Everything posted by jamal
Pick up a chilton's/haynes manual. It has torque specs. Lug nuts are about all I actually put a torque wrench on, outside of engine components. For the brackets, it's "pretty tight," and for the caliper to bracket bolts it's "not quite as tight." Of course there are a few that you need to be careful on like endlinks and strut top bolts. And spark plugs, and the oil pan.
I don't suppose they'd let you swap in the rear crossmember and diff from an AWD soob, weld the diff, and remove the front axles to be rwd? That would really expand upon your suspension options, because there is nothing for FWD cars. Actually it might be possible to fit konis in the rear struts. I wouldn't bet on it though. If you haven't started building the car, why not just find a better group 2 platform? Also, if you haven't rallied or built a rally car before, why not buy a finished or partially finished used one? Generally that will save a lot of money.
What, through magic? I'm not saying you shouldn't seafoam the car, but the compression and timing (and FI) are what determine the need for higher octane to prevent pre-ignition and detonation. You're not pinging with 87 because octane requirements go down as elevation increases since the air pressure is lower.
Sup Bosco. You'd also want to put bigger injectors on both cars and have a way to cut fuel pressure when running without it. If I were you I'd start with the brat, and then try to adapt it to the OBS once you have the kinks worked out. Yeah that's Douglas Vincent. With the number of motors he's gone through I wouldn't exactly call it "successful."
Hrmm KYB
jamal replied to nipper's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
I think a lot of this "yeah the GR2s are stiffer" partially comes from going to new struts from old blown ones. Konis are expensive and pretty stiff. But they will fit in most subaru strut housings. Probably not outback stuff though because it's longer. Some guy on nasioc got them into STi housings but it's not easy. Oh, and KYB is stamped into my sti struts. -
Hrmm KYB
KYB makes most of the OEM struts, and the GR2s are pretty much the stock equivalent. I've heard 0-20% stiffer depending on the car. -
you have open front and rear differentials and a center differential with a viscous coupling to limit slip. The viscous coupling will transfer 28lb-ft with a 100rpm speed difference between the front and rear. I don't know how the transfer capability changes with different speed differences or the upper limit of how much can be transferred to the front or rear. If, for example, you had the front or rear wheels up on rollers, the VC would not be able to transfer the full power of the motor to the wheels with traction (assuming they had enough to not spin). http://www.ultimatesubaru.org/forum/showpost.php?p=618964&postcount=41
CD Player
jamal replied to RBGERSON's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
It's very easy to remove and replace. Pretty much any other Subaru radio will swap right in, and used WRX 6-disc changers go for $40-80. If you remove the cupholder and ashtray you should be able to see the small screws holding the trim in place. -
Why would it not be? Anyway, you could get a generic rack and then make yourself some brackets that attach it to the seat back or something like that. I don't know if a big shotgun will fit across though. Or do something like those pet barrier things that use compression to hold themselves between the floor and ceiling.
Duty C controls the pressure to the hydraulic center clutch pack. When you're rolling along and the solenoid is operating at 90%, it's sending fluid to the clutches which force them apart and allow the front and rear to spin at different speeds. There is still a small amount of resistance, which is where that 90/10 comes from. Once enough of a speed difference is detected between the speed sensors, or the TCU determines it necessary based on throttle input etc, the solenoid will drop pressure to the clutch, which allows the plates to come together and send more power rearward. The power split that is listed, ie 90/10, 50/50 for 5mt, and 41/59 for dccd, only applies when all four wheels are turning the same speed and a limited slip device is not in operation. Once a wheel slip occurs, the split depends on the amount of center lockup and the available traction at the front and rear.
