Everything posted by bheinen74
flashing power mode light indicates a code is stored, meaning for a code something has failed. could be a switch, could be a solenoid. SVX has problematic transmission from the get go, they all do, not a single one escaped a trans problem. - it can be fixed. prepare for some shock about the price to fix.....BIG TIME SHOCK
big trouble
bheinen74 replied to ellets's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
took this album of pics today all are from the front of car. hope this is a start, if all else fails, i am serious interest in your car if you want out. cheers http://s405.photobucket.com/albums/pp132/bheinen74/legsshoses/ -
big trouble
I can put up pictures of the 94 turbo under the hood, and help, i could even come get it so you dont scrap it. this is that silver wagon from st loius with b;pwn hg right hopefully the car didnt give him a stroke. -
i can fit any chunk in any case, without ring gear attached. Its the part of when the ring gear is attached that the ears need ground off.
ring gears need to stay with the case they came from, put the ring gear back into its original with the pinion gear as it matches. LSD cases have the "ears" ground off on the 4 insides so it will fit in. Non lsd diff still have the "ears", so you need to grind those ears off the case for it to fit. I lke to use a high speed air grinder with diamond bit for my grinding. you will grind down just to the side cover bolt holds are starting to show up. Compare to a original lsd case you will see the bolt holes. make sure to stuff a rag over the pinion when grinding, and to use air compressor to blow it out and make sure its totally free of any debris.
I dont live anywhere near a pawn shop. about 30 miles to the nearest one. I use Ebay for most my shopping.
New Guy from North Idaho
bheinen74 replied to Idasho's topic in Meet n' Greet. Your USMB Welcome Center
needs roof rack yours is really nice. -
I bought a 92 Legacy sport
bheinen74 replied to wplocal's topic in Meet n' Greet. Your USMB Welcome Center
91 and 94 are the most desireable 91 cause it had vlsd rear and oll cooler for he ej22t 94 cause it was last year and had better headlighting and better interior ammenities. i owned a 92ss and it was awesome also owned a 93ss, 94TW, and a current 94ss liked the 94's most but would DIE for a 91 just could not find any. -
depending on the laws there, you may just want to put on a set of hella 500's at the same level as the current lights. Subaru in general, did not research headlight beam quality when they design them..compared to about all other manufacturers, the headlight are as you describe.
swap the heater hoses around and check your heat. thats what was the matter on my BRAT. seems those valves are a one way and you should try to reverse the flow from how it is now. good luck report back.
tis the time of year for threads regarding heat. what year model make?
wow, those things rusted in half here at the frame after the box.. none of the last 40 i looked at had a solid frame, even tho they said it was ok, i saw daylight thru each frame rail and hit it with my flashligt bottom and chunks fell out. goot luck
