All Activity
- Today
- Yesterday
Thanks everyone. I just discovered the new iteration of the bracket involves a few different mounting screws that I need to get, along with the newer tensioner style. I tried to helicoil the stripped holes and did not execute it properly... so now im looking for the discontinued part (13086AA012). This engine is in pretty decent shape from what I can tell, has never overheated when ive had it. But I believe you are right, el_freddo that the threads had previously taken a beating. Its the 2 tensioner (not pulley) bolt holes that got stripped. Long story about the failed helicoils... ill spare you the details. Anyhow the dealership didnt seem to understand how to make the new bracket work for this car so I believe Im just going to pursue finding the discontinued part, if that doesn't work Ill look to "modernize". Thanks any tips on this part would be much appreciated.
91 Loyale wagon 4wd value
SuspiciousPizza replied to somarkram's topic in Old Gen.: 80's GL/DL/XT/Loyales...
There is a market for these cars in the Midwest, it's small and niche so not exactly the easiest market to get into. You gotta know someone who's looking to buy and you gotta be selling what they're looking for. The reason you can get some decent scratch for a DL/GL/Loyale (especially a BRAT) is because a lot of the cars rusted to bits. They make great hunting rigs (they're small, quiet, and a D/R trans does well on logging roads), they're great winter cars, they're great farm vehicles. I'm not looking for a disagreement, just pointing out that if anyone is looking to sell, there are buyers up North willing to shell out for these little cars. :] -
newmexguy replied to somarkram's topic in Old Gen.: 80's GL/DL/XT/Loyales...
- Last week
Calling All Dual Range Owners
czny replied to SuspiciousPizza's topic in Old Gen.: 80's GL/DL/XT/Loyales...
And, most of the old threads here on USMB lost all pics thru fotosuckit or changes in forum hosting service changes. PM Crazyeights to see if he still has some pics & such for 5 MT d/r transmissions. -
el_freddo replied to SuspiciousPizza's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Hmmm, I can’t think of anyone off the top of my head that’s written up a tutorial. It’s one of those things that you just get into and forget to take picks etc as you go. Re: silicone. Just lever on the plate, the silicone will let go. The trick is not to damage the mounting face. Cheers Bennie -
I finally got an easy one! The 2002 was missing intermittently, bad enough to affect driveability. We got under the hood and tried spraying propane from an unlit torch along the vacuum hoses, for just in case it had a vacuum leak. No luck with that, but I did hear a tick each time it missed. I started paying attention, and was able to see a spark jumping from one of the coil end plug wire boots to a rubber hose! The boots had gotten dirty, and the medium voltage had made a track to ground. I pulled each boot and wiped the outside of the boot with a rag moistened in WD40, and wiped the dirt and carbon off the coil where the boot plugs on. FIXED! New plug wires are on the way. On a side note, we tried sticking the unlit torch into the air intake and opening it as wide as it would go. Couldn't hear any change in the motor noise. That trick might have worked with carbureted engines, but it doesn't seem to work with this engine.
Here's some reading for you before you dive in to that "spare". https://www.ultimatesubaru.org/forum/topic/121582-transmission-reseal-new-bearing-with-pics/ https://www.ultimatesubaru.org/forum/topic/95638-411-awd-dual-range-in-legacy/page/2/ https://www.ultimatesubaru.org/forum/topic/100318-ej-dr-tranny-s-from-nz-ive-read-many-recent-threads-want-newest-info/ Can't recall which long gone member had a complete tear down description, but I think el freddo might know. Gloyale did some, el freddo did some. -
scruff started following 6 lug swap question. and Daytime running lights
Factory EA82 studs have about a 14.2mm knurl diameter (according to the Dorman listing), new gen Subarus are 14.38 (but the shoulder is too long for EA applications, as the rotor doesn't slip over the studs). Looks like I used a 35/64 drill bit (13.89mm). I also used Dorman 610378 studs, which have a 14.48mm knurl diameter, smaller head (easier to seat with the curved material on the back of the hub where they need to be), about 10mm longer overall, but short enough shoulder even for steelies (open lug nuts required, though).
- 1 reply
- 1
Most shops are willing to press a bearing into a knuckle for a nominal fee. This would be far cheaper than replacing all those parts. Same amount of labor. Only downside is having the car apart for a trip to a shop. Heck, probably would still be economical to buy a junkyard knuckle and have a shop press in bearings. We had a customer bring their car into the dealership where I work for a rear bearing. Turned out it had a complete aftermarket knuckle installed not long ago (not purchased from a retailer willing to help with the replacement cost). We tried to install an OEM bearing, and it didn't fit! We had to replace the hub with an OEM one as well. Just another story of the risks of cheap parts.
SuspiciousPizza replied to SuspiciousPizza's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I have a 3 day weekend coming up so I'll be taking the time to begin trying to take it apart then. I found a section 1-3 FSM for cheap on eBay so I don't have to wait around to get my other one back. I tried taking the T-case cover plate off last night to see if there was anything obvious. The RTV is gonna be a headache, it seriously doesn't wanna budge. Glued, screwed, and tattooed down. My idea for dealing with the RTV was getting it hot with a torch and gently using a razor blade to cut into the softened sealant. I do worry about residue from burning. I'm just going to have to be very thorough with cleaning the internals. I'll be recording as much of the disassembly as I can/remember to. I'll be posting links to the videos when pertinent. I'm kind of glad I got a "broken" box, now I can practice servicing one without the stress of potentially damaging a good transmission. There'll be more to come :] -
Hmmm… think I’m looking at EJ cases too much these days, I don’t remember the top of the bell housing being so rounded. And those dowel hole up top - never seen that before, maybe a series 1 thing, I haven’t played with those gearboxes before. Cool audio clip. Could be many things - crown wheel touching the low range selector ring if they did a diff ratio swap (in which case, have a look at the pinion shaft for a weld mark); reverse gear partially engaged enough to click/grind like that - or a partially engaged drive gear for that matter too. So many possibilities of what it could be. Either way, don’t just drop that box in (as established)! Looking forward to autopsy pics Cheers Bennie -
You guys are awesome. Thank you for replying. I thought about the ebrake thing also. Lifting up on it slightly when pulling in the driveway starting to be a pain. I could look up schematic and use a jumper wire but maybe as a last resort. I'll look into that module. Must be the drl module that's being talked about?
