moosens
112
Everything posted by moosens
It's a rather nice example. Especially for the northeast. There are pics out there already somewhere from the previous owner. But yeah , show the car. We know what the fuse box looks like.
Oh , and I have a bunch of original factory fuel filters in their Subaru boxes. I also have some new old stock for your car like tail light lenses and side markers etc.
name is moosens but I understand how you saw that ..... Paul works too. That dome light cover just pops off. Use a fine blade straight head or just your fingers as you gently squeeze it to release the cover. I have some low mileage parts still from a real life old lady car 76 GF two door. I have that fuse cover for sure and plenty more. You car was almost mine. Lol !! Enjoy it !!! You can always try me here or email moosens at yahoo
Dead Loyale after timing belts broke and replaced
moosens replied to TPaul's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Are timing covers off now? Are marks still where they should be? -
Usually filters have arrow on Side or Top to indicate flow. And those bulbs are easy enough to find.
You want to check the fuse box itself is grounded properly too. The order is the same for your 76 as the later models , box and cover same but maybe blue and black.
Greg , welcome ! I'm unable to see where you are but given your criteria and especially if you are in a rust zone , you may want to find one from a high and dry climate. Also you might want to consider a 90-94 Legacy. Enjoy !
Trying to start for first time after 14 years...
moosens replied to Scooner's topic in Historic Subaru Forum: 50's thru 70's
79 begins electronic distributors and internal voltage regulation. So that's why the later EA71 - actually last version of top starter and now wide case at this point - has the pick up. -
Using my 78 4wd wagon for function in the slop that covered our roads today. Man what great looks this car gets now! And there were accidents everywhere but none I saw were our brand. That's it ! Nothing too major. Just saw the historic section needed a push. Happy Thanksgiving to those who celebrate. !!
- 1 reply
- 1
EA81 (Brat) brake system malfunction - help diagnose
moosens replied to ettev's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Probably unrelated but check that the plastic air suction thing isn't disintegrating. Just something I thought of in relation to my old gen 2 brat. Mine broke up and chunks of the plastic cause major carb/drivability issues when good old Skip took it home to PA. Good luck ! Happy Thanksgiving! -
Mike , got your PM Geez , been a long while.... Vacuum hose from booster to intake? -
78 DL automatic Governor Gear
moosens replied to Brett!'s topic in Historic Subaru Forum: 50's thru 70's
There is one on eBay currently. Also , there exists an upgrade metallic version which is not so necessary if you're keeping it as vintage novelty. -
Picked up a 1979 DL automatic today...
moosens replied to sjschlag's topic in Historic Subaru Forum: 50's thru 70's
And I'm pretty sure that's the exact same thru the Loyale series. -
There might still be the original white plastic type still on eBay. There also exists a metal upgrade governor gear which a good dealer source guy should be able to dig out. That could conceivably take you a lifetime to wear out if you treat the car as novelty and not full time daily. -
If you find the actual part you will have accomplished something very special. A few of us have parts manuals and I'm sure eventually one of us will post the part number. Keep in mind Subaru has newer superseded part numbers now and your local guy will likely find they are not available.
Up above the modulator you replaced on the upper passenger side there is a governor. I think it's three 10mm bolts that hold it in place. Take that out gently and clean it as I'm sure it's gunked up from sitting. I had success that way with one of our automatic cars. You access that from the engine bay. It's toward the front of the tranny. -
New member in Upstate NY
moosens replied to bobomb's topic in Meet n' Greet. Your USMB Welcome Center
Your heart will welcome a new brand real soon.- 1 reply
- 1
