CEL went off, Front Cat..OR 02 Sensor, want to do SEAFOAM?
johnceggleston replied to SubeeTed's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXlmao :banana::banana: seafoam :banana::banana:
CV axle not fitting correctly
johnceggleston replied to simpreza2's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXa simple glance at the axle attachment point on the trans will tell you if it is there or not. if you have a splined shaft sticking out of the trans case, you have the #14 stub shaft.
johnceggleston replied to simpreza2's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXif he takes a pic of the stub in the trans will you believe that it is there and you are the only who can not see it. it is not in the axle he took off and i don't think he over looked it when he was cleaning up his tools, especially considering how much you have talked about it. if it is not there, where did it go? it was there when he drove into the garage and took the axle off. so unless the mice ate it, or it rolled across the floor and under the work bench after he removed the axle, it is there. and i can see it in the picture. BUT, since i'm not there i could be wrong, but i'm not the only one.
johnceggleston replied to simpreza2's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXok, it's the same axle. this means you are doing something a little wrong. i think my approach would be to loosen the axle nut, slide the splined end out of the hub enough to get it attached on the trans end. then put the outer end completely back together except the axle nut. at some point the correct conditions should occur so you can start the nut on the threads. of course this is just an idea that i haven't tried. but if the axle has any chance of fitting correctly, it should be with everthing bolted together as it should be. either this or you just need to force it.
Preparing to replace timing belt on 2000 Forester
johnceggleston replied to chrisw's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXoem idlers are pricey, but if the off brands fail it doesn't matter how cheap they were. do a search for 'timing belt' and you'll get more info.
johnceggleston replied to simpreza2's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXi assume you are sure it is the right axle. perhaps the boot was clamped on the shaft in the wrong place making it look like it's fully extended when it's not. how much will it compress, more or less than the old one? compare side by side. where did you get the axle? can you exchange it?
johnceggleston replied to chrisw's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXthere are several parts dealers on line, www.subarupartsforyou.com https://www.subarugenuineparts.com/oe_parts_cat.html are 2 subaru parts dealers. some buy on ebay, some only buy oem. as for replacing parts, you need to weigh the cost of the parts now, your money, and the labor to do the job again later. assuming you get a warning the parts going bad. if the waterpump, tentioner or idlers go bad on the hiway, it will cause bent valves. which parts do you think will make it to the 200k, next?, belt change and is it worth the risk? how long do you plan on keeping the car?
gas smell at startup
johnceggleston replied to eventoday's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXit's worse if you have to back up in the morining to turn around. as you drive through your exhaust the defrost sucks it right in. i usually open left or right side windows for a few seconds to change the air once i get moving.
how to tell if i have a LSD
johnceggleston replied to crash321's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXby the way crash321, yours is the best avatar i've seen in a long time. :banana::banana: do you have to cook them??
Idler pulleys
johnceggleston replied to tidd1340's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXi've never heard anyone ask this before. pulleys should be easy to come by. try removing one belt at a time to see if the noise goes away. maybe have a replacement ready to go in. i have heard that the ac pulley bearing (not the one on the compressor, but it can go bad too and is also replaceable) can go bad and that they are replaceable, but probably easier to replace the whole thing.
johnceggleston replied to crash321's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXfor most lsd diffs, you jack up both rear wheels and turn one wheel by hand. if both wheels turn the same direction it's limited slip. if they turn in different directions then it's an open diff. this may not work on a viscous lsd. in those, the viscous fluid needs to heat up before it will limit slipping. any one else know about a vlsd?
front axle question legacy 2.2
johnceggleston replied to 86subaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXi'm pretty sure they are the same. i've swapped them before. there is a difference between FWD and AWD, but they both will fit. i think the FWD axle has a thicker shaft. if the manufacturer used a different part number due to some slight modification the parts house may not know they are the same. check out the new parts site for cross reference. http://opposedforces.com/parts/
transmission ID
johnceggleston replied to 2.5GL's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXthere's one for manual trans search for 'trannychart' http://www.northursalia.com/techdocs/trannychart/trannychart.pdf
Lookie!!!!!!!!!!!!
johnceggleston replied to nipper's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXwhen you look for a part that's specific to one model like an outback strut, it does a good job. but when you look for a part used on several models, like a legacy strut, the cross reference is amazing, absolutely great.
Starting issue
i guess you'd have to pull the starter to check the contacts, and at that point you may as well replace them. when my 97obw occasionally did this, i installed a new relay at the starter. apparently there wasn't enough juice coming from the ignition relay(?) to engage the solenoid but when the new relay was mounted at the starter, there was enough juice to activate the new relay. the new relay switches on a new fused power feed to the solenoid which then has all the power it needs to activate. and this solved my problem. but if your solenoid is clicking, your problem is probably different. most of the time, the contact replacement is the repair choice in this situation. but with a one year old starter........
HELP: CEL CODE P0420 {2000 Forester}
johnceggleston replied to howards11's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXrarely is this a cat problem, especially at 66k miles. usually it's a front o2 sensor problem, although a little early at 66k. the replacement HAS to be a subaru part. you can order it on line from one of the dealers who sell for a little less. and it's not too hard to do yourself. http://www.subarupartsforyou.com https://www.subarugenuineparts.com/oe_parts_cat.html
1997 Legacy Gt 2.5 radio interference
johnceggleston replied to Joenasnj's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXremove the belt that drives the alternator.
Im Back!!
johnceggleston replied to Bserk's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXyou probably know, but don't forget the new screws for the seperator plate. the ones from the plastic plate won't work.
battery going dead
johnceggleston replied to pamike's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXamps is the rate of electricity used, disconnect the draining component, use less electricity, amps will decrease.
4eat compatability
was it by chance a turbo?
Can MY 99 legacy Rear Diff Fit MY 95
johnceggleston replied to pearlm30's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXthe axles will definatly work and the rear diff should work as long as the car is a 2.2L engine. whats the par number for the trans.?
CEL code P0420
johnceggleston replied to ryanw's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX95 used a different o2 sensor i think, 2 of them , front and rear were the same. you need the o2 sensor that matches your ECU, so unless you changed the computer as well as the engine, you need the one for the 97-98. when buying parts, never mention the 95 2.2L engine, unless you are buying engine parts. you'll just confuse the parts guy.
CEL code P0420
johnceggleston replied to ryanw's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXwww.subarupartsforyou.com engine parts, sensor o2 = 22690AA290
4eat compatability
gary's right, very hesitant. but having said that, i have seen no evidence of a 3.9 in an auto legacy, manuals only. all auto legacys up thru 95MY have a 4.11. when you search for 93 impreza differentials at car-part.com, they give you 90 - 94 legacy, loyale, and impreza 3.9 ratio. they do not specify auto vs. manual. because of the lighter car and the 1.8L engine in the impreza and loyale, my guess would be that your does not mathc the legacy trans. impreza 93 l wagon, TZ102ZX3AA (94 as well) legacy 92 l wagon, TZ102ZA2AA the TZ102 is the same, this is the trans type they used it until 98 or 99. the double AA on the end is the same, in legacy this means leg "L", CA = GT, BA = outback. so my guess is it means the equivilant in imprezas, i don't even know what that would be. i do know that at least some impreza outback sports had the BA on the end. the X3 and A2 are the issue. when they started making the 4.44 final drive for the 2.5L cars the A went to a 2, so if there is a final drive difference this could be the indicator. typically the 3rd to last character progressed upward most model years. one year the legacy outback was a ABA the next year it was a CBA and then a DBA. i searched car-part.com and : TZ102ZA3DA = 95 impreza 2.2L auto w/ 4.11 ratio. i think this means no match. TZ102ZA1AA = 94 leg auto non-turbo. they return 92 - 94 all together. TZ102ZA1AA = 91 leg auto non-turbo, 90 - 91 were lumped together. one of these may be wrong. i couldn't find a legacy .......TZ102ZA2AA or a part number for early 90s leg auto w/turbo. i guess your leg trans could be a turbo?????? i hope this helps.
What is the difference between a regular Subaru Legacy wagon and OutBack wagon?
johnceggleston replied to WickedV6's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXlegacy L , LSi and GT each came with different size wheels, but the diameter of the tires were very ,very close. so the GT has a 16' wheel, but the over all tire size is the same as the L and LSi. you can put GT tires on an L with no problems, no adjustments. the reason you can't put L wheels on a GT is the the 14" steel wheels will not clear the brakes. the same is true for outbacks. you can put outback wheels on a L, with out any lifting, if you use 205 tires with a smaller aspect ratio. so the diameter is close to that of the leg L. the width is not the isue, it's the height. there is a tire size calculator by miata that will help.
