December 7, 200520 yr $700 usd, from Rallispec. I've got another d/r lined up thanks to Island Roo so once they arrive we'll see if it can be done.
December 7, 200520 yr If I may show my ignorance, what is a 4.44?Is that a diff gear ratio? Rollie Yep, stock D/R trans uses a 3.90 final gear ratio, and if someone could find a way to put 4.44s in a D/R case, THEY WOULD BE A GOD, AND I WOULD WORSHIP THEM FOREVER!!!!! I think someone did the math, and 4.44's would allow for ~29" tires with the same gearing as 3.90s and 22s.... it'd be like having stock drivetrain, with the clearance of 29s!!!!!! I'm SOOOO HAPPY!!!! sorry...
December 7, 200520 yr anything i can help with! so that might make me gods evil hench man? what type of car are the gears fromi mean a specific Subaru, like a WRX, or specifically cut for the EA82 trans? hows the research on the EJ22T going?
December 8, 200520 yr Author I hope it all works, if it doesn't then I'll piece the d/r back together and hawk the gears on e-bay or something. After the cost of shipping and reselling I might lose a couple hun. but I've DREAMED about better gears for too long. As far as I understand these are from Japan. Several models of JDM(and a few US cars too) Subaru's use them. Mark(Island Roo) I probly won't get started until mid Jan or later shipping from Japan to US then to Canada at this time of year can't be all that fast, they did figure on 1 month or less tho, but I'd appreciate any help I can get.
December 8, 200520 yr I think I creamed my pants when I read 4.44 final drive ratio .. thats better than my jeep... if you need any help at all what so ever... OMFG I WANNA HELP... too bad you're so far away. please keep us all posted as you gather information, and your plans/hopes for this project. my uncle has a used transmission shop, I'm wondering what all would go into something like this, cause over the winter break, if i get motivated and have a fairly good idea of what i'm looking for, I might just go through all my uncles crap and mix and match and see what works... he has a LOT of parts just sitting around...
December 8, 200520 yr i'd be interested in hose gears if they dont fit... i got a legacy that needs shorter gears..... 4.44's would do the trick....
December 8, 200520 yr Author My legacy has a pretty low 1st as is (92 turbo 3.90 final) are you doing autocross or something?
December 9, 200520 yr more like rally cross setup.. im running the outback struts with lift springs soon to be installed, and im running kumho venture m/t 27-8.50/14 tires.... the gearing has gone south a wee bit.... need to get the acceleration back..... hopefully the motor i plan on putting together for it will help some as well...
December 10, 200520 yr SCWEET!!! So .... help the guy with the "moding for dummies" book To do this you have to change the gears in the trany AND the diff? so then you have to get annother LSD diff in my case that is a 4.44? or are you doing some other kind of set-up?
December 10, 200520 yr Author Yes you have to change both, but you keep the gears from the trannie it's only the ring and pinion that have to to be swapped. A fair bit of aluminum removal too with the trannie and the rear diff. All I know about it so far is from reading up on few different forums and rally sites, it'll be I while before I can post pics and have any sort of write up.
December 10, 200520 yr Yes you have to change both, but you keep the gears from the trannie it's only the ring and pinion that have to to be swapped. A fair bit of aluminum removal too with the trannie and the rear diff. All I know about it so far is from reading up on few different forums and rally sites, it'll be I while before I can post pics and have any sort of write up. Ok, so are you using the stock ea81 tranny case or are you having to use a AWD case? And is $700 so far the total expense?
December 10, 200520 yr flyboy....it's the front diff....which is in the tranny case. and I think $700 is just for the 4.44 front gearset, probably not including the stuff for the rear. and I bet he's using his EA82 tranny
December 11, 200520 yr picked up the black wagon tonite, went to get the other car turned out to be a EA81 in an 82 hatch but had excavator marks in the body so left it there
January 2, 200620 yr Vanislru..... I've researched this extensively myself as well....Here is what i've found out... the 2WD Hi-Lo 5speed trany is Not going to allow the 4:44 gear set to marry in as it sits stock...The Pinion shaft bearings sit in different enough locations that EXTENSIVE re-constructive surgury( welding of case,machining of case ) will have to take place....then the other MAJOR issue is the length of the pinion shaft is set up for an AWD model tranny, so it is roughly 50mm longer/shorter than the Hi-Lo trans.....I can't remember......So the tail end of the Hi-Lo box won't marry to it either.... I have talked Person to person with A guy who back in 93-94 Did a 4:11 swap into an RX AWD hi-lo tranny...And in order for that swap to happen he had to use the tail section of the AWD 4:11 trans, and LOSE the center diff Lock that was in the RX tranny..... I Sincerly hope your Machine Shop guy has a Magic Wand....and can make this Happen....I would Love to see it I have been wanting to post to this for you to have more first hand info, but HAve been Oh so Super busy... Today's the first chance I've had to sit and breath in months.... Hope this brought a bit more insight into your endevor...... John in Oregon......
January 3, 200620 yr Author Yeah, I'm pretty confident some major reworking will have to be done too. As long as I don't screw the R+P's trying to do it then I'll only have messed a d/r trannie, that's really cheap. Now that the Christmas shipping gong show is over I hope to see those R+P's soon. I want to make it happen. If it takes alot of time so be it. $$$ too well... I just hope It's not too bad and it becomes something that others can do too.
