fnlyfnd
Everything posted by fnlyfnd
Once the leaks are fixed the car will be good for awhile. The Ej22 is the best engine subaru ever made, althought you have the 2nd gen, it is still a great motor. I say fix it w/ a private shop buying the parts yourself from a online dealer (subarugenuineparts.com or 1stsubaruparts.com, etc..). As long as the tranny is good and the body isn't roting out it would be totally worth it to fix it.
check nasioc, a lot of people do it best bet is to get a whole complete wrx that is salvaged. You'll need everything (harness, ecu, dash?, pedals, reard diff, etc..) Should be able to get it done over a weekend. I believe the entire dash itself is a near perfect fit. Even if you did the mechanical end, a shop cold do the electrical stuff. I'm sure someone in WA specializes in this kind of thing. Eastcoastswappers.com ...just to check it out I know its the wrong coast
My 2.2 was always a little under half way. That was a 1996 legacy though. The fuse holder is its own special thing. It is not in the fuse box, just kinda mounted on the strut tower or firewall. No box, no other fuses. When a fuse is installed into it, it puts the car into FWD. Again, if it is installed just run away no questions asked. Take it to the mech. no matter what. Get it in the air and look for leaks. The 2.2 is notorious for oil leaks around 120k.
