Everything posted by bheinen74
hijack but related...i did the Hella conversions for all 4 lights on my brat. 2 times now, sometimes i cannot go back to just low beam, like the switch isnt working on the low. hibeam switch off, and the "beam" indicator still lit and all 4 lights are on. I had to disconnect the high lamps on my last drive. Do i need a relay, is my switch getting fried, or do i have a lamp grounded out somewhere? sometimes it works fine, but then gets stuck on high...
well, i ended up using the stock skid plate, with a fabb'd cross bar welded to front of the plate, and rear slightly bent. rear attached like stock, front welded bar attaches to the front pushbar lower bracket via bolts. all this on a 4" lift brat.
4 headlights low uses outer bulbs on low wattage high use outer on high wattage, plus the inners. your low beam high portion is out. replace the light.
i bet the linkage is fine, i bet the "grooves" of the wiper arm where it attaches are stripped. easy fix. to fix. take off arm retainer nut to the side not working. check the grooved/probably find pieces of metal. get a small piece of screen wire, the metal kind. enough to fit over the wiper stud. place arm back on, tighten nut. the screen wire will cause it to grip again. rock on
do you think my Baja Widetrack AT's 205/75/15 or my 175/70/13 Continental now tires, will do better in snow. last year i drove with the snows. i have a choice this year. both sets are near new, snows are studless.
DesMoines IA meet Sat. 29
bheinen74 replied to subiemech85's topic in Meet n' Greet. Your USMB Welcome Center
good to meet, now we need to go crash nasioc http://forums.nasioc.com/forums/showthread.php?t=850855&page=448 they meet first wednesday every month. -
100hp and AWD, compared to 400hp RWD, you will see what the subies AWD system is all about. on snow, ice uphill, etc, the subie will outrun anything on the road with its puny little boxer engine. you will be racing everyone in the snow, and win no probs.....
check/clean all the electrical connectors to the fan connector up by the radiator. mine was corroded (green), and cause no fan when i got the brat.
Civic didnt come easy. took me about 5 years of hard searching for this one. It replaced another 91 hatch si that i bought a month before i found this one. and it replaced my crx si. I can say, after i got it, i still searched for one even better. cars are addiciton for me. the last 8 years i have still been watching, and this one is the nicest by far i have seen come up anywhere, thats 8 years agressive searching or more. I now know this is the nicest one in the states. thanks.
Legz
bheinen74 replied to SubaruJawn's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
that should buff right out. -
where are your old tires wheels going nice tires there. Big
brat wont heat up....
bheinen74 replied to ()__1337_CRAYOLA__()>'s topic in Old Gen.: 80's GL/DL/XT/Loyales...
had the problem and it turned out that reversing the heater hoses gave me heat, guess there is a right and wrong way for the hoses to go on. right way give heat, wrong way no heat. that was my experience. -
admin on here says the site might go down for maintenance, means we need to give emails to keep in contact, or check the chat room my email is bheinen@yahoo add that to your address book to keep me updated if we lose the site for maintenance -
I just cleaned the garage up, making a spot for when i bring the SVX home on Friday night. http://s405.photobucket.com/albums/pp132/bheinen74/garage%20cleaned%20ready%20for%20svx/ civic is up front-I had to jump the battery it was drained down SVX will go on the right side, Brat will move to the left, white car sits out on the pad to left of garage, and the wagon is for sale so it will be going bye bye.
i could do 2pm... yeah, still early enough to see the cars before dark to get pictures, and won't keep us there when its dark and cold. Even if there's only a few of us we can discuss our cars, parts etc and get ready for another meet later, maybe discuss a little trail run when we have some snow..... bh
