All Activity
This stream auto-updates
  1. Past hour
  2. I don’t recall the EA82 having head bolt holes that go into water jackets. I you have it on an engine stand turn the holes to be cleaned upside down and let gravity do its work. You might only need to agitate it with a piece of wire. Then run the thread chaser down each hole again. Or so it on the bench by “whacking” the deck into a soft surface like a newspaper or towel on the bench. Anything that doesn’t come out shouldn’t be a problem.
  3. Yesterday
  4. So I've been spending the past few nights after work cleaning up my deck surfaces and head bolt holes. I ran a thread chaser down all the head bolt holes and they all cleaned up great, however some of the gunk it scraped off the threads is now at the bottom of the holes. I don't want to use compressed air as I worry some of the holes go into the water jacket and I don't want to blow the gunk into the water jacket. Any tips and tricks here? I thought about using a wood screw to auger the gunk out or using some safety wire as a pick to get the gunk out. I used a small amount of engine oil to help the thread chaser and the gunk is sticking to the oil. Obviously brake clean would help get the oil out but I still worry about the brake clean blowing the gunk into the water jacket. :]
  5. Measure whatever lift block you have on the subframe or above the strut. I believe you can get away with removing half an inch from this measurement and use this to fabricate the new trailing arm mounts. If you can make your own mounts, you have the advantage of making several sizes to see what works best for you and keeping your costs down in the process.
  6. I have not done this and those that did this years ago are most likely long gone from the forum. One of the biggest factors is your driving style and mechanical sympathy. With a dual range gearbox and the dual range divorced transfer case and the addition of 4.44:1 diffs, you could run larger tyres and crawl really slowly - best of both worlds. What vehicle are you putting all of this into? If a vehicle with an AWD, you’ll need to weld the centre diff. Being a 1.44:1 low range it’s either an MY chassis or the sf forester (but I didn’t think you guys got the dual range gearbox from factory in the states).
  7. I love your checklist of stuff you worked through, very systematic! Interesting about the low range, you’re probably keen to know what the issue is. I’m keen to see a low range for the 5spd! That redesigned rear knuckle “just paid for itself” (quote from “The Castle”) with that bolt on bearing replacement! I bet the rally crew would be interested in a set of these knuckles! Keep up the good effort!
  8. Metal zip ties are awesome to use too. Just ensure you get plenty of pressure on the boot before cutting the tag end short. Roll the remaining tag end over the zip tie’s clamping piece. This locks it in somewhat.
  9. Last week
  10. A few things when disassembling/assembling axles: Inner joints (transmission side): These have a large diameter metal clip close to the outer edge of the bearing cup. Just use a small flathead screwdriver to get this started and remove it. Take photos of the orientation of the outer bearing retainer, it is unidirectional. Remove the bearing carrier/retainer as an assembly, use your small screwdriver to pry the bearings out (be careful to not scratch the surfaces, use a cheap screwdriver they'll be softer than nice ones), then turn the outer retainer and it'll separate from the inner carrier. Outer joint: These joints have the metal clip I was mentioning above. If this joint wasn't accidentally disassembled when you were putting in the strut then leave it be. They're not supposed to be disassembled but they *technically* can be. Only use molybdenum disulfide grease when assembling the axle. Make sure the axle is clean of grease before regressing and reassembling. Zip ties can work as boot clamps, but I'd recommend actual boot clamps.
  11. I love the technical terms used in the illustration. Haha.
  12. Thanks, el_freddo, it truly is the highest quality of art. I was able to move the boot back and take a look at the inside, and it looks like the shaft thing has come apart from the spindle thing. According to the (1988) manual, there is a snap ring that holds it in, somehow? I will have to take the whole thing out and on the table to really see what's going on. I just got a 1986 service manual, so I'll be sure to take a look at that as well and confirm that snap ring was present in the 86 models as well, although I'm sure I'll find out once I take the thing apart. Hopefully when this is all done, I'll actually get back to working on those air struts lol.
  13. After doing a TON of research: Front Right KYB: 333234 Front Left KYB: 333235 These struts seem to only be available in Australia so you're going to pay out the keister for shipping but luckily for US residents the current exchange rate is quite good. I have one KYB strut on the way from down under so if you want to wait to see if what I actually get is the correct strut, I'll post back here when I get it and let y'all know. I needed a right side strut BAD, I had a spare left Sachs but I couldn't find a right Sachs nor TRW. Hopefully now I'll have a spare set to keep my GL running far longer than the engineers intended. :]
  14. Drove white Outback around town a bit, seemed to be slipping at times. Hadn't realized the auto trans fluid was low, didn't realized it had lost much. Wound up adding three quarts but it is now slightly over full. Back to its normal amount of auto slushiness now I think. Washed it and put the front piece of sheet metal B made and license plate on. I've driven it over 200 miles and about five hours of driving, seems basically back to normal, alignment seems great. Haven't noticed any leaks. Hasn't been starting without using a jump pack so we cleaned up all the battery cable/starter connections. Didn't really help but the lead clamp on the ground post was due for a replacement, cut back those cables and cleaned them up. Eventually got a new AGM battery which seems to be working. Replaced the rear washer pump, old one was leaking. Replaced the RF headlight, one of the bolts had pulled through in the hit. Got a driver's side radiator fan and installed that. Exhaust was rubbing on driveshaft a bit, B had rigged something up that was almost preventing that, I tweaked it a bit and it seems good now but the middle section of the exhaust could definitely use some improvement there plus the cone gasket has been leaking for years because the flange bottoms out. B helped me replace the pitch stopper. The stock plastic one broke in the crash, which I didn't realize until fairly recently. Took some jacking up of the trans and prying to get the new pitch stopper to bolt up. On the plus side that straightened out the trans mount and probably gave us a bit more exhaust to driveshaft clearance. Pulled a vacuum on the AC system, seemed to be leaking a bit. Put a little charge in it and the o ring on the low side of the compressor seemed to be leaking. Replaced that, didn't seem to leak, put the rest of a can in it. Enough to actually run the AC, high side 50, low side slight vacuum, doesn't blow cold. Figure I'll check it in a week or so and see if it's leaked. We're basically past AC season here but it is handy for defrosting the windshield at times. Radiator fan runs with the AC on. We tried pulling the swaybar mounting bracket forward by using a come a long (hand winch) to the Impreza but I don't think it moved. Doesn't seem to hit the tie rod so I guess it's good where it's at. Rear portion of the driveshaft is bent, I'd say 1/8-1/4" (3-6mm). Buckled in the crash maybe? There's a high frequency vibration that's worst at about 50mph, I assume from the driveshaft. Got one on order from a junkyard. We went over some things on the Impreza. The rear wheel bearings had a little bit of play. Slight on the RR, about the amount we start to consider bad on the LR so I replaced that. Much easier with the bolt in wheel bearings. Replaced that CV axle too, inner boot was starting to cut/tear. Old wheel bearing spun freely and sounded bone dry, good thing I replaced it. B tightened down the aluminum bracket for the LF control arm, those bolts were quite loose for some reason. He adjusted the driver's door, hadn't been staying closed firmly again, catch probably just shifted out a bit. He found a leak in the RF tire, seems to be a decent sized stick or something. So I have a few tires to take to Discount sometime for their road hazard warranty. Unfortunately the trans started making a lot of noise Sunday on the way home from a day trip. Made it home fine. Most likely similar low range failure the black Outback had. Going to start transmission removal today. Have some new low range parts made up - different material/heat treat, more oil holes, additional bearing - hopefully will last longer.
  15. Thanks for the wisdom! What I did exactly was, unbolt the stabilizer from the from the transverse link, and loosen the bolt holing in the link so I could bring it down, I then took out the old air struts and then put the new one in. I couldn't bring the knuckle down low enough that I could slip the strut into the hole of the knuckle from the bottom, but I could bend the knuckle at an angle and then pop the strut into the knuckle (This is after I had loosened the bolt at the knuckle, and sprayed some WD40 to help it slide in). I had done this with the passenger side and it's not having issues, but I am now going to inspect that to make sure it's not about to fall apart. On the passenger side it was loose enough I could use my hands, however on the drivers side, I used my leg since I was close enough to the wall. Below is some MS-Paint art to illustrate my "infinite genius": I think I see what you're saying about disconnecting the joint. Tomorrow I'll take off the boot and see what's going on in there. I am assuming I'll need an extra pin, but we'll see, I'll reach out if I do and I'll gladly pay for it.
  16. Any SPFI throttle body will work. They were available on DL, GL, GL-10, and Loyales. They're all the same. Granted, just going off the model doesn't always work if there isn't any photos on the listing. For example a GL-10 could be SPFI, MPFI, or MPFI Turbo. There's a ton of overlap with fuel delivery systems on the different models. Vehicles could be optioned with a ton of different bits and bobs so there's really no hard line between different models. Generally the only real difference between the DL, GL, & GL-10 models is interior *broad generality*. If going off photos, the MPFI throttle body looks vastly different. Look for the cylindrical IAC valve on the front of the SPFI throttle body. The part number for the throttle body assembly is 16118AA380 OR 16114AA170. If that helps you on your search at all. :] P.S. look up "Subaru Loyale Throttle Body"
  17. Darn! SuspiciousPizza suggested looking for a throttle body, which would probably come with TPS. I've been using the search terms: EA82 SPFI throttle body on eBay and Craigslist, but suspect that there are better terms I could use, for example specific models and years. I don't have any knowledge of which Subaru models/years had engines that are close enough to what's in my 1987 SPFI GL-10 wagon, to have a compatible throttle body. I would appreciate any advice on that front.
  18. Were you pulling on the knuckle or some component away from the car? Like you're facing the car as if you're removing a tire and pulling the knuckle towards yourself. I'd remove the boot clamp to inspect what happened. On the outer joints, there's a little metal circlip that fits into a groove on the axle shaft. This clip prevents the axle shaft from pulling out of the inner joint. My guess is that's what you did. Pulled the axle out of the inner joint. All you should have to do (if that is the case) is take the clip, put it in the groove and shove the axle back into the inner joint. If you need a spare clip, I have some. I seriously doubt you actually broke the axle with arm strength alone. If you did, you should drop the wrenches and pick up a speedo for a bodybuilder competition In the future, best way I've found to remove the axles from the transmission is: remove the roll pin on the inner joint (6mm needle punch), remove the two engine mount nuts, remove the front engine pitch rod bolt, remove the transmission mount nuts, use a jack with a block of wood to lift the engine and transmission up 1-2 inches DON'T LIFT FROM THE OIL PAN LIFT FROM THE TRANSMISSION (watch your fan so it doesn't hit your radiator or fan shroud and make sure you're not pulling any hoses, wires, or cables) then you can pull off the axles. You just need to give the transmission a little lift to get enough clearance. :]
  19. No luck looking at the suggested SERA484-10 TPS as a possibility. It arrived on Friday and I took a look inside. Knowing the wiper function of nearly any standard potentiometer is reversible I hoped to use the same trick here but no joy. The total resistance value of the carbon trace is in the proper range but the wiper does not maintain contact with the trace throughout the full range of the sweep. That means it can't be reversed. I was counting on being able to invert the pot function and maybe 3D printing some of the plastic bit to make a mirrored version. I could probably make it work if I had no other choice but it would not look pretty.
  20. Well, in my infinite genius I made a pretty big oopsie. While replacing the front struts, I somehow broke the driver side drive axel! I can fill it in the boot, its somehow become detached at the joint where it meets the hub. I must have bent it in a bad angle or something. I was able to get a replacement, but my predicament is this: In a video by a Miles Fox on YouTube, he pops out the axel out of the transmission using a breaker bar against the hub, however since its broken at the hub, what would be the best way to get it out? I have replaced an axel before in a Jeep, and it was able to just come out, but from what I can read in the manual and see in the video, these seem to be different, with a slide pin and stuff.
  21. I think that you are right to suspect the drive-shaft. The drive-shaft shouldn't be able to be moved by hand. It should be rigid, not soft - especially in the radial direction. A passenger in the back seat might be able to tell where the vibration originates.
  22. The factory retorque procedure seems like a massive pain. Torque once using 3-step torque increments, reassemble and install the engine, get it to operating temp and let cool. Then loosen the intake manifold bolts and take off the cam carriers (may as well remove the intake manifold and pull the engine again), in the same torque order loosen the head bolt 60°, oil the threads between the washer and the head, torque to spec. Repeat on every bolt using the head bolt sequence 5 times. Then retorque one final time without backing off the bolts. Reassemble. I have no issue doing this to prolong the life of the head gaskets but I does seem like a PITA.
  23. So no change or updates since your last post of the same content? Since there is no reply to your proposed variable switch I’m guessing it’s not a common thing to do. Why not just replace the knock sensor and be done with it?
  24. I have accessport manager 3.1.9 and a bunch of different tunes available. Not sure if there is one for secondary air pump delete. Below are some of the tunes Filename Vehicle Economy Mode v350.ptm 2006 USDM Imprez Economy Mode v400.ptm 2006 USDM Imprez Stage v400.ptm 2006 USDM Impreza Stage 91 v350.ptm 2006 USDM Impreza Stage1 91 v350.ptm 2006 USDM Impreza Stage1 91 v400.ptm 2006 USDM Impreza Stage1 91 v400.ptm 2006 USDM Impreza Stage1 93 v350.ptm 2006 USDM Impreza Stage1 93 v350.ptm 2006 USDM Impreza Stage1 93 v400.ptm 2006 USDM Impreza Stage1 93 v400.ptm 2006 USDM Impreza Stage1 ACN91 v350.ptm 2006 USDM Impreza Stage1 ACN91 v350.ptm 2006 USDM Impreza Stage ACN91 v400.ptm 2006 USDM Impreza Stage ACN91 v400.ptm 2006 USDM Impreza Stage1 +EBCS 91 v350.ptm 2006 USDM Impreza V Stage1+EBCS 91 v400.ptm 2006 USDM Impreza V Stage1+EBCS 93 v350.ptm 2006 USDM Impreza V Stage1+EBCS 93 v400.ptm 2006 USDM Impreza V •Stage1+EBCS ACN91 v350.p... 2006 USDM Impreza V Stage1+EBCS ACN91 v400.p... 2006 USDM Impreza V Stage 91 v350.ptm 2006 USDM Impreza W Stage 91 v350.ptm 2006 USDM Impreza W Stage2 91 v400.ptm 2006 USDM Impreza W Stage 93 v350.ptm 2006 USDM Impreza W •Stage 93 v350.ptm 2006 USDM Impreza W Stage 93 v400.ptm 2006 USDM Impreza WI Stage2 ACN91 v350.ptm 2006 USDM Impreza WI Stage ACN91 v350.ptm Stage2 ACN91 v400.ptm 2006 USDM Impreza WF 2006 USDM Impreza WF Stage+EBCS 91 1050x v35... 2006 USDM Impreza W
  25. The 560k resistor in place of the knock sensor seems to confirm the knock sensor as my problem. The on / off cut-out bucking is gone, only a significant flat spot in the low rpm range, feels like a fail-safe scenario or similar sensation. I only drove a couple of miles before parking at the shop for the mechanic to get data while driving, he has a really nice tool for that. I’m hoping he gets the time to work on this soon. Meantime, I’ve been reading a conversation on this forum where Blitz has responded to the topic “hesitation” with a solution to the nock sensor involving a variable switch to add resistance manually to the circuit. He also had removed to knock sensor . I’ve been curious if anyone has solved the knock sensor issue with a combination of a resistor in series with the knock sensor. My mechanic says that might be something to consider. Thanks for any thoughts
  26. I was a long time ago that I did an EA82 headgasket job - I don’t recall there being instructions to back off the head bolts in the process! Just use engine oil, nothing special required. If you dip the first 5mm of thread that should give you heaps of oil to play with. If you can use an engine stand with the cylinders vertical (engine 90° rotated), this will help keep the oil in the holes and not on your new head gasket. Oil pan, drain it. Then pull it off to clean it out. Reseal with quality sealant. Cooling passages - you’d probably be better off hitting any passages you can with a high pressure washer before starting any real work on the rebuild side of things. Just running water once the work is done won’t move anything. If it’s looking really nasty, getting a rod or a screw driver in there to remove scale can be effective. Ensure you get this crud out. When putting everything back together, clean all mating surfaces then wipe with methylated spirits or some alcohol wipe that completely evaporates without leaving a residue. Then apply your goo or gaskets etc and torque to spec. After about six months of continuous driving, it should develop an oil leak if you’ve done things right (joke! It should last longer than this!). EA82s always leak oil! On that note, they usually leak from the cam box where the sealant is the only barrier between the engine internal environment and the rest of the world. I hated this seal! Best method I found was to clean as described above, apply silicone to fill the channel and the edges of the mating surface. Then sit the cam box on the sealant and leave it to harden a bit before torquing the cam box down properly. And the VERY BEST method I found for EA82 oil leaks was to EJ it. The only EAs I tinker with now are EA81 units 😎
  1. Load more activity
