Everything posted by blownbimer
MEET: CO: May 21th at Red Rocks Park
blownbimer replied to The Korean's topic in Meet n' Greet. Your USMB Welcome Center
Promise? Im sure I'll make it out there in one of the beasts....or maybe I should show in a Civic or a BMW? ahhh Thanks Erik -
First, check the Vitals, I usually taste the oil on the dipstick.Pull the oil cap, and look for creamy goodness-Creamy goodness is not good, its bad. Check The ATF, Smell burnt? Power brake it, and feel for the trans slipping. Check the tires, make sure they all are even worn. Diffrent color body panels? Look for signs of a hard hit. Legs have the spare in the trunk right? Pull up the spare and look for signs of rust. Turn in a tight circle and listen for clicking...better yet, crawl under and look at all the axles for torn boots. While your under the car, look for excessive subaru seepage. Hammer on the car, make sure the shift is crisp. Turbo holding the boost when you do that? Pull the intake tube and check for excessive oil in the tube.Ask the owner not to warm up the car. That way, when you start it, you can test its cold start, as well as looking for valve guide smoke..Think SBC! Good luck! When are you going to check this thing out? Thanks Erik
shouldn't be too bad....If you plan on a wrenching party, let me know....and I think russ owes you to help...heh Oh, are you running this thing very much? Might want NOT to run it much if it is mixing water and oil...dont want to wash a bearing.... Thanks Erik
Kingbobdole here, stealing Noss's intraweb.... Id just like to say that I would think he'd rather go with the EJ series tranny cuz... I know the cvs are the same and the lenght is the same... the issue is the rear mounts, which I'm not sure on.... also the adapter plate would be easier but priceyerer er.... if you get a donor turbo leg, that'll make it easy... just depends on how much power you plan to make andd in an XT6 somewhere in the 170 horse to the ground area will make you take down a WRX... they are not that fast... my xt6 can take down a stock wrx.... As far as the engine goes... I'd either just try a combo of motor mounts and cross members till it fit... worst case, you have to do a bit of modding, but the motor mounts for the 6 and ejt are VERY similar... just the blot is off a bit which makes me think its cake to get it in there..... as far as engine management goes... I'd rethink MS at that... yeah yeah yeah I said it before, but there are many prefabbed things that will go on an EJ and be cake to make work... MS is a little bit more hands on... and I'll lend you a hand, but if you cant figure it out, theres no reason to have it, get something more basic... The ER27 being "unturboable" is total CRAP... I will prove it my self if I have to... I just need 2 more parts:burnout:
84 Turbo wagon failed emissions
blownbimer replied to blownbimer's topic in Old Gen.: 80's GL/DL/XT/Loyales...
temp gauge never moves much, maybe the thermostat is stuck open, and not letting the car warm up...it has been like 5 degrees here..heh Thanks Erik -
Anyway to adjust the mixture on this one? or is it all electronic? Thanks Erik -
Guy I got it from just replaced the water pump...humm...sounds like I need to call him and see if he still has the marker Thanks Erik -
That plastic peice is GONE on this one...motor is super clean on this car, so its not just hiding from me. Prob play around with it...or go to sidewinder and get one...are they a PIA to put on? -
Well, i thought she was running good....aparently not. I took her over to the emissions place, and she failed the CO part of the test.100 on the co with a limit of 20. Looking at the papers, it failed at high speed on the dyno...so Its over fueling then. Where to start checking? this car has recently had a tune up, but the timing hasnt been set b/c of no marks. 02 sensor? where oh where to start? Thanks Erik
what makes a ea82t engine die?
blownbimer replied to subiemech85's topic in Old Gen.: 80's GL/DL/XT/Loyales...
For me, It was 25psi of boost, which made the impeller grind on the housing via 1/2 inch of play, which led to metal shavings which led to the rod feeling the need to tell me how unhappy it was to be inside the motor.... -
Wha? Its ALIVE!!! MWAHAHAHAHAHA!!!!
blownbimer replied to Caboobaroo's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Hey it runs! Now I need to head up there with my bat and whoop ya into finishing it...sounds like your really, really close! Thanks Erik -
Why NAPA EXhaust gaskets SUCK!
blownbimer replied to kingbobdole's topic in Old Gen.: 80's GL/DL/XT/Loyales...
So your saying torque it till you fart, then back it off half a turn is not the proper spec for exhaust bolts? Hehe...Glad you got your cesnna fixed phil! Thanks Erik -
What color should wagon wheels be?
Gona go for gloss white I think....I have the chrome rings/ center caps for it...I'll polish them and put em on! Thanks Erik -
Attn:EA81T people in colorado....
blownbimer replied to Jerry DeMoss's topic in Old Gen.: 80's GL/DL/XT/Loyales...
PM me with a phone number....I can call you when I see them... -
saw them draining that silver one when I was there sunday....anyone needs anything from eather of these turbo cars, I will be going on thursday, and would be more then happy to pull parts....anyone who wants to tag along is more then welcome to.... Thanks Erik -
Anyone able to order one of subaru special tools? I just tried at my local dealer and they said they could have one by the end of feb....I was hoping for one a little sooner... any ideas? when I put the number into one of the subaru web sights they freek out. Thanks Erik
Ok, I give up. What did I do wrong?
blownbimer replied to subynut's topic in Old Gen.: 80's GL/DL/XT/Loyales...
The ones I've used, you put the cly in question on TDC, then, you connect a fancy air tool to the spark plug hole.Im sure autozone rents them. When the air blows, you should be able to listen in the oil cap, air filter, and exhaust pipe, wherever you hear a hiss, thats where to start looking. Thanks Erik -
Know what the krylon code for that is? Thanks Erik -
They sell it peice by peice...http://WWW.pullnsave.com will give you a price list if your interested... Thanks Erik
Anyone done a leak down? find out where you loosing the compersion? Thanks Erik -
Grabber green is always an option...But This car is just way too clean to do that to..heh Thanks Erik -
Eh hem....My car wasn't the one that sounded like a hoover at the last meet... Your apron is waiting.... Thanks Erik -
Not a good pic, but its all I have at the moment... Thanks Erik -
I have an 84 Turbo wagon, and It has the spoked wheels. What color should I paint them? Bright white? or kinda an off white? or was body colored an option? Thanks Erik
