September 16, 20196 yr will the auto trans from a 2001 outback LL Bean h6 work in a 2001 outback base model with a 2.5? i know id likely have to change the diff too just wondering are they electrically the same and will work. Edited September 17, 20196 yr by sirtokesalot
September 17, 20196 yr I think not. use car-part.com to check compatibility. 2001 Subaru Outback (Legacy)Transmission AT, 2.5L, BrightonAT, 2.5L, GTAT, 2.5L, L modelAT, 2.5L, OutbackAT, 2.5L, SUSAT, 3.0L, vehicle dynamic controlAT, 3.0L, w/o vehicle dynamic controlMT, GTMT, OutbackMT, exc. GT and Outback
September 17, 20196 yr Author I do know the 2001 h6 llbean car is not CDC I'm not sure the transmission number the 2 cars are at a friends house where I'll be doing the work.
September 17, 20196 yr My guess is yes except for the difference in final drive ratios. https://www.ultimatesubaru.org/forum/topic/156582-outback-h6-4eat-compatability/ Edited September 17, 20196 yr by john in KY
September 17, 20196 yr 23 minutes ago, sirtokesalot said: I do know the 2001 h6 llbean car is not CDC I'm not sure the transmission number the 2 cars are at a friends house where I'll be doing the work. You're car is currently 4.44. LL Bean is 4.11. So, if you swap to the 4.11 diff to match yes it will. BUT!!!........The taller gearing will make the car feel less powerful off the line, and during hills and towing. It may improve Highway gas mileage as the trade off. Also, the TCU may or may not have a problem with seeing the wrong RPMs vs. VSS readings. Also, the shifts may try to happen too early, as they would be mapped for 4.44. Differences in clutch pack specs for 4cy vs. 6cyl may also cause shifts to feel clunky or laggy.....not sure but since the differences in the trans are there, it's possible. Not sure if the wiring would allow swapping TCUs to match. It might. But then also the H6 TCU may want a different type of TPS signal.....again not sure. Basically, yes it will drive if you swap diffs. The nuances about how well it will actually perform and if you'll be happy are hard to parse. I would find a good 4 Cyl Outback or Forester trans.
September 17, 20196 yr Author 6 hours ago, FerGloyale said: You're car is currently 4.44. LL Bean is 4.11. So, if you swap to the 4.11 diff to match yes it will. BUT!!!........The taller gearing will make the car feel less powerful off the line, and during hills and towing. It may improve Highway gas mileage as the trade off. Also, the TCU may or may not have a problem with seeing the wrong RPMs vs. VSS readings. Also, the shifts may try to happen too early, as they would be mapped for 4.44. Differences in clutch pack specs for 4cy vs. 6cyl may also cause shifts to feel clunky or laggy.....not sure but since the differences in the trans are there, it's possible. Not sure if the wiring would allow swapping TCUs to match. It might. But then also the H6 TCU may want a different type of TPS signal.....again not sure. Basically, yes it will drive if you swap diffs. The nuances about how well it will actually perform and if you'll be happy are hard to parse. I would find a good 4 Cyl Outback or Forester trans. well do u think it would be as bad as a 2.2 running on a 3.90 final drive? my current setup is a 1998 outback with a1995 legacy L engine and trans using the outback tcu. im ok if its a lil slow im mainly concerned about driveability and hope it would be a little faster than my current car. Edited September 18, 20196 yr by sirtokesalot
September 18, 20196 yr On 9/17/2019 at 10:44 AM, 3Pin said: I think not. use car-part.com to check compatibility. 2001 Subaru Outback (Legacy)Transmission AT, 2.5L, Brighton AT, 2.5L, GT AT, 2.5L, L model AT, 2.5L, Outback AT, 2.5L, SUS AT, 3.0L, vehicle dynamic control AT, 3.0L, w/o vehicle dynamic control MT, GT MT, Outback MT, exc. GT and Outback How do you find this info on car-part.com? I am searching for compatible models for an '08 Impreza, and this would be extremely useful for me right now!
September 18, 20196 yr when you enter details about your car, it brings up an option to pick the right transmission and you select the one you need.
September 18, 20196 yr Author well today i did the swap the transmission is bolted in there now. i forgot thefluid here at home so did not fill it yet. will it cause damage to the 4.11 transmission if i were to run it with the 4.44 diff with the fwd fuse installed? id like to try to drive it before i swap the diff over as well just to find out if it all works before spending that extra effort. would like to figure it out before morning. im planning to go up there again tomarrow to finish it. Edited September 19, 20196 yr by sirtokesalot
September 19, 20196 yr Author well im getting ready to head back to the car to finish up. i guess ill just swap the diff and hope this transmission works out. wish i knew if i could drive it with the wrong diff and fwd fuse first to find out if it will work before doing the effort of changing the diff. but id rather not cause damage and i just dont know if it will with the fwd fuse in or not. Edited September 19, 20196 yr by sirtokesalot
September 19, 20196 yr It SHOULD be okay to test drive a little with FWD fuse in. Alternately, you could remove the rear section of center section of the driveline.
September 19, 20196 yr I would say safe for testing, but maybe not for regular use. The plates will be spinning relative to each other at a fast rate and any tiny bit of friction will cook 'em.
September 19, 20196 yr Author heres the results. i did change the diff the transmission does work and does not set any codes seems to drive ok with light throttle/normal driving but under heavy throttle/acceleration scenarios it has some really funky shifts. engine can pull the gears ok doesn't seem to be slipping or struggling too hard. seems like i can drive it though until i find another good transmission. in the end this did not cost anything but time the h6 transmission and diff was free
September 20, 20196 yr It will be less trouble to get the right trans. You can get low mileage ones from the JDM outfits for 2-300. Or any junkyard they dont fail that often so you have good ods that youll get a good one .
September 21, 20196 yr Author does anyone know if the transmission from a 2005 forester would work in my 2001 outback? i found a transmission for 100 bucks from a rollover with 71,000 on it. i dont really get that website. Edited September 21, 20196 yr by sirtokesalot
September 27, 20196 yr On 9/21/2019 at 5:51 PM, sirtokesalot said: does anyone know if the transmission from a 2005 forester would work in my 2001 outback? i found a transmission for 100 bucks from a rollover with 71,000 on it. i dont really get that website. I think they would be too different. certainly the transfer valve and solenoid would have to be swapped, but worse I think the '05 forester had a much more electronic 4EAT.
September 28, 20196 yr Author im going to assume i cannot use the transmission from a 1998 impreza can i? i have one of those on hand in another car i got free.
September 28, 20196 yr A used trans is usually not that expensive. IMHO, I would sell the free trans you have and buy the right one for your car. Just saying. that is what I might do.
September 29, 20196 yr Author 11 hours ago, 3Pin said: A used trans is usually not that expensive. IMHO, I would sell the free trans you have and buy the right one for your car. Just saying. that is what I might do. ive been looking i jsut dont have cash for one currently. exploring my options. i was almost going to trade the 1998 impreza for a low mile trans but then realized it was a 2006 transmission and wouldent have worked. yes i would trade a running car for a transmission exp when said car was a free car. i do know i could get more by selling it and buying a transmission but it needs more work before i would sell it. Edited September 29, 20196 yr by sirtokesalot
October 5, 20196 yr Author is there any reason to fear a transmission that was stored outside with the axle stubs in and tail sealed? i found a 100 dollar 123,000 mile 4.11 legacy transmission.
October 5, 20196 yr 10 minutes ago, sirtokesalot said: is there any reason to fear a transmission that was stored outside with the axle stubs in and tail sealed? i found a 100 dollar 123,000 mile 4.11 legacy transmission. Bugs and animals leave debris and weather exposure. Probably fine but there’s definitely room for stuff to happen. How long has it sat and where? 10 years on a weedy, shaded, over grown, cluttered side of a building is different from a clean, dry area with less debris, vegetation, etc.
October 5, 20196 yr Author heres the 2 pictures. the guy said its been there for a couple years and it was covered but not sure with what.
October 5, 20196 yr Author Ok just want to be sure I found a 2004 outback trans now for 150 the 2004 trans will work right? I dont k ow the ratio on this one thogh I'm guessing 4.44 I can look ot up later. I have both 4.11 and 4.44rear diffs The transmission I found is tz1a4zceba-3k I'm not sure the original but it will be going into a 2001 outback hope to hear from someone before this afternoon want to pick this up tonite Edited October 5, 20196 yr by sirtokesalot
