All Activity
This stream auto-updates
  1. Today
  2. Maybe i missed it but have you gotten an engine stand and flushed those head bolt holes? That’s going to be key. Same with bolt threads. Don’t sweat it all. Designs like these cam towers are reasons I have closed my chapter or EA82s but hey its your special engine so i understand your commitment. But to a lot of is older folks its just an EA82 and just do tour best, don’t go nuts with retotqueing the cam tower and etc etc but i am NOT a mechanic. Good luck.
  3. Thanks for your response. It feels like a wobble from the rear wheels but it could be a strong vibration. I can't see any wobble when I ride my bicycle beside or behind the car. It starts wobbling at bicycle speed and continues getting worst as I continue to slowly accelerate and stops as soon as I take my foot of the accelerator. After my process of elimination I have concluded it's either centre drive shaft rubber bushing, the transfer box, or the transmission. As there is no vibration coming from the front wheels and the auto transmission seems to functioning fine in all respect, good fluid, no leaks, and changes gears nicely, I tend to think its the drive shaft. I can not fine a new replacement for the centre bushing/bearing so I would have to buy a new shaft to eliminate that possibility, and the work to re & re. I was hoping I could easily and cheaply turn it into a FWD vehicle only. BUT, I also can't locate a new power transfer solenoid to re & re and not sure of what can of worms I may be opening up to replace it. The car has low mileage and motor runs well but it's been used like a work horse and has been beat up other wise, kind of like me at my old age and abused by hard physical work, so I'm hoping to get some more use to enable a big clean out of the salvaged construction materials around my home so my kids won't have to deal with my junk. So I'm looking for a simple, cheap fix to get a little more life and abuse out of it. Any future suggestions would be very much appreciated. My car has been a good work horse so I hate to put it out to the pasture yet while I still have a need for a beater. Thanks again.
  4. Yesterday
  5. You're going to drop the suspension ~8" and leave the steering rack where it is? That's going to require so much modification to the knuckles to try to maintain the geometry, much lower offset wheels (which will put more load on said steering). You don't need an entire second factory crossmember. You only need brackets to support the motor mounts. Add a plate to grab the 2 studs on the "back" (now front) of the differential. Generally at that height, the lift blocks spacing the crossmembers and other suspension pickup points are tied together to make a bit of a frame, and then the transfer case and "front" (now rear) of the new differential can mount to that. Good picture of the bottom. You can see all the extra bracing added from the suspension mounts, and crossmembers that mount the diff and tcase. As well as rock sliders. And a good picture of a front crossmember/engine mount situation. Lots of room for the steering shaft.
  6. If it's a vibration (rather than a visual wobble) coming from 'somewhere' in the rear of the car, then it could be the main drive-shaft vibrating under load. The centre bearing of the drive-shaft (located forward of the rear-diff) could be loose, or beginning to get loose.
  7. Might want to stock up on available parts as things don't look good for the supply of aftermarket parts:
  8. If your sure your lug nuts are tight , then likely your bearings are shot . To replace the complete hub is not that hard. Just time and jack stands. Go here for fsm:Index of /Auto/Japan/Subaru
  9. I have another question regarding oiling the head bolts. After doing some reading online, specifically for rebuilding EJ's, some people really stress oiling the underside of the washers (knew that) as well as the underside of the bolt heads. Doing this makes sense but the FSM doesn't mention doing that. So is it okay to only oil the threads and the underside of the washers? Or should I also oil the underside of the bolt heads? Also some people really stress using a high-pressure assembly lube rather than engine oil. The FSM specifically says "oil". I know it's not rocket science but with how rare parts are, I want to take my time and do it by the book and learn from other's experience rather than learn the hard (and expensive) way. :]
  10. Thanks man. I'm definitely familiar with the shifter joint fix on the EJ series as I've done it three times before and makes me hate roll pins. I shot DRW an email to see what they have for it, I appreciate the referral.
  11. When you say rear wheel wobble do you mean vibration? This could be caused by many things as noted - start with the basics: - check mounting bushes of gearbox, diff and tail/propshaft; check centre bearing of the tailshaft for movement. - check uni joints for any play. ANY movement in one of these (where you can move one bearing cap closer to the other without the other one moving) means you need to replace it. Which means mods or a new tailshaft. - check rear CVs for any unexpected movement. Also realise that putting the 2wd fuse in will still see the rear drive shafts, diff and tailshaft spinning when the car moves. It just won’t receive power from the gearbox - assuming you have the auto from your description. What speeds do these vibrations occur? Is there a specific gear it happens in? Can you induce it by driving “manually” by selecting the gear the auto is to be in? If it occurs in all gears when accelerating my thoughts are it will be an issue with the auto.
  12. Nope. Meant EA82. The EA81 shifter is completely different to the EA82. Ahhh… sorry, it just clicked, you’re talking about an EA81 5spd. I’m pretty sure these are more like the EA82 setup too. I’m not used to the EA81 wagons being a fwd 5spd - we only got that gearbox in the hardtop coupes over here. All wagons were 4wd 4spd boxes. So with your sloppy shifter, get under the car: If you see a uni joint on the selector shaft it’s same or very close to EA82. It probably needs a set of bushes, I did a repair to mine once with a piece of garden hose… If the selector shaft is horizontal and has a sleeve over it then that thread fix *should* be of use. Hope this helps - and clears up some confusion!
  13. I am a new forum participant with a serious problem. My 1996 Subaru Legacy has a bad wobble from the rear wheels when accelerating (not when coasting). The car has low mileage (156,000 km) and the engine runs well and I need the vehicle but can't afford an expensive fix. I typically do my own mechanical repairs and maintenance. I tried to switch to front wheel drive only but it appears the power control solenoid is malfunctioning. When the correct fuse is installed the dash indicator FWD light comes on but the rear wheels still get power to them and so the wobble continues. Is there anything I can do to disengage the rear power to the rear wheels? I can't find a correct power solenoid for such an old vehicle. Is there some ghetto-rigging I can do that would enable more car use without quickly damaging the transmission or other essential component? Is there any way of resolving my problem short of replacing the rear drive train components by the trial and error method?
  14. Going to the UP in a few days but I don't anticipate using the low range much. Thought I replied here but don't see it now so I'll try again. Got the low range rebuilt with some of the upgraded parts. For instance, added needles to this surface on the input shaft that rides in the high range output shaft. These are locked together in high range but are always discolored and worn after use. Trans went back together fairly easily. B checked the gap on the crank trigger sensor (only .024", would be fairly difficult to reduce) and replaced the clutch disc. We put the trans back in and reassembled the rest of the car. Seems to be back to normal. At first the clutch action was strange, the first half of the pedal travel just got the slave pushrod in contact with the fork so you had to push the pedal all the way to the floor. Tried pumping it up and bleeding it, no improvement. After maybe an hour of city driving it's suddenly back to normal, only have to push the pedal about 1/4 of the way down to disengage. Low fuel light no longer works, it was working during last year's trip out west but I ran out of gas with the gauge a little above empty and no light on the dash. Fortunately was able to coast into a gas station to a pump, did have a jerry can with me. One of the seals on one of B's struts was out of place so we took the strut off and went through it. Got the seal retainer welded back into place, replaced that seal, cleaned up the threads on the shaft, and replaced the bumpstop.
  15. Last week
  16. I've got a buddy coming on Friday to take a look and will report back with his opinion as well. Hopefully it's just a bad cv and I can find a decent replacement somewhere.
  17. New off RockAuto... stupidly went with the cheapos... https://www.rockauto.com/en/moreinfo.php?pk=9129200&cc=1270134&pt=2288&jsn=584
  18. Using an additional engine cross member was my initial plan (this does match what I have seen in the previous tcase builds) , but I wasn't sure I'd be able to extend the steering input shaft (i.e. the part that goes to the u joint) through the additional cross member To handle the steering adjustment I was thinking of extending the tie rod ends and leaving the steering rack where it is. I'll have to see how extreme the angle becomes with this approach The front control arms have two mounting points that I am planning to drop down off of the fabricated portion of the front subframe. Depending on the trickiness of relocating the front control arm mounting point I may end up cutting/using a portion of a front cross member anyway (the bottom half) Reusing the rear subframe will provide a start to integrating the equivalent of "frame rails" to mount the t case to. Between mounting this front subframe (with rail supporting the tcase) to the original control arm mounting points, the transmission cradle mounting points, and eventually the rear subframe I hope to provide enough support The 2.0 in the Crosstrek doesn't make a crazy amount of torque but I am concerned with the larger gear ratios still blowing components up.
  19. Good tip Imdew, but i was trying to test the ball joint all along, but quite impossible without disassembly it seems..... if you lift the car, the A arm sits at such an angle that even if there was play, i dont think that id feel it tugging at the wheel. its not like checking for freeplay at the steering head in a bike refretfully crazy how with those tie rods gone, car felt like its totally clapped out! with new stupid tie rods, feels like a new car, just odd
  20. Zero. The EA82 5spd is essentially the predecessor to the EJ 5spd and shares far more with with that box than the 4spd.
  21. If you do wheel bearings I'd recommend buying sealed bearings and foregoing the seals. If anything take one seal off each bearing, face the unsealed sides into the knuckle and pack grease between them inside the knuckle. The seals are a real pain in my opinion. Front bearings are super easy compared to the rears, if you lift the engine & trans as a unit to get the axles out then you don't have to detach any suspension components. If anything take your outer tie rods out of the knuckle but I got away without it. Putting the axles back in, you may have to loosen/partially drop the control arms. :]
  22. Thanks yall. I jacked it up again today and made sure the axle nut was tight as well as the lug nuts. There is a little vertical play in the passenger side wheel but that was there before when there was no clicking noise prior to replacing the cv's (I have to replace the wheel bearings but didn't have time while doing the axles). I could replace the bearings and see if that fixes it Noise is the same while turning and I haven't been able to test with another passenger yet but will try to do that today. The inner cups seem to have a lil bit of play - don't think they are jammed downwards by the shafts. Cone washers are installed. This noise only started after replacing the cv axles so I don't think there are any issues that suddenly arose with the transmission, driveshaft, or engine mounts. I've uploaded a video of me driving here: https://youtube.com/shorts/xNpCdfp6KzQ?feature=share Hope this is helpful!
  1. Load more activity
