All Activity
- Today
Howdy, folks! I just bought a '93 Justy up in Oregon. I needed an economical daily driver. What I DIDN'T need is another oddball car with an orphaned engine that takes WAY more work to find parts and support for. That's why I'm here. Oh, well, these kinds of vehicles are in my DNA since forever, and apparently, I can't resist. I think the Justy is going to be fun. Hoping to gain some knowledge here and also add some as I dive into it, which is already happening fast..
itestpilot joined the community
None of that, hahaha. This thing stays in my shop so it's never really below 40* unless I have the heat on out there. Hope to find some time this weekend to take it up the road. We stay so busy with my son and basketball and work BS, Plus, I have 3 other cars of my own, not including the wife's.
Yeah fair enough! You didn’t do the “mandatory” double pump if the throttle before turning the ignition on? Or the other way to do it is ignition on to prime the fuel bowl, ignition off, double pump, ignition on and start. I do this one when I haven’t driven my brumby in a while, especially in summer when it seems the bowl evaporates and needs filling again.
- Last week
There's a front right Sachs 4WD strut on Parts Geek right now. There's only one in stock so if you need one, now's your chance! :]
Looking for a driver side rear door shell
SubsPNW replied to SubsPNW's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Sorry, been off-line due to a cold. I am working on another door that is a little closer to where we live. If it is rust free we are going to go with it. I should know by Wednesday afternoon (hopefully sooner). -
You should always hit the gas pedal at least once before cranking, to close the automatic choke.
Ehh, a couple people have and I don't care to do stuff for people I like. Since it's his personal and I'm buying the filament with my money, we don't really have to as work doesn't own it. Key issue update: I did start it yesterday after doing some serious keyhole dousing with contact cleaner and compressed air. Didn't get any smoke but still unhooked the battery to it just for peace of mind. Old girl did start on the 3rd crank without hitting the gas pedal.
Yeah nice! We have Bambu X1 Carbon and I think a P2H - but that one is in another department as such, I might get some playtime on that this year. We’ll see. That first print is classic. Do you guys have everyone asking you to print this,that and everything in between?
It's a Bambu P1S. I have never used one but first job I sent to it was this. Was a big hit in the office.
That pretty much confirms it's inside the trans. Though, when I had 2nd let go on one, it broke off an entire tooth on the small gear only make a light clicking noise, and lodged the tooth in the center section. Draining didn't find anything, only taking apart showed the issue. Though with how old yours is, it might also be loose bearings causing enough slop to make that constant noise
Have you drained the gearbox oil and see what comes out with it? Also carefully feel around inside the gearbox through the drain hole for any other fragments that may be present. Noise will travel to different areas. You’d need to use a dowel/long screw driver/stethoscope to pinpoint where the noise is coming from more precisely. Seems more likely that second gear is chipped, possibly both gears - if that’s the case you’d get an un-rhythmic sequence that will repeat after some time. This is because all gearsets have at least one gear that’s got an uneven number of teeth so they wear all teeth against each other for even wear across all the two gear cogs’ teeth.
82baru replied to SubsPNW's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I've got a 1982 GL Wagon rear driver-side door in pretty good shape (see photos). There is some minor rust in the bottom left corner of the exterior. Let me know if you're interested. -
I hate things that stick up from the center console... always hit my elbow on them. Even the raised part on the power window models is too high. I usually drink bottled water with screw caps, and tuck it between the seats - with the back seat bottom folded forwards, there's a nice cubby there for my drink bottle. But I have to make sure it leans to the right, not the left, or I still get my elbow on it. lol
For functional and tough parts my go-to is Armadillo by Ninjaflex. It's a very high hardness TPU so it acts like a normal rigid polymer but it has a very high bond strength between layers. It takes some tweaking to get your settings dialed in and may require dual-extrusion or a multi material unit when you print support material. Since it bonds so well to itself, getting supports off without cutting and sanding tools isn't easy. The best overall bed adhesive that works with almost all polymers, that I've found, is normal white school glue spread with a damp paper towel (3 quarter-sized dollops spread thin). Once that dries, lay a layer of Magigoo PC bed adhesive over that. That coating will last 3-10 prints before you wash it off with dish soap and reapply. I've wanted to print a cup holder. Right now I'm just using a cardboard drink carrier I got from a coffee place on my passenger side floor board.
The path from where the key goes to the ignition switch itself is long and not direct - smoke may escape through it, but you're not getting any liquids into the switch that way. The switch is only two screws after you take off the shroud - pull the switch and work some contact cleaner in around the plastic piece in the middle. The switch can't be taken apart, so just spray a bunch around the center plastic piece, spin it back and forth a bunch of times so it wicks in, repeat repeatedly.
Im super keen to play with ABS. Messed around with PLA heaps. Designed lots of stuff to - all school based for students m. Been an awesome journey though! What model 3D printer did your boss get?
I also tried my hand at printing two different versions of the center cap retaining rings. Did one in PLA that was way too long and the other in the same ABS but it snapped on me as a I tried seating it today.
Update. Had to remove the water pump and replace and reseal with a different RTV. The water pump flavor of Permatex was garbage and never sealed up. Used "The Right Stuff" this time and replaced the leaking 90* crossover hose. Tedious as hell, but no biggie. De-pinned and replaced the alternator plug that had a broken clip on it. Finally snagged a blue steering column shroud. Didn't take a pic unfortunately. Boss got a 3D printer for Christmas and brought it to the office so I been wearing it out. Made me an ABS cupholder. Next issue: My son had noticed it a few months ago but I was finally able to see it myself last night but I had electrical smoke coming out of the ignition switch where the key goes. Honestly, didn't know that was possible. I know the PO had replaced it at one point because he said the OE was worn out. I know it had quite a bit of grease down in it. For the time being I'm leaving the battery unhooked in my shop and douched the hell out of the keyhole with electronic contact cleaner and compressed air.
Returning after years...
moosens replied to msteel's topic in Meet n' Greet. Your USMB Welcome Center
Great to see you back. Enjoy your time. Lost count of how many times I’ve typed “save the dual range fivespeed” In exclamation. Good luck. I think you’ll score. Those cars mentioned, kind of parallels our own at one time. We just sold our 2006 OBW seems either you get a good one or one that’s constantly having issues. These days my daily addiction is the 2000-04 Legacy/OBW but yet to own the 2004 with the fly by wire. Having that in the 06 scared this old dinosaur. The vehicles that are fly by wire these days are many and I’m just taking a while to accept that. -
egowing, I'll pull the wiper arms tomorrow - I'm assuming you want the fronts and back?
