December 17, 201015 yr came to the realization that when i floored it the weber would only be 3/4 of the way open. so i adjusted my cable. pulls a lil bit better oh i painted the custom bumper i made too. (its about 3/4 done) heres a b4 pic. ill be sure to get a pic up today when its lighter out
December 17, 201015 yr Made a bike carrier that attaches to the jump seat mount, since I don't have any jump seats.
December 18, 201015 yr I'm digging the lights I have some that need to be mounted up however I need to find a gear first. Does anyone out there have distributor gears for an ea81 I need both the crank gear and the distributor gear. Then I can put the motor back together. I got the engine bearings today and yesterday I got my pistons:grin:
December 18, 201015 yr I put a new thin radiator fan and radiator temp switch in my GL. I went to get into my legacy outback at 5:45am and the driver's side mirror was dangling by a few wires. The po po said there were 5 others in the neighborhood. "Do you think it was kid or a plow?" he asked. I said that judging by the 6 inches of fresh snow on the ground I'm going with plow.
December 18, 201015 yr Well it was last week but, here it is,, Picked up a Christmas tree and loaded it on top. A 20 mile trip down the freeway, just from a tree farm.
December 19, 201015 yr Its lifted More Pics: http://www.facebook.com/album.php?aid=100340&id=1344730058&l=d53631b3b2 4" lift, Gen II Vented disk brakes, new Axles up front, NEW load leveler shocks on the rear with custom top mounts
December 19, 201015 yr Installed some cab mufflers on the BRAT. Put in some seats out of my old Dodge Spirit. The Dodge seats are so much thicker and wider that they reduced the interior noise greatly, so I call them my cab mufflers.
December 19, 201015 yr I recently put 15" rims and tires on my 93 legacy. New MAF sensor, custom exhaust, working on cold air intake, new headlights, seamfoamed it changed the oil. Next project is new performance chip, and replacing my no reverse tranny.
December 20, 201015 yr Pulled an '82T out of a parts car for my RX zzz Scored $150 mounted Blizaks on Craigslist Found another rockin' RX parts car for xmas I'm starting to run out of parts car parking.... And the wife is running out of humor
December 20, 201015 yr did the alternator swap on the wagon. and went to do the front wheel bearings took the knuckle to napa to have the bearings pressed, the press slipped ended up marring the cage and putting a few flat spots on the bearings themselves. im car-less right now and its sorta lame
December 20, 201015 yr the following should be finished tomorrow: timing belt w/ new tensioner and all idlers, new waterpump, reseal oil pump, crank and cam seals, new clutch kit and flywheel, valve adjustment, new valve cover gaskets, updated oil separator plate, new rear main, pretty much every hose, and some other needed love. the credit goes to GD and it has been awesome watching and learning from him. really helped me and the family out on this one.
December 20, 201015 yr Did a compression test and all cylinder's read: 150 psi except for No. 1 cylinder which was just shy of 160 psi. Edited December 20, 201015 yr by darsdoug removed smiley face.
December 20, 201015 yr Well, it's not my Subaru, but GirlWithALegacy's 98 Lego obliterated a timing component. Idk which one as I'm 300 miles away from my tools and am borrowing crappy off brand tools from a friend. Not to mention I'm lacking a 22mm-7/8 socket >_< And with minimal funds available, it may be difficult to get said socket. Anyway, so I'm tearing apart and trying to fix someone else's Subaru. Oh, and another rant item. The previous mechanic (PO's didn't know a spark plug from a lug nut) rounded off the a/c belt tensioner pulley bolt and I ended up breaking the adjuster bolt casing, or whatever the bolt threads into, trying to get it to let the tension out on the belt Twitch PS: Post #1000! and it only took me 2 years, 4 months and 15 days! :cool:
December 21, 201015 yr I love those photos, something about them makes it look nostalgic. Very good indeed! -Tom
December 22, 201015 yr well im like 5 days late on these pics but hey here they are.....its still about 80% done. : D
December 22, 201015 yr Cut down the bed mat from my old Mazda truck to make a nice BRAT mat for Clod's bed.
