'll run the same if not better. WI doesn't have inspections and only does testing for vehicles 1996 and newer (But not all Counties in the state do it) Next up is to totally de-smog the EA82, hoping the ECU won't trigger a CEL. If the '92 Landcruiser does't, I don't see why the Loyale would, but who knows.
April 8, 201511 yr The best way to fix an ECU check engine light is to place some black electrical tape over the check engine light spot on the dash. Works like a charm...I haven't seen a check engine light in ages!
April 8, 201511 yr Author I do get an ECS light on the EA81 when you drive it long enough, but thats because someone removed the O2 sensor and plugged off the hole with some JB Weld. I am thinking of putting a resister in place of the Oxygen sensor so the computer thinks its there. Or pull the bulb out lol.
April 9, 201511 yr Author Yeah Jimbo said the same thing. I will try to get some pictures tomorrow if it isn't pouring.
April 9, 201511 yr Author Heres some pictures of the cleaned up de-smogged Hitachi! I need a less rusted Air box, but I may be able to fix this one. Here you can see the Main fuel feeder line, the Return, and the Vac line for the throttle/choke thing on the left. And all the blocked off ports that are now unused. I am planning on unscrewing the port ends, and screwing something solid into them so there is no need to worry about failing rubber caps. Here you can see how I ran the Vac Advance off the front of the carb and plugged the other port. No Charcoal canister and lines anymore! This is the breather line for the tank vent, I am planning on hooking this to the air box where suction isn't so absolute as not to draw fuel thru this line, but have it vent into the air box so it can be re-burned if at all. My other thought was to just cap off this line, but I'm not sure what reproductions would happen if the tank can vent? All Wet! Edited April 9, 201511 yr by TheLoyale
April 10, 201511 yr man i love your car !... wish i could get my hands on one of these older ones Edited April 10, 201511 yr by Nico
April 10, 201510 yr Author I will trade you for a clean EA82 sedan. I can't deal with rotted out Subarus anymore, top half looks nice, bottom is gone, you have to rebuild the car before you can even build it up! Nico, you have one of the nicest, cleanest builds I have ever seen, and for the fact that everything is almost NOS and is altered, it is amazing!
April 12, 201510 yr Author Gonna get my '82 4WD bumper from the Skiwagon back tomorrow! Gotta pick it up in West suburbs of Chicago.
April 16, 201510 yr Author Picked up the bumper last Sunday, looked just about as good as when it left me! Just needed to be re-polished and the rubber re-moisted. Now I gotta figure out how to make a 4WD bumper work on a 2WD that had the impact bumper struts (Which I removed) Anyway, got a set of KYB Gas A Justs today for the rear, installed them and its a night a day difference from the original collapsed dampers. Awesome stuff! #KG4183A Straight out of the 80s, thats for sure! The rear finally sits up just a bit, no more saggy rear end! Also repainted the rear badge since all the chrome flaked off. All Tamiya paints. Gray and Red to keep it looking 80s. Edited April 16, 201510 yr by TheLoyale
