did Subaru ever make this trans
i was wondering if Subaru ever made an EA AWD trand with no diff lock or D/R? the reason i ask is a friend of mine just bought a trans from a JDM importer. i looked it over real good and it has some differences from any trans i have seen.
first off it is a turbo trans. 25 spline front stubbs
it has no vacuume diaphram for diff lock nor dose it have the lever that the diff lock would pull.
also the transfer case is larger like a AWD trans...
im stumped. did Subaru ever make an EA AWD trans...
-=Suberdave=-
http://www.suberdave.com
you sure it's EA? because with those specs, the only difference would be the bellhousing....
or, it's not factory, and somebody slapped an EJ AWD center onto a FT4WD box.
There is a S/R FT4WD EA82 box. But it should have a diff lock lever on the right side about in the middle of rear casing. Or at least a pin sticking out ready to take a lever.
In other words. 99.99% sure there was no EA AWD box with no diff lock.
... However, you can make one using internals and rear casing of an EJ trans.
-=Suberdave=-
www.suberdave.com
Only if its a 4EAT :rolleyes:
it seems i wasn't the only one who had that thought upon reading the first post :rolleyes:
Me too!
I never even think of autos when there are questions about gearboxes on here. It's almost like I have blanked the fact that autos exist out of my mind. :-p
Seriously,automatics dont really exist do they? transmissions that shift themselves?..that sounds like a horrible idea.
