Everything posted by Durania
Skid plate saves the day (not how you think)
Wow, talk about lucky.
Project 83 coupe
Boy that does look good. Can't wait to see a group shot of it and Lil' Blue.
Brat project finished!
Gosh, that is hot.
Getting a 89 RX Turbo
This sums every bit of it up when it comes to the EA82T. I agree with GD, hope its not too late to pass on the sale.
Where were 1st gen Impreza's built?
Durania replied to danbennett2u's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXOta-Gunma, Japan. Along with the Forester.
Twist-N-Lock Hubcap Alternative?
Durania replied to Bmm001's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXNothing wrong with going to a junkyard or posting here in the "wanted" section.
removing engine bay undercoating garbage
Holy crap that thing is in great shape. Throw up some interior pics.
will 05 16in wheels/tires fit on 90 Legacy Sedan LS AWD ?
Durania replied to tjaiz's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThanks, this is what they are on now:
02 Impreza Broken Timing Belt?
Durania replied to lmdew's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXNever heard of someone getting that lucky. Do they compression test to make sure. Pretty crazy if everything is fine.
Will 99 EJ25 work in 2000 Forester
Durania replied to davidswilliams's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXReferencing the Impreza/Forester line.
Durania replied to davidswilliams's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXBoth 99 and 00 will have SOHC engines.
Durania replied to davidswilliams's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI think it will. Probably will have to swap intake manifolds since the 99 is MAF based and the 2000 is MAP.
Durania replied to tjaiz's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI had 16" WRX wheels on my 91 Legacy with stock 205/55 size tires and had no trouble at all. Noticed a huge difference in handling.
repair a MAF?
Durania replied to aa8jzdial's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYou should be able to find one at a junk yard. Not sure if you will be able to use one off of a 98 since it was DOHC that year and 00-01 were MAP based so those years are ruled out.
Car dies overnight, possibly alternator??
Durania replied to eventoday's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI put an auto zone reman one on my Brat when it died after work one day. Of course I didn't have much of a choice. I do try and stick to OEM on most items simply because there is a large difference in quality.
4.8 vs 4.2 2.2
Durania replied to bobaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXHuh? Oil capacity?
Durania replied to eventoday's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXHow about just going ahead and replacing it? That way it doesn't kick the bucket on you 70 miles from home and end up paying the tow bill on top of a new alternator.
spark plug socket size
Durania replied to 86subaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYep, the 2.5 and 2.0 DOHC are in there horizontally. The SOHC engines are in at angles.
Durania replied to eventoday's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYes.
Overheating and blowing cold air
Durania replied to 90subaruls's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI am sure you'll remember it but make sure you get the Subaru gasket for the thermostat as well.
Durania replied to eventoday's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXMy money is on the alternator, those things can be finnicky when they are on their way out.
EJ25 Piston Removal
Durania replied to Durania's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXGot ya, thanks. Looks like I need to invest in some monster Hex heads.
EJ25 Piston Removal
Durania replied to Durania's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXNot really wanting to disconnect the piston for the rod. Would like to keep it all together as one piece.
Smelly HVAC
Durania replied to brus brother's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXSubaru makes something that will clean and refresh your HVAC system. I've seen it advertised in some pamphlets they send me.
Durania replied to 90subaruls's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXDid you happen to flush the heater core as well?
