'82 Brat: Solid Axle Build *** DONE! :) ***
Planning Started
made initial purchase yesterday
4 axle brackets, 2 rights and 2 lefts, all with a 10 degree offset
4 adjustable link mount brackets
4 tube link brackets, 2 rights and 2 lefts, all with 10* offset
3 upper control arm brackets flat mount
1 upper control arm axle bracket 8"
8 bushing kits
4 Large RE joints
4 Forged Johnny Joints 1" shank RH thread w/jams & tube adapters
more to follow....
  • Replies 472
  • Views 172.6k
  • Created
  • Last Reply
Top Posters In This Topic
Most Popular Posts
  • Brat is still alive and kicking.....
  • carfreak85
    carfreak85
    OK, Mr. McBRAT, you owe us an update on the life this beast has been living
  • I'm hoping to get back out to WA sometime for one of the shows, but it will probably be a couple years from now....
Posted Images
Judging from that list of parts.
I like where this is going.
:popcorn:
i actually did some measuring for this.i figured if i made a subframe to all of the regular suspension mounting points and made the center section a combo transfer case/link mounting area it would work out better.
as opposed to try and weld the center mounting area directly to the body. anyways.awesome,am looking forward to seeing how it comes out.
eventually i will actually follow through with this one. i only started it 2 times already.got closer the second time.cheers, brian
got the RE joints the day before yesterday. I'm still waiting to get the '87 4Runner rear axle, steering box, and front hubs before it goes into full deconstruct mode.
I'll be removing some stuff from my Brat but still keep it driveable so I can drive it out to the shop.
  • 1 month later...
I know, I know.... pics....
maybe later tonight...
The engine and tranny crossmembers are back in stock locations. definitely need to remove the couple of carb spacers from the weber...
complete rear subframe is removed and all front suspension/steering stuff removed.
still need to remove the gas tank ande-brake handle....
Okay, so a bit of history on this Brat...
I got it in Feb. '03, came from AZ, engine was trashed, no fluids anywhere... a complete build was in order....
picture.php?albumid=46&pictureid=292
picture.php?albumid=46&pictureid=291
Put a 4/3 lift in, rear disk brakes, complete brake system flush, etc....
finally got an engine and in Aug, it moved under it's own power for the first time in probably 14 years...
picture.php?albumid=46&pictureid=290
Since then, it's gotten lots of decals, lots of dents, suspension changes, lift changes, etc.... all making it better each time, but always leading to the next weakest link....
Here it was in July of 2008...
picture.php?albumid=46&pictureid=294
picture.php?albumid=46&pictureid=293
Parts mentioned in the first post....
picture.php?albumid=46&pictureid=300
also purchased a Samurai transfer case...
and a few years back, I had purchased a '85 toyota from a junkyard. parted it out, and here's what's left after finally removing the axles. I also got a wider rear axle out of a '87 4-runner so it at least matches the width of the soob rear....
picture.php?albumid=46&pictureid=303
and then cut up and ready for the recycler...
picture.php?albumid=46&pictureid=302
The deconstruction begins....
picture.php?albumid=46&pictureid=301
picture.php?albumid=46&pictureid=296
picture.php?albumid=46&pictureid=295
picture.php?albumid=46&pictureid=297
Definitely need to take the carb and intake spacers off... or cut a big hole in the front of the hood :) actually, SPFI will be coming next summer probably....
what do you think...? Just a little more bashing?
picture.php?albumid=46&pictureid=298
:brow:
actually, those are a little bigger than what'll be on it....
moving rear axle back a bit, and the front axle forward more... probably looking at 105" wheelbase... and will definitely be losing sheetmetal....
Mick what are your plans for the front axle?
I'll be running the '85 toy front axle, with the '87 4-runner IFS steering box.
Chris (the design/fab guru) will be deciding whether to go 3 link or 4 link in the front.
excellent :brow:
let me know if you need any yota drivetrain parts. I'm parting out an '86 IFS 4Runner right now. I'm keeping the engine, tie rods and front axles for sure. pretty much anything else is up for grabs.
Took a few more pics tonight with my good camera, when I went over to drain the gas tank, and pick up the no longer needed soob parts... Chris already had the front axle positioned under it to get a feel for placement, etc...
The exhaust definitely needs changed up front....
picture.php?albumid=46&pictureid=312
picture.php?albumid=46&pictureid=313
picture.php?albumid=46&pictureid=314
picture.php?albumid=46&pictureid=315
picture.php?albumid=46&pictureid=316
picture.php?albumid=46&pictureid=317
picture.php?albumid=46&pictureid=318
whats the plan on passenger side exhaust? looking like got some good progress momentum now.
probably need to come forward and loop to the drivers side. like a flipped turbo cross-over....
I think a Turbo exhaust header from a EA82 with some mods to the crossmember would clear your pumpkin, what say ye? Looks like its gonna be fun, Im workin on a straight axle rig myself :brow:
-Bill
