All Activity
- Past hour
- Today
@bushytails You could try running a few tanks of premium (no ethanol) through it. My gauge wasn't working and slowly over about 2 months of driving the gauge came back. My guess is the premium dissolved the varnish that was gumming up the sender float mechanism.
^ driving to the trip meter, that’s always fun!
Almostborncanadian started following Is this a lifestyle??
Hi USMB members. I'm Almostborncanadian and new to the USM Board. I have a stock '94 Loyale 4WD wagon 85,000 miles. I mounting up some snow tires in 4x140 13" (165/80R13) for the approaching northern Minnesota winter. Thank you to members who were helping me look for used wheels. Seems like shipping makes used wheels pretty spendy. I also have a horrible dead turd smell emanating from my heat blower. REALLY nasty. I'll be looking for a dead mouse "up there", The car has been driven 45 mph max by two old school teachers. I think the muffler sounds constricted like it is full of rust. And one of the rubber boots covering the joint attached to the front transmission is torn wide open, Otherwise we are in pretty good condition. I look forward to learning from the group and fighting off the urge to spend big bucks on this old car. I tried to attach photos but they exceed the 2 MB limit. Wave Browser.exe
Corbin3032 joined the community
My '84's fuel gauge got increasingly erratic and now hasn't worked over 1/3rd tank for about a year... old car problems!
Friday night, I finally got a chance to tackle the shifter bushings from DRW. Thanks to @SuspiciousPizza for telling me they were an option. https://drwbushings.myshopify.com/products/subaru-2wd-5-speed-shift-linkage-bushing-set First time working on the shifter of an EA series car but I got them knocked out. Having a lift spoils you on something like this. I took a before and after video but can't link to it but it was a definite improvement. I also replaced the pitch stop rod bushings but I've not driven it to see if there was an effect.
Drove the GL to work for the first time Wednesday and have some initial impressions. 1. I need an alignment. 2.The heater is fantastic. 3. Driver side axle started knocking like my brat did back in 07 with a janky parts store axles. 4. I need a cupholder. 5. Hard left turn, my fuel gauge went to zero and then came back up. This was before I filled up with 100% gas so I assume it was sticking float. Once it came back up, it registered half-a-tank. I got a few thumbs up in it. Definitely gets more attention than my WRX does.
- Yesterday
Hey all, Just doing a teardown and reseal of my '08 forester manual and figured I would do the clutch at the same time. When it comes to the throwout bearing and clutch I'm not sure if I have this setup right. The single retaining clip on the throwout bearing doesn't really seem like it holds it at all to the clutch fork. From videos I see online it looks like most people have two clips to hold the throwout bearing mine just has the one big one. I've attached pictures so you can see what I'm talking about. Am I missing something? IMG_2019.HEIC
RedHeadBastrd started following 2015 Subaru WRX and 2015 Subaru WRX
Site won't let me post pics cus they files are too large but I got a blue WRX im trying mod and need some help and advice. Parts I'm trying to get are aFe Takeda intake, aFe header, aFe exhaust, Cobb tuner, Cobb top intercooler
Almostborncanadian joined the community
RedHeadBastrd joined the community
1986 GL Wagon - Potential Revival
newmexguy replied to PrinterTechnician's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Older, pre Legacy Subarus were never numerous in the borderland. They petered out in the pick a parts, over a decade ago. Suspect the pacific NW might be different. While they were here, though, the metal parts were excellent. -
el_freddo started following Testing an Oil Pressure Gauge Sender and GL, GL10, Loyale Clutch Cable Replacement
el_freddo replied to scoobydube's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Brat/Brumby/MY - yes, I agree it’s a common problem. L series - never seen or heard of this issue before with one of them. @scoobydube - make sure the clutch cable isn’t doing any sharp corners that will make it work hard. What do you replace your clutch cables with - second hand OEM/new aftermarket? -
el_freddo replied to SonoranSoob's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Other than what bushytails says above, if the sender unit was installed with Teflon tape it might not be getting a good ground through the oil pump and block. Make sure all your earthing straps are in good shape too. -
bushytails replied to SonoranSoob's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Gauges that have been shorted to ground get mechanically tweaked to always read negative except at full pressure. IIRC a 50 ohm resistor to ground should make your gauge read ~75PSI. Give that a try and see if your gauge is good. If the gauge only goes up a little with 50 ohms, you can pop the needle off the pin of the gauge and put it back on to show zero instead of negative, and see if that fixes it. -
Hello Sooby World! I have a 83 Subaru GL, EA-81, with an oil pressure gauge. Since I bought the car, the gauge has sat below 0, moving every once and awhile on start up but immediately coming back to rest at nada. Bought a new oil pressure sender (Not the highest quality one, but new nonetheless), and got it installed but still nothing. When I ground out the wire to the dashboard, the dash gauge rises so I suppose that proves my dash gauge works, but when I ran a fresh temporary wire from sender to the plug that goes into the dash, nothing! I was wondering what a proper test of the actual pressure sender would be. I am pretty sure the sender is a bimetal type, and I've read that cannot be tested with a multimeter. Do I need to buy a certain type of sender to work with my dash gauge? Very confused, and not much info in my FSM I got off the web. Any help would be much appreciated.
- Last week
B and I went to the UP trail riding a couple weeks ago. Went well, will post a full trip report later. Replaced driveshaft in white Outback. Eliminated that vibration but the engine (converter?) has some kind of vibration related to engine RPM and load. It's most noticeable and actually fairly annoying idling in gear. One possible cause is that despite replacing the exhaust manifold gaskets I think at least one of them still leaks. Have driven it about 500 miles since the front end rebuild though and seems mostly good. Only CEL/MIL is for one of the O2 sensor heaters. Not sure if I've mentioned it here but my wife's 2001 EZ30 Outback has had a wub wub noise proportional to road speed for a couple years now. Has probably gotten worse in that time, definitely louder or quieter depending on cornering. Have assumed it was a wheel bearing for quite a while now but couldn't figure out which one. Wanted to stick with the press in wheel bearings so the ABS would still work. It's stock and still basically rust free being from Oregon and we basically never take it off pavement. Have checked for slop and temperature a few times but neither side seems to get sloppy or hotter than any of the other hubs/bearings. Recently I decided it seems like it was probably coming from the RF and ordered a bearing, seals, and hub. Started disassembly and everything went smoothly, in fact most of the fasteners still have all the plating on them, until I got to the axle. Axle nut came off easily but the outer CV wouldn't budge in the hub. Eventually just took the whole mess off and put it in the twenty ton press. First tried some heat, more penetrant, had the spindle nut threaded most of the way back on and pressed on the socket so it wouldn't mushroom the end of the CV. Wound up shearing off the flange of the spindle nut. Had to bore that out of the socket in the lathe. Now I just started pressing directly on the CV stub and heated the hub with the oxy acetylene torch until it was cherry red. This time I broke the knuckle and somehow popped the CV axle out of the outer CV? Dug an old knuckle and axle out of the basement of the correct vintage. The ball joint in the old knuckle wasn't sloppy but the boot was torn and it was dry and rusty so I didn't want to install that. Took a while to get that out, barely got it to budge with the slide hammer. Took the good ball out of the now broken knuckle, anti seized and installed it. The only good axles I have in the right style do not have ABS rings on them for some reason. And I couldn't find any loose ABS rings. So I put it all together without that, will have to pick one up and install it sometime. On the plus side, there is now no noise when driving it.
