fnlyfnd
Everything posted by fnlyfnd
The tranny doesn't have its own computer, it uses the tcu/ecu/ecm whatever you want to call it. This is the main "brain" of the car and controls everything ELECTRONICAL. If the manual tranny was electronic, why would you have to use your left foot and right hand to make it work? The electronical devices would do it for you. Stop reading for a second, clear your mind.....heres an awful analogy - If a 5 ball pendulm was electronic you would just have to flip a switch to turn it on. You have a model that isn't; you have to raise the ball yourself. Both of these are mass produced, so they use the same base. All you have is a block, strings, balls. The block/base is universal, having a spot for batteries and a switch. If you put batteries in your model and flip the switch, nothing happens. Its purely mechanical.
How can the jumper work on manual trannys. A manual tranny is mechanicaly controlled, how can a electric device overide it. A auto tranny is electronically controlled hence the reason the electrical jumper can override the center diif/clutch pack I really don't think the jumper works on your manual car. I know on mine I dont even have a place for the fuse to go in.
Yea I guess you're right. I still don't like the idea of having diff. fluid in an auto tranny though. Are you sure this isn't just a cleaning process, and should be flushed out in a couple K miles. From what I read (quickly) it cleans out the gummy stuff. Which I would imagine means, don't run for a long time. I have a manual tranny, I usually dont pay attention to this auto stuff.
Half doors and super swampers = a badass obs Looks great man
My new lego
fnlyfnd replied to 99lego's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
http://www.cars101.com
