2
Everything posted by edrach
Harbor Freight has some awesome tarps.
May 15th Rallyx #2 in Oregon
edrach replied to Qman's topic in Meet n' Greet. Your USMB Welcome Center
So who all is going to the rallycross this weekend? Portlanders: what's the long term weather report for Sunday? And the time leading up to it. It would be nice if the field were waterlogged like last time; no need for the water truck. -
If you haven't done it yet, replace the air filter. I think running it hard for two tankfulls of gas will help a lot. Also check for a good connection on the O2 sensor.
The Next of Many Dumb EA81 Questions
edrach replied to Bucky92's topic in Old Gen.: 80's GL/DL/XT/Loyales...
If you can persuade another local EA81 car of similar vintage to come visit, it should help figure out the wiring. Good luck with it. The HTKYSA disk is on it's way via 1st class mail; I hope it helps. -
EA82 LSD rear diff conversion
edrach replied to torxxx's topic in Old Gen.: 80's GL/DL/XT/Loyales...
As long as the rear ratio (3.700 or 3.900) is matched, they are all the same. -
1986 GL and Brat: AXLE ISSUES
edrach replied to 86looneyGL's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Again: www.cvaxles.com. -
My new to me XT6 is alive!! OMG (Pic added)
edrach replied to Qman's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Way to go; I can't wait until next weekend. -
Carefully, locate the center with a punch and drill out about 1/2" deep if you can and open up the hole to about 1/8th inch diameter. Soak the bolt remains with liquidwrench or some such and use an "easy out" to try to unscrew it. Most of the time you can save yourself more work this way. If not, you're most of the way to drilling and re-tapping.
if water pump is needed....ebay or jy?
edrach replied to starkiller's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Yes I still have it available if it's the right one for you. That being said, considering the labor involved to replace a waterpump on your car, I wouldn't put less than new in your car. Do it the next time you replace the timing belts. -
Borrowed Axle tool--please return
edrach replied to edrach's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I'll post a pic this evening. -
I was lucky enough to get mine on ebay. -
Normally it's not needed but some bearing/axle combos are pretty tight and this just makes the job much easier. -
Too late for a floor pit.
Sorry to you all; I finally found it (as you can tell I'm cleaning up my garage). It was hidden away somewhere where I never would have put it. Must have been my wife. -
Is my new Half shaft bad?
edrach replied to phychotron's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Vibration while accelerating which goes away immediately when you lift off the gas and coast is almost always a sign of a bad DOJ (inner joint) of the axle. I'm not familiar with it producing a tapping noise. -
A while back I lent the special tool for pulling the axle back through the hub to someone local. I'm thinking of doing some axle work on the Brat and it would be nice to have it back. So will the person who has it be kind enough to bring it back. Thanks.
How to remove the studs on my brat?
edrach replied to Flowmastered87GL's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Come April 1st, it's a $400 fine if caught. -
An easy way is to jack up the front end with the car in neutral and the handbrake off. Put your hand on the spring in the strut and spin the tire by hand. You'll feel the vibration of a bad bearing in the spring long before you feel any wobble using the other methods. The same method can be used on the back wheels although there's more mass involved in the rear drivetrain. If you find a bad bearing in the front, do them both; if you don't, you'll be doing the other shortly anyway. Also check to be sure the castle nut is tight; it makes the same noise as a bad wheel bearing.
Sounds like an easy way to throw a stud through the gas tank or into something else nasty. -
Driveline question regarding 5 speed swap
edrach replied to richieroo's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Speaking of harmonic humm; make sure you work out a way to attach the exhaust in the center as with the old 4 speed. I had just put a rubber hanger in the center on mine at first and the exhaust would resonate loudly around 2800 to 3200 rpm (cruising speed on the highway); my wife found the noise very annoying. When I finally fabbed a solid support in the center where it belonged, that resonance was finally eliminated.
