All Activity
This stream auto-updates
  1. Past hour
  2. B straightened out the upper radiator support on the Outback. We cut out the lower radiator support. Hung a straight radiator and the condenser from upper support, hood closed, and started mocking up a new lower support. Got a piece of 3" square tubing to use for that. Put the main bumper beam back into place, squared it up, and cut a new mount for the passenger side. Will post pictures of all that later, planning on doing some fab tomorrow. The main damage to the engine seemed to be where the oil cooler/filter threads on to the block. I tapped it deeper and used one of the longer pipes we'd made when I did the same thing to the black Outback. Also like that time though the block has a hairline crack which was spraying oil everywhere. I cleaned this one out and then poured some super glue in the crack from the inside and outside. Then applied three layers of JB weld. Not real pretty but I ran the engine for a bit and I didn't see it leak a drop. So fingers crossed that will be a semi permanent fix.
  3. Searching around for a pump that will work. My local parts store carries this pump: https://www.rockauto.com/en/moreinfo.php?pk=1111648 Thoughts on this being a viable replacement?
  4. Today
  5. Well wish I had done this check sooner! I'll see if I can find a pump and swap it out. Thanks!
  6. For SPFI models, the fuel pressure discharge from the fuel pump is 36-50 psi. After the regulator is 20-24 psi @ 700rpm. The regulator drops the high pressure from the pump to a usable pressure for the injector. So there is a high pressure side and a low pressure side, separated by the fuel pressure regulator on the throttle body. Could be an issue with the fuel lines or filters. But most likely the fuel pump is tired and out of spec.
  7. The 560k resistor in place of the knock sensor seems to confirm the knock sensor as my problem. The on / off cut-out bucking is gone, only a significant flat spot in the low rpm range, feels like a fail-safe scenario or similar sensation. I only drove a couple of miles before parking at the shop for the mechanic to get data while driving, he has a really nice tool for that. I’m hoping he gets the time to work on this soon. Meantime, I’ve been reading a conversation on this forum where Blitz has responded to the topic “hesitation” with a solution to the nock sensor involving a variable switch to add resistance manually to the circuit. He also had removed to knock sensor . I’ve been curious if anyone has solved the knock sensor issue with a combination of a resistor in series with the knock sensor. My mechanic says that might be something to consider. Thanks for any thoughts
  8. I measured between the fuel filter and the throttle body. So I suppose this is before the regulator. I assumed the regulator would change the pressure in the entire system but if I’m supposed to be getting almost full potential psi from the fuel pump then I guess there’s my problem.
  9. Fuel pressure is not building with key to on, but not started. If he sprays a little starting fluid in, it will start and run and fuel pressure is 35psi. Fuel pressure drops to zero when the car is shut off. Both engines had this issue and it was a complete swap so the fuel pressure regulator, fuel injectors... have all been changed by the engine swap. Hard troubleshooting from 3500 miles away.
  10. Yesterday
  11. Did you measure before or after the fuel pressure regulator? If after, that seems pretty close but others more experienced would have to let you know for sure. If you decide to pull your injector, I've found a large needle nose vice grip works the best. Don't use the straight part of the jaws, rather the semi-circle part of the jaws works very well. You may have to spin the injector to loosen the 2 o-rings. Be sure not to lose the 3-padded metal ring the injector sits on top of. Throttle body & injector gasket kit I use is Walker 18015.
  12. Late to the party, if only doing clutch I drop the gearbox. On our 2000 Liberty/Legacy, I pulled the gearbox and managed to slide it back enough to work on the clutch and swap it out for a new one. This saved dropping the gearbox, I can’t remember if I managed to get away without removing the drive shafts. If I needed to it was an easy wiggle one way then the other with the gearbox because my model has diff stub axles, yours will have the male driveshafts into the gearbox to contend with. I used two steel rods that sat on the engine crossmember and the front gearbox crossmember piece. The rear crossmember and centre piece was removed, as was the gear linkages, tail shaft and exhaust. Where there’s a will there’s a way. These days I find it easier to drop the gearbox rather than lift out the engine. I put the car on ramps and go from there. If dropping the gearbox out all together I use a motorcycle jack and usually need to get the car up higher to clear the bellhousing as the engine comes out from under the car. Cheers Bennie
  13. Last week
  14. Alright folks, installed the new solenoid and still having the same issues. The CEL is now off and I'm not getting any codes from the ECU. Just checked for vacuum leaks again and it doesn't seem like there are any. Out of curiosity, I double checked my fuel pressure and am getting 19/20 psi. Is this close enough to the spec of 21 psi? And if so, would a good next step be to check the fuel injector to see if there are any issues going on there?
  15. Thanks for the info guys! Yeah I figured it might be like that. Awesome! Thanks for your help!
  16. My 2008 Subaru Outback Sport has been involved in a wreck and likely needs to be totalled. CarFax does not show a transmission or engine replacement but I bought it having been told one was replaced. The VIN is 4S4BP61C287310455. I think I found the transmission sticker itself so the first thing is "is this the transmission tag". I have attached the sticker. I have spent many hours trying to decode and just overwhelmed. There wasa another similar sticker about two inches away with no writing left that I can see.. I am trying to prove this is a replacement from the original transmission. I am going to go back tomorrow to the salvage yard and look on the passenger side door and just trying to do everything I can to prove this. Does anyone have any advice?
  17. https://www.ultimatesubaru.org/forum/topic/145506-ej251-engine-weighs-119-kg-262-lbs/?do=findComment&comment=1222275
  18. If you have other engine maintenance to do, pull the engine. Yes either works. Reseal the oil separator plate behind the flywheel. RTV - gray. Get the metal plate if you'r is plastic.
  19. As others have said,, replace them. Just the EJ22 had composite gaskets. The early EJ25's had single layer gaskets, they later went to MLS types. O.
  20. I've done it both ways but without help or a tranny jack, i'd lift the engine. You have to get it up high and its no fun wrestling that weight. Yes you have to drain the coolant and separate the exhaust (don't forget to disconnect the O2 sensors), but I can do this without help. O.
  21. Using your heads and intake manifold any 2000 to 2012 will work. Better options would be 06 up. In 05 Subaru went to Drive by Wire . The Radiator and water pump housing leads are in slightly different places, so don't cut those hoses you may need them. Depending on block year, you may need the radiator. You can use an Impreza block, but the oil pan is different. I believe those are the differences. If I think of anything else, I'll chime in. O.
  22. I am looking for all options for a replacement engine for my son's 2007 outback wagon with a standard EJ- 2.5. The block is bad, the head are ok. I know that engines from an outback and legacy work. If someone can confirm which years exactly and do Impreza 2.5's or forester 2.5 blocks work? If so, which years? Thanks in advance.
  23. 2007 Outback legacy is it easier to drop the transmission to change the clutch or pull the engine? Odd question maybe. I can’t find any information on the weight of the 5 speed manual that’s in the car. I don’t have a lift but i do have a cherry picker. I’m just not sure if I can get the car high enough to drop the transmission. What have you guys done? Thanks
  24. That was the first real drive I've done in it since getting the blower going and I did notice I had good heat at the feet so at least it's flowing through the heater core. I'm going to get a plan of action with this radiator since it's currently dripping and I'm going to be changing the lower hose that's been roadside-repaired with a union piece.
  25. They're going 65mph in the photo... at that speed, it should be firmly at the bottom line, where the thermostat opens. EA81s aren't picky about thermostats, since they're on top like most older vehicles - it's the newer EJ motors that have them on the bottom that are super picky. My first guess would be a clogged radiator. Where on your temperature gauge does the thermostat open? From a cold engine, keep feeling the outlet side. It'll be cold and then suddenly hot when the thermostat opens. Then keep watching the gauge, and also note where the electric fan kicks on. These are your reference points for where the gauge should read. On level highway it should be at the point the thermostat just opens, and it should never exceed the point where the fans kick on, at any speed.
  26. I noticed that as well when I was driving it. I do know that I have a seeping radiator and trying to get a plan in action to either get it repaired or find a replacement. I did order an OEM thermostat this morning because I know how finicky the EA81 can be about aftermarket thermostats and I have no clue what's in it. The good news is the fan does run, unlike the others that I had that ran the fan all the time. My brat with an OE thermostat usually sat around this line that I have marked and I watched it constantly. I am also going to replace the radiator cap. Are the Stant ones okay? I asked my dealer and I can't get an OE one anymore.
  27. I, personally, would not worry about the temp gauge. To me, that’s where I would want it to be, about the middle. I have never owned an EA81, but my ‘04 Nissan, my daughter’s ‘02 Outback and my wife’s ‘17 Legacy, all run in the middle.
  28. I always replace them. I have found water in the cylinders. #642 subaru MLS is the one you want. https://www.ebay.com/itm/132854879269
  29. I'm not familiar with the older gens. Does each line indicate something? Like first line is where the thermostat opens, second line is "high normal op temperature", 3rd is "dancing with danger" and 4th is really not good? I've never opened an older gen FSM or owners manual, let alone seen an older gen in the flesh other than a BRAT at a car show once. Are the dash readouts known for any inaccuracies such as the 3rd gen oil pressure gauges being quite vague?
  1. Load more activity
