All Activity
This stream auto-updates
  1. Past hour
  2. I vaguely recall sohc single port EJ22 is an oddball thing somewhere around 97 when they went from phase 1 to phase 2. Are the valve covers on the heads the old school ones that have "16 VALVES" imprinted on them? \ If it's an 99 ecu, it's probably not really meant for those heads, probably why performance is poor. Good and bad is ecu is fairly simple and doesn't care which block is in there. Swap in the 2000 block, it's what the 99' ecu wants over all. Or if your state emissions doesn't care, drop in an 97-98 ecu and it might fix everything; if the current block has good compression and no mechanical issues.
  3. Did a little more weekend deathwheel work today - took about an hour to get some access panels cut into the bed floor so I can more easily add some gussets to the subframe while it's bolted to the assembly. The idea here is that I'm going to use them both to reinforce the subframe and it will give me a locating feature when I go to tack this piece into the car so everything lines back up. The idea here is that I'm going to use them both to reinforce the subframe and it will give me a locating feature when I go to tack this piece into the car so everything lines back up. I've still got to take things in and out a couple times before this becomes a more permanent part of the vehicle. I'll probably weld the panels back in once I'm satisfied with the subframe and suspension towers, as some of these welds I'm planning on leaving only semi-permanent till I've got all the clearances worked out with the coilovers, so I'll be leaving access until I'm sure I don't need it anymore. This last photo looks real scary but in reality it's just me adding four tack welds to the gussets only on the subframe. I'll be removing it one last time to box everything in and hit it with a bit of weld-through primer. Folks with a real professional background in automotive engineering would probably cringe at some parts of my approach, but I got everything measured up as even and straight as a mallet and tape measure would allow. I'm honestly pretty impressed with myself at how evenly I was able to get everything to line up with a couple symmetrical features I used as reference points (a couple bolt holes and a few key bends/seams. I find myself repeating the mantra "perfection is the enemy of progress" a lot on this build, and so far (knock on wood) it's working out pretty good. Next up I have a fairly short punchlist to get this subframe on the car in a meaningful way, and then I'm planning on attacking the lateral links, trailing arms, and locating the strut towers. The more I think on it the more likely it is that I'll probably be scrapping more of the Impreza tower than I'd intended. The rust is pretty deep in the driver side tower and the more I stare at the mockup as it sits the more dislike the way it looks. One way or the other I'll figure out something good. Main goal is to have it back on its own four wheels (again) around the new year. We'll see if I make that goal or if I blow past it for some unforeseen reason. Hopefully I'll have at least one more update before the New Year, but if you don't hear from me beforehand, have a good last few weeks of the year, everybody! -M
  4. Freaky build thoughts welcome here. I don't think inboard brakes are going to fit on the setup i'm planning, but someone wily might be able to make em fit on a closer to stock undercarriage. I'll probably just be swapping the knuckles to add discs on this one once I've got the suspension set up in the back end.
  5. Yesterday
  6. Shows the mentality of most of these places. Still remember finding a first gen Monte Carlo atop a heap, in a New England yard in the late eighties. Late in the day, on a Saturday. No time to pull perfect dashboard with complete harness. No time off during week. Asked them, very nicely, can this be saved until the following Saturday? Yeah sure buddy. Of course, when went back next Saturday, they had forked the hulk, through the windshield, moved the forks up and down, and destroyed the dashboard, along with the once perfect dash pad. A several hundred dollar sale, out the window. Typical.
  7. You have tried: www.car-part.com? www.row52.com? Row 52 is nearly flat-lined, but they still list stuff in California yards. Most other states have dropped off their database. And no more pullers. Yep, I tried that, meaning a puller on their site, thinking, wow, I can sell here too. Nope, it turned out to be a joke. Every puller I sent a message to, didn't respond. No responses to my ads. No responses to replies to their wanted ads. Really? A couple of requests - for $5 to $10 plastic parts in Albuquerque area yards - 200 plus miles N of my location. Okay, am going to spend 8 hours total seat time - to chase plastic parts - that are likely either GONE, or DESTROYED by the SUN. You're kidding me. A complete waste of time, regrettably. Those cars have dissipated from Borderland yards. There were never many here, anyway. The local yard had three subarus when they crushed out - a '77ish coupe, an '84 wagon, and an '87 wagon with a dual range transmission. All were too risky to buy and try to resell, due to several factors. Limited market. Distance from potential "buyers". LOGISTICS (the gorilla in the room) or the physical act of moving the stuff.
  8. That's a great question. I'll have to do a compression test when I go to my buddy's to use his shop. Our work schedules and other plans makes it difficult to find the time to meet up. It seems to be running better with the new ECU. Not perfect but I trust it for driving to work and back. Which is all I need the car for. I noticed it'll stumble after I start it when it's hot. Say I get to my destination, after I start it to leave, it'll stumble at idle after the first deceleration. For instance when I get to the first stop light. Once I take off, it seems to be okay after that. All fluids are at appropriate levels, oil pressure while slightly jittery is healthy, temps are okay, vacuum is okay when the engine isn't stumbling.
  9. ^ That was my thought too. As this issue gets progressively worse you’ll start losing power in other gears too.
  10. Lifts can rock if not adjusted regularly. I need to do ours as it sounds like an EA81. EJ251: The only issue they have for daily driving is a touchy throttle between no throttle and very light throttle. I find this annoying and am yet to find a solution - not that I’m looking hard as I’m too busy driving it then when I’m not I’m doing other things… If you have the leaking coolant crustiness on the outside of the head, replace head gaskets with the Multi Layer Steel (MLS) units from the STi - someone here knows the part number for these. I replaced ours and zero issues for 200,000kms so far. Engine now done 515,000kms which we’re stoked about. Still pulls like a freight train through the rev range. Uses a little oil but I’m not worried about that.
  11. Last week
  12. Rear sump bolts are accessible through the engine crossmember. Lifting the engine in situ with the engine mounts undone and pitch stopper rod removed should be enough to get the sump out without pulling the engine out. Surface prep then becomes a challenge but should be doable. Ppl performed this in the past. Personally I do the sump when the engine is out for head gaskets etc. Or if removing the engine for this job I’d do other work at the same time that’s far easier with the engine removed - resealing other oil seals, valve tappet adjustments (ea81) for example.
  13. What does your compression look like with the engine cold and then with the engine at running temp?
  14. I have a 1997 Subaru Impreza that needs replacement weather stripping around the RH doors as well the rear lift gate. Sadly, these parts are discontinued by Subaru. Does anyone have an idea of where I might find these parts?
  15. Thanks, yes these are just simple straight through side feed. Maybe comments people made about turbos had me confused, it didn't look like these could leak. Thanks
  16. I would not be surprised if my rings were bad. That'd explain why my vacuum flutters on start up then quickly subsides within a minute. The throttle body I'm using is a junk yard unit so no clue if the previous owners tried to adjust the mixture. There is still a fuel smell to the exhaust. It's so weird because it went away after fixing the code 34, then it came back. At least now it's running without throwing a CEL or codes.
  17. Fouling after driving down the hill with clutch engaged, would likely be the pistons sucking oil past the rings into the combustion chamber. The dirty plug would confirm that. There is an mixture adjustment screw on the top of my intake manifold. You lean it out by unscrewing it and getting the highest idle rpm. You stop unscrewing it just as the maximum rpm is reached.
  18. The original bolts are so soft that they will break off with very little tightening. There is no idiots guide that says one must overtorque high strenth bolts. Given the limited thickness of the gasket, I would think that it would be quite impossible to warp that small of an oil pan, unless you are not into equal tightening on all sides. Removing the oil pan while the engine is in place, I believe it impossible. Beside accessing the rear bolt being quite difficult, the oil pan needs to slide out towards the rear due to the sloped oil intake tube below the engine. So snugging up new bolts appears to be the only viable option, unless you want to pull the engine.
  19. I went to inspect the purge solenoid. 24.5ohms resistance. Hmm the valve is good. Maybe there's an intermittent connection. Tested the engine harness. Continuity checks okay. Tested the harness between the ECU and the engine. Continuity checks okay. Maybe it's the ECU. I swapped in a different ECU. No more CEL and now the RPM's drop gradually versus with the other ECU they'd drop rapidly when the engine got to temp. Maybe it was an ECU issue? I'll see how this one does.
  20. Looking for wiper arms to fit my 1983 Subaru GL wagon 4wd email............egowing@tds.net
  21. Well at least I saw my box with my service manuals inside. I was way busy and did not take the box down and open it. But we have some warm weather tomorrow so I’ll check as I get back there. I kind of thought that link wouldn’t have the A/C from my foggy memory. I think folks who upload these get a little tired and figure “hey I’ve got the engine section, that ought to keep folks happy” and that’s the end of the upload. But with new technology maybe folks will fill in more.
  22. They’re fairly great. I have a small fleet of them now. 2002,2003,2003,2003 all Legacy or Legacy Outback. In 2004 and after you’ll get the fly by wire deal so no more throttle cable. And if you do an engine swap there’s a little work around for the EGR is swapping against the 2000-02 with a 2003 or 2004. You might never need that info since they generally run pretty well. Oh the piston slap in one of ours. Mostly when cold then quiets down. That’s the “new” lifter noise. Lifters aren’t as loud as the EA engines. Worse problem with driving these is just the usual - other drivers.
  23. So is there no deteriorating catalytic converter potentially contributing to clogged exhaust? Saw it on a Ford van years ago. Ran it loud and proud to diagnose a clogged cat.
  24. Just wanted to see if there is anything specific I need to check on. I'm going to do searches for any tsb's and other stuff but wanted any input you all might have on it. 153k has some ticking from the engine. Not sure if it is lifter or piston slap. Runs good. EDIT son took it out to show his brother how to drive a standard and muffler fell off. LOL Got one ordered. Thanks Hush
  25. Yep I spoke too soon. Went to start my car this morning before work and I got a CEL. Double bugger. Code 35, purge solenoid. So I'll be doing some tests tonight after work to see what's going on. If I need to, I'll be replacing the solenoid with the same model I used for my EGR solenoid replacement. AISIN VST-026. Boy have the price of those jumped since I last bought one! Nearly double the price.
  1. Load more activity
