All Activity
- Past hour
Just Bought a Brat!
Thank you, yes I should have never sold the one I had when I first moved to Colorado in the late 90s, been searching ever since for something worthwhile, meaning not a rust bucket. Now I can sell the jump seats I I have had in the shop for several years in case I found one that didn't come with those.
- Today
Strange, I just got digging into the catalog. Yea, one of the rear subframe bolts is different. It's drawn in the LR position. But the bushings are all the same. 🤷♂️
Back in a GL
Next on the agenda is figuring out my idle/mixture issues. I still seem to have a good little miss while driving. I've never used a timing light so I probably need to get one of those on order and con my father-in-law into seeing if he remembers how to use one. I know my distributor has been messed with at one time because it's got the wrong bolt in it. @bushytails , any advice?
Just Bought a Brat!
Congrats! I saw that on Cars and Bids the other day.
Just Bought a Brat!
Long time since I have been here, sold my 99 Impreza years ago. Just scored a Brat on BaT yesterday, I know it is a long shot, but I am going to need to find a perfect front bumper! Any leads would be appreciated. Bill Rigsby - Florissant, CO - 8,213 feet 1982 Brat
- Yesterday
Back in a GL
Coworker gave me a set of skis. I also have a new fuel filter to install at some point.
- Last week
You only find plutonium in select delorean cats, not subarus...
We thought we had prerun the rear diff and suspension swap on Bs Forester as best we could so we did that last weekend. Definitely seemed like it was time to swap the rear diff, it has been making noise (pinion bearing?) for a couple years now and there was more debris on the magnetic drain plug than usual. Everything went smoothly until we got to the rear diff bushings. They weren't completely shot but they almost certainly have 300k miles and 25 years on them and this would be the time to replace them. We tried the hollow hydraulic cylinder again but for some reason it didn't have as much stroke as it should and we couldn't see an easy way to bleed it or add oil. Then the threaded rod we were using snapped. At this point B suggested just removing the subframe. He was able to break loose all four bolts but then three of the four nuts started spinning inside the frame. So we hole sawed in from the top to get at those. That wasn't too bad but we cut into a vent line for the fuel tank so I replaced/rerouted that one later. One of the subframe bolts had a big shoulder on it that fit the subframe bushings fairly well, the other three were just 12mm. We used new bolts, anti seize, sleeves for all four bolts to fit the bushings better, washers and nylocks on the top when we put it back in. Pressed the bushings out and the new ones back in. Even in the 20 ton press removing the bushings took some effort. Reassembly went fairly smooth. B said the drive home was mostly good, pulling to the left which slowly seemed to improve. We were barely able to assemble the brakes with new pads on his worn front rotors we used in the rear, one of them was definitely dragging some. The next week he said everything was working alright and then suddenly on Wednesday it wouldn't rev over about 3000RPM, even in neutral. He tried a different fuel pump, the flow and pressure seemed good. Replaced air filter, plugs and wires, and tried a couple different coil packs, no improvement. He drove it to my house and we did some more troubleshooting. If anything the OBDII indicated it was running rich when it would stall and everything else seemed to be working properly (MAP, TPS, etc). Slammo suggested maybe the cats were plugged so we unbolted those. The front cat was empty. Fired it back up and revved out fine. Figured the plutonium from the front cat had plugged the rear cat so we tried backflushing it with compressed air which did nothing. Then tried backflushing it with the garden hose nozzle, not a drop came out the other end. B's hypothesis is that when we got a bunch of rain this week the moisture in the exhaust turned the plutonium dust into mud and completely sealed off the rear cat. He cut it out and welded a piece of tubing in its place and it runs great now. We also bled his rear brakes and replaced his HVAC fan switch with one that works better and did some other little things. In the meantime I changed the oil, oil filter, and air filter and charged up the AC on the Impreza and did a few other things. It's been awhile since I changed the air filter. That picture makes it look a lot worse than it was, there was just a ring of leaves at the end, filter itself wasn't too bad but I put in a new one. It has been running consistently cool now since the lower temp thermostat and hose rerouting and I think I've fixed a few small coolant leaks.
EA81 Hitachi distributor slop
If memory serves me, and it's not as good as it once was, you need to remove the vac module and three screws you mentioned -- the one under the rotor and the two inside the housing by the clips that hold the distributor cap in place. Dangerous amateur tip: you can put a slotted screwdriver tip under the reluctor and use the edge of the housing as a fulcrum to apply slight leverage to help unstick the breaker plate assembly.
can the engine and transmission come out the top?
Numbchux replied to sirtokesalot's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYes. 4th gens were available with the 2UZ 4.7l. Mine is a 1st gen, though. I have a 4.0 1UZ in it. Install is far from complete, but it runs and drives (no cooling system, so very briefly).
moosens replied to sirtokesalot's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXCool, thanks. Yeah Boyd’s I’ve dealt with when using a friend’s place in Norwich. But that’s a haul. Not sure what Johnny’s in Thomaston is up to lately. I think they have a new owner for a few years. Used to be ok, he’d let you walk and pick. Milford Auto Recyclers is messy but those guys can be fair too and let you walk through. I’ve picked there years ago but I’m not sure if they’re letting you pick. But they’re cool guys there.
el_freddo replied to sirtokesalot's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYou guys got a v8 4Runner as standard, or is that an engine conversion? We got the v6 or the diesel option, definitely no v8!
Stock 1988 RX rallycross NWRA
Rallycross is a good time, and depending on the surface and track layout can be a real strain on the cooling system. The last time I raced one was in a fully rally-prepped STi, and I had to drive it down the road 1/4 mile and back to let it cool off after every run.
Numbchux replied to sirtokesalot's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI know you've already done it. But when I scrap cars, I cut out the radiator support. Then the engine and transmission come out easy. I even made the upper radiator support bolt-in on my 4Runner during the engine swap. I had the V8, 4-speed auto and transfer case in and out of it several times, but left it all as an assembly.
I have discovered that much of my gradual performance degradation is due to excessive slop in my Hitachi distributor's upper shaft. Getting adventurous and hoping to save my little funds, I have three Hitachis. The faulty one in the car, the one that it replaced that needs cleaning and taken apart, and a third, a used one that I want to clean. How does one remove the "breaker plate" to get to the centrifugal weights? I've pulled the screw from the upper shaft, the two "breaker plate" screws, and the vacuum module, but stuck there as "breaker plate" is immovable.
Clutch replacement
lmdew replied to 19Red_wgn98's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXProper torque! The bracket can be replaced if needed.
Clutch replacement
19Red_wgn98 replied to 19Red_wgn98's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI have replaced the belt not the pulleys or tensioner. Sounds like a stupid thought process, but my belt literally broke some of the teeth off as it was running. Idk how I didn't have a blown engine since it’s the revision of the Ej22 (Piston design change in 97 and brought up compression). Didn’t have the money to replace tensioner or pulleys, but they were not shot yet. I’m going to go back to them because my cam seals are leaking pretty bad so the timing belt has to come off again. One thing I’m a bit concerned about is the tensioner bolt stripping out being it goes into aluminum.
- Clutch replacement
Clutch replacement
lmdew replied to 19Red_wgn98's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX1+ Engine work, pull the engine. No Lift, drop the trans. PB Blaster on all mounts/bolts. Reseal the rear Breather plate for sure. Metal plate better than plastic. Rear Main, I've never seen one fail. Most of the time it's the breather plate. I've had good luck with Grip Force clutch kits off ebay.
Need Cheap Parts?
I'm doing some spring cleaning and have a bunch of extra parts that I'm trying to sell cheap. Mostly 3rd Gen parts, but I do have 2nd Gen parts too. If you need something, send me a P.M. I have some of the more desirable/nicer condition parts already up on my eBay (only way I'm willing to sell is through eBay or in person). My eBay seller name is suspiciouspizza. I'll be getting everything I have up on my eBay within the coming month. These parts may be a bit dusty and crusty, or they may be in very good condition. Better condition parts will sell for more but otherwise I'm selling cheap. I bought all these parts in lots at scrap price. I'll be acquiring another lot soon. :]
- Earlier
Clutch replacement
bushytails replied to 19Red_wgn98's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYou should mention what the exact vehicle is, since there were some changes to the clutch release mechanism over the years. Your list sounds pretty good. You could get a new flywheel, have yours resurfaced, or just run it, depending on what it looks like. Your clutch kit should come with a new pressure plate, unless you're being extremely cheap. Always replace the pilot bearing (assuming it even still looks like a bearing - many have long since failed on older vehicles) and throwout bearing; both should be included with your kit. You should be able to get torque specs from https://charm.li/ , or look for a pdf manual for your vehicle. For better than stock, I've been extremely happy with my Spec Stage 1 clutch. Stage 1 is just a higher clamp pressure plate and a slightly grippier disc, nothing aggressive like the higher numbered stages. South Bend Clutch is a bunch of incompetent crooks, so avoid them when shopping for upgraded parts. (See, companies, you rip people off, and then they make sure to point out you suck in every single relevant discussion) A time estimate depends on your skill level and tools. If you have a lift, tranny jack, and a decade of experience, it's a 1-2 hour job. If you have a pair of ramps, a driveway, and a harbor freight starter tool set, plan on a weekend project. Pulling the transmission is easier than pulling the engine, especially if you don't have a fully equipped shop. For tricks, for a beginner, I'd say to make sure your disc is extremely perfectly centered, both by using the alignment tool provided with the clutch kit and by visually double-checking after torquing the pressure plate, and then be very careful mating the transmission back to the engine, making sure to exactly match the tilt angle of engine and transmission, then spinning either the engine or transmission until the splines engage and the pilot slips in.
Clutch replacement
I’m looking for a write up on how to replace the clutch and if there is anything else I need to do. I have replaced other clutch’s before, but not sure of the full process on these cars. The car currently has 226k so I was wondering what else I should replace while I’m there. I’m kinda thinking rear main, oil separator plate reseal, pilot, throw out, flywheel, obviously the clutch. What parts would you recommend for slightly better than stock? Is there anything else I should replace while I’m there? I see around where some people pull the engine, and some pull the transmission. What are torque specs and where could I find them? What is the estimated time in the full process. Also would like to know what tricks can be useful. Thanks again.
19Red_wgn98 started following Clutch replacement
Replacement ignition lock cylinder
lmdew replied to 19Red_wgn98's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXwww.car-part.com If you have a you pull it yard close by, just go in with your drill and drill out the bolts and get the complete assembly.
'79 Brat EJ22 Retrofit Build Thread
Oof, the hits keep on coming. Between life happening and that stint where the forums were down - I hadn't had much time to update this, but today I took the time to get things moving a bit again. Long story short - I decided the simplest thing to do to solve the rubbing problem as it currently exists was to cut the tack welds and shift the whole subframe back about an inch, rather than doing a whole bunch of complex bodywork. My bodywork skills are definitely not my stronger suit, so I figured I'd better make things fit to what's already there as best I can. While this job was harder than I thought it was going to be (I had to cut out a larger section of the bed to get my cutting tools in there), the wheels now sit squarely (loosely) in the middle of the arches. To continue the spirit of solving a problem by creating new problems to solve, now I have to modify the original rear diff crossmember to make up for the distance the entire assembly has moved. Probably going to knock that out in the next couple days. Basically for that I'm going to cut some chunks out of the existing crossmember , then offset them with lengths of rectangular or square tubing of similar cross section. It shouldn't be too difficult because the stock part is basically a piece of straight U-channel with bushings mounted through it. No weird bends or offsets to be had so as long as I modify it so the threaded holes move directly rearword, it should be a pretty quick fix. Once that's all done it'll be a temporary modification of the stock lateral links to bring everything a little tighter in towards the frame, then I'll get started on fabricating the strut mounts in the bed, and probably remeasuring everything to see about finding an off-the-shelf set of adjustable lateral links and trailing arms that fit, and then another semi-permanent modification of the rear CV axles to get those back on. I'll likely need to revisit the wheel arches in some form or fashion, but I'm hoping I can get away with just some good ol' fender rolling. Time will tell.
So I have a 98 Impreza and I’m trying to find a new ignition lock cylinder to replace mine. The previous owner left just the tumbler and not the entire assembly. I cannot find the replacement for a 98. I find 97 but not 98. Find every year after as well. I can find the ignition switch just not the full assembly. Any help would be very appreciated. Thank you.
