September 18, 200817 yr Planning Started made initial purchase yesterday 4 axle brackets, 2 rights and 2 lefts, all with a 10 degree offset 4 adjustable link mount brackets 4 tube link brackets, 2 rights and 2 lefts, all with 10* offset 3 upper control arm brackets flat mount 1 upper control arm axle bracket 8" 8 bushing kits 4 Large RE joints 4 Forged Johnny Joints 1" shank RH thread w/jams & tube adapters more to follow....
September 25, 200817 yr i actually did some measuring for this.i figured if i made a subframe to all of the regular suspension mounting points and made the center section a combo transfer case/link mounting area it would work out better. as opposed to try and weld the center mounting area directly to the body. anyways.awesome,am looking forward to seeing how it comes out. eventually i will actually follow through with this one. i only started it 2 times already.got closer the second time.cheers, brian
September 26, 200817 yr Author got the RE joints the day before yesterday. I'm still waiting to get the '87 4Runner rear axle, steering box, and front hubs before it goes into full deconstruct mode. I'll be removing some stuff from my Brat but still keep it driveable so I can drive it out to the shop.
November 14, 200817 yr Author got the '87 4 runner rear axle, and steering box.... I'll try to get the pics to start showing the build as we go.....
November 16, 200817 yr Author I know, I know.... pics.... maybe later tonight... The engine and tranny crossmembers are back in stock locations. definitely need to remove the couple of carb spacers from the weber... complete rear subframe is removed and all front suspension/steering stuff removed. still need to remove the gas tank ande-brake handle....
November 17, 200817 yr Author Okay, so a bit of history on this Brat... I got it in Feb. '03, came from AZ, engine was trashed, no fluids anywhere... a complete build was in order.... Put a 4/3 lift in, rear disk brakes, complete brake system flush, etc.... finally got an engine and in Aug, it moved under it's own power for the first time in probably 14 years... Since then, it's gotten lots of decals, lots of dents, suspension changes, lift changes, etc.... all making it better each time, but always leading to the next weakest link.... Here it was in July of 2008...
November 17, 200817 yr Author Parts mentioned in the first post.... also purchased a Samurai transfer case... and a few years back, I had purchased a '85 toyota from a junkyard. parted it out, and here's what's left after finally removing the axles. I also got a wider rear axle out of a '87 4-runner so it at least matches the width of the soob rear.... and then cut up and ready for the recycler...
November 17, 200817 yr Author The deconstruction begins.... Definitely need to take the carb and intake spacers off... or cut a big hole in the front of the hood actually, SPFI will be coming next summer probably....
November 17, 200817 yr Author what do you think...? Just a little more bashing? actually, those are a little bigger than what'll be on it.... moving rear axle back a bit, and the front axle forward more... probably looking at 105" wheelbase... and will definitely be losing sheetmetal....
November 17, 200817 yr Author Mick what are your plans for the front axle? I'll be running the '85 toy front axle, with the '87 4-runner IFS steering box. Chris (the design/fab guru) will be deciding whether to go 3 link or 4 link in the front.
November 17, 200817 yr excellent let me know if you need any yota drivetrain parts. I'm parting out an '86 IFS 4Runner right now. I'm keeping the engine, tie rods and front axles for sure. pretty much anything else is up for grabs.
November 18, 200817 yr Author Took a few more pics tonight with my good camera, when I went over to drain the gas tank, and pick up the no longer needed soob parts... Chris already had the front axle positioned under it to get a feel for placement, etc... The exhaust definitely needs changed up front....
November 18, 200817 yr whats the plan on passenger side exhaust? looking like got some good progress momentum now.
November 18, 200817 yr Author whats the plan on passenger side exhaust? looking like got some good progress momentum now. probably need to come forward and loop to the drivers side. like a flipped turbo cross-over....
November 19, 200817 yr I think a Turbo exhaust header from a EA82 with some mods to the crossmember would clear your pumpkin, what say ye? Looks like its gonna be fun, Im workin on a straight axle rig myself -Bill
